things you need,
a mobile that support web surfing like the I-Phone 4, other mobile devices should work as long they support Java script execution
1. some modern mobile
2. Handbrake Batch Encoder - download from here http://www.box.net/shared/i6exaxr438
3. utorrent 3.0 http://www.utorrent.com/downloads/complete?os=win
4. HFS ~ Http File Server http://www.rejetto.com/hfs/download
next step, install everything
i assume you installed everything, now go into C:\ and create the following folders
Garbage
Downloads
Completed
next step is to configure the directory on utorrent, start utorrent, go into options and under directory add the paths like this
Put New downloads in {x}
C:\Garbage
Move Completed downloads to {x}
C:\Downloads
next step , click on Remote option and enable your u-torrent to be accessed on-line just follow the questions, create your User name and password, add your Question password and thats it. click on apply and ok. utorrent is done.
next step. setting up the watchfolder paths
click on HandBrake WatchFolder icon on desktop, now right click your mouse on the task bar icon and click settings,
now do the following
source directory to watch
C:\Downloads
source 2 Directory to watch
C:\Downloads
target location to save encoded file
C:\Completed
make sure you pick the right preset for your mobile device, click on choose built in preset and pick mp4 or whatever your mobile can support.
this is optional , click on after encode option and add the path to C:\Completed
now, click on update settings
we now need to start HFS file server, open hfs on the left side you would see empty home directory, you right click your mouse key and add folder from disk C:\Completed
now this is important, you need to disable the limits in hfs, click on menu , limits options, > disable speed limits
and if that anti leech is ticked on disable that also. thats about it.
now everything is configured.
now go into your mobile and open browser, and type in http://web.utorrent.com you should see mobile version of u-torrent remote, just add your user name and password you created
thats it now you can import torrents into your client. it will download convert and send into completed folder,
to find the encoded mp4 file you just type in 127.0.0.1 and thats it happy streaming.
sorry no pictures I'm feeling pretty lazy nowadays
so if your still confused, what this is all about, this enables you to download torrents through your mobile and have your computer encode the file and send it into the file server where it feeds it back online through port 80 so you can stream with your mobile
