how to build a drawing machine
PraveenAlexis
Re: how to build a drawing machine
Post by PraveenAlexis » Wed Jul 27, 2011 2:13 pm
Imagei could find some motors from my old brocken DVD-Rw ;)
Post by Neo » Wed Jul 27, 2011 7:27 pm
New topic added, How to control Hard Disk motor using a microcontroller ;)
Rksk,
Remember I was talking about the tray motor of the CD ROM. Accidentally I found a video on that. It's a stepper motor.
Ability to control position accurately without a feedback system (such as using an encoder) is a feature in a stepper motor. Since the angle movement per pulse is well defined, it is easily possible to control the angular velocity using a little microcontroller.
[media]http://www.youtube.com/watch?v=dSKac6EPkrc[/media]
Post by Neo » Thu Jul 28, 2011 1:09 pm
Information here are related to donation topic here.
According to the doc How it Works.docx, you will need to apply an edge detecting filter to convert the source picture to machine printable drawing. This subject comes under Computer Vision -> Edge detection. I would like to propose either Sobel or laplacian filters.
Source Picture
Destination machine printable drawing
First you need an image reader (Such as JPG reader) and then apply this sobel filter to get the edges that are ready to be sent to the printer. Finally output the data line by line (called vector graphics).
I can help you to do this since I have done these in past. Let me know.
Post by Neo » Thu Jul 28, 2011 3:29 pm
Keep these circuit diagrams with you guys.
Power supply
Since the motors are 12V, find a 12V / 2A transformer to suit both needs. 7805 will provide essential 5V and power to the uC (microcontroller).
Power supply.jpg (29.95 KiB) Viewed 14811 times
Stepper motor control with ULN2003
Oscillator & MAX232
Lots of exiting things to happen ;)
PraveenAlexis
Post by PraveenAlexis » Thu Aug 11, 2011 11:00 am
1) The two accells
2) Cartridge Holders
3) Stepper Mortes x 3
4) Normal DC motors x 2
5) Belts x 2
Neo, can you make this pic small :) i dont know how to do it :roll:
Reason: Image resized and uploaded :)
Post by Neo » Thu Aug 11, 2011 12:56 pm
So you have enough items to give a start. Next thing is to give a start. I'll give you some guidelines.
First thing is to design the structure. I think threaded rods can be easily used for moving parts. You can easily find them in local hardware shops.
  1. Sample structures
    1, 2 and 3 are 3 threaded rods that are fixed to 3 stepper motors to move along x, y and z.
    Another sample structure:
    The one in https://robot.lk/viewtopic.php?f=75&t=2594#p7607 is also a good example.
  2. Threaded rod
  3. Mounting motors to threaded rod
  4. Fixing the other end to a Ball bearing
  5. Fixing a nut to moving part
  6. Once we are done with the structure, it's about moving the motors in x, y and z directions using electronics.
Since you have few people on the group, you can ask someone to identify the wires, voltage & current ratings and angle per step of each stepper motor.
We can discuss about the electronics part later.
PraveenAlexis
Post by PraveenAlexis » Thu Aug 11, 2011 1:22 pm
shenal is working on the electronical parts, and im working on the structure ;) shenal have an idea about moving the pen up and down without the stepper, he will explain you when hes done with it, :)
Post by Neo » Thu Aug 11, 2011 2:51 pm
I guess he is going to use a solenoid? If that is the case, I think it's a good idea as long as he can control the pen on hitting the paper slowly (using a spring may be) to avoid damage to both paper and pen. We can discuss that later.
Good luck!!!
PraveenAlexis
Post by PraveenAlexis » Sun Sep 04, 2011 10:45 am
we finished making the structure! Nw we have to do the electronic part! I wish shenal will reply here soon!
Post by Neo » Sun Sep 04, 2011 1:38 pm
A picture is worth a thousand words !!!
Can you update with some pictures.
