A process can be identified as a set of instructions loaded to the memory. Every process has UID and GID.
Who is the owner of the ‘firefox’ program?
stat /usr/bin/firefox
	stat $(which firefox)Observe,
Get PID, Executed User, Real User, Common Name
ps axo pid,euser,ruser,comm |grep firefox
ps axo pid,euser,ruser,comm |egrep ‘init|firefox’
	ps axo pid,%cpu,%mem,tty,euser,ruser,comm |lessfind the parent process
pstree |lessWhat is a Signal in Linux
This a UNIX concept which is used to inter-process communication. Using Signal can send a message directly to a process. There are many Signal types are available. Most frequently use signal are;
HUP (1) -> re-read the config file
KILL (9) -> Terminate immediately
TERM (15) -> Terminate gracefully
Further, observe
man 7 signalCode: Select all
kill
killall
pkill
pgrep
Observe:
1.
        $ pgrep crond
	$ pgrep cupsd
	# kill -HUP $(pgrep crond)
	# kill -HUP $(pgrep cupsd)
	$ pgrep crond	-> has PID got changed?
	$ pgrep cupsd  	-> has PID got changed?
	# kill -9 $(pgrep cupsd)
	$ pgrep cupsd
	# service crond start
	$ pgrep crond 	-> check the PIDCode: Select all
        $ firefox &
	$ killall firefox		->Observe the firefox
	$ pkill firefox
$ firefox
	$ ctrl + z
	$ jobs 	-> find the job id
	$ bg %1	-> resume the background process 1
	$ fg %1
	$ kill %1Start Stop Services
All init script of the process are usually in /etc unless if you have given a installing prefix when compiling the packages.
How to use;
/etc/init.d/servicename start|stop|reload|restart|statusCode: Select all
service servicename start|stop|reload|restart|statusStart Stop service while Boot and Shutdown time
At the booting process kernel start the init process, which is the master process of the system. Then read the /etc/inittab to decide the default runlevel.
Observ:
cat /etc/inittab|
# Default runlevel. The runlevels used are:
# 0 - halt (Do NOT set initdefault to this)
# 1 - Single user mode
# 2 - Multiuser, without NFS (same as 3, do not have networking)
# 3 - Full multiuser mode
# 4 - unused
# 5 - X11
# 6 - reboot (Do NOT set initdefault to this)
id:5:initdefault: # default runlevel
According to the runlevel defined the appropriate directory is used to run the initial script.
				|- rc0.d
				|- rc1.d
				|- rc2.d
	/etc/rc.d/|- rc3.d
				|- rc4.d
				|- rc5.d
				|- rc6.d
Observ:
	ls -al /etc/rc.d/rc5.dCode: Select all
K95cgconfig -> ../init.d/cgconfig
K95firstboot -> ../init.d/firstboot
S02lvm2-monitor -> ../init.d/lvm2-monitor
S07iscsid -> ../init.d/iscsidAnatomy of the init scripts
                     S 07 iscsid
S for start at boot _|	|	|_  init script
K dont start		|_ prority level
