74 series is an TTL logic IC series made by Texas Instruments. An Electronics Engineer can never miss the 74 series.
Just the base numbers are listed below, that is: parts are listed here as if made in the basic, standard power and speed, TTL form, although many later parts were never manufactured with that technology.
7400: Quad 2-input NAND gate
7401: Quad 2-input NAND gate with open collector outputs
7402: Quad 2-input NOR gate
7403: Quad 2-input NAND gate with open collector outputs (different pinout than 7401)
7404: Hex Inverter
7405: Hex Inverter with open collector outputs
7406: Hex Inverter Buffer/Driver with 30 V open collector outputs
7407: Hex Buffer/Driver with 30 V open collector outputs
7408: Quad 2-input AND gate
7409: Quad 2-input AND gate with open collector outputs
7410: Triple 3-input NAND gate
7411: Triple 3-input AND gate
7412: Triple 3-input NAND gate with open collector outputs
7413: Dual Schmitt trigger 4-input NAND gate
7414: Hex Schmitt trigger Inverter
7415: Triple 3-input AND gate with open collector outputs
7416: Hex Inverter Buffer/Driver with 15 V open collector outputs
7417: Hex Buffer/Driver with 15 V open collector outputs
7418: Dual 4-input NAND gate with schmitt trigger inputs
7419: Hex Schmitt trigger Inverter
7420: Dual 4-input NAND gate
7421: Dual 4-input AND gate
7422: Dual 4-Input NAND gate with open collector outputs
7423: Expandable Dual 4-input NOR gate with strobe
7424: Quad 2-input NAND gate gates with Schmitt-trigger line-receiver inputs.
7425: Dual 4-input NOR gate with Strobe
7426: Quad 2-input NAND gate with 15 V open collector outputs
7427: Triple 3-input NOR gate
7428: Quad 2-input NOR Buffer
7430: 8-input NAND gate
7431: Hex Delay Elements
7432: Quad 2-input OR gate
7433: Quad 2-input NOR Buffer with open collector outputs
7436: Quad 2-input NOR Gate (different pinout than 7402)
7437: Quad 2-input NAND Buffer
7438: Quad 2-input NAND Buffer with open collector outputs
7439: Quad 2-input NAND Buffer
7440: Dual 4-input NAND Buffer
7441: Binary-coded decimal to Decimal Decoder/Nixie tube Driver
7442: BCD to Decimal Decoder
7443: Excess-3 to Decimal Decoder
7444: Excess-3-Gray code to Decimal Decoder
7445: BCD to Decimal Decoder/Driver
7446: BCD to Seven-segment display Decoder/Driver with 30 V open collector outputs
7447: BCD to 7-segment Decoder/Driver with 15 V open collector outputs
7448: BCD to 7-segment Decoder/Driver with Internal Pullups
7449: BCD to 7-segment Decoder/Driver with open collector outputs
7450: Dual 2-Wide 2-input AND-OR-Invert Gate (one gate expandable)
7451: Dual 2-Wide 2-Input AND-OR-Invert Gate
7452: Expandable 4-Wide 2-input AND-OR Gate
7453: Expandable 4-Wide 2-input AND-OR-Invert Gate
7454: 4-Wide 2-Input AND-OR-Invert Gate
7455: 2-Wide 4-Input AND-OR-Invert Gate (74H version is expandable)
7456: 50:1 Frequency divider
7457: 60:1 Frequency divider
7458: 2-Input & 3-Input AND-OR Gate
7459: 2-Input & 3-Input AND-OR-Invert Gate
7460: Dual 4-input Expander
7461: Triple 3-input Expander
7462: 3-2-2-3-Input AND-OR Expander
7463: Hex Current Sensing Interface Gates
7464: 4-2-3-2-Input AND-OR-Invert Gate
7465: 4-2-3-2 Input AND-OR-Invert Gate with open collector output
7468: Dual 4 Bit Decade Counters
7469: Dual 4 Bit Binary Counters
7470: AND-Gated Positive Edge Triggered J-K Flip-Flop with Preset and Clear
74H71: AND-OR-Gated J-K Master-Slave Flip-Flop with Preset
74L71: AND-Gated R-S Master-Slave Flip-Flop with Preset and Clear
7472: AND Gated J-K Master-Slave Flip-Flop with Preset and Clear
7473: Dual J-K Flip-Flop with Clear
7474: Dual D Positive Edge Triggered Flip-Flop with Preset and Clear
7475: 4-bit Bistable Latch
7476: Dual J-K Flip-Flop with Preset and Clear
7477: 4-bit Bistable Latch
74H78, 74L78: Dual J-K Flip-Flop with Preset, Common Clear, and Common Clock
74LS78A: Dual Negative Edge Triggered J-K Flip-Flop with Preset, Common Clear, and Common Clock
7479: Dual D Flip-Flop
7480: Gated Full Adder
7481: 16-bit Random Access Memory
7482: 2-bit Binary Full Adder
7483: 4-bit Binary Full Adder
7484: 16-bit Random Access Memory
7485: 4-bit Magnitude Comparator
7486: Quad 2-input XOR gate
7487: 4-bit True/Complement/Zero/One Element
7488: 256-bit Read-only memory
7489: 64-bit Random Access Memory
7490: Decade Counter (separate Divide-by-2 and Divide-by-5 sections)
7491: 8-bit Shift Register, Serial In, Serial Out, Gated Input
7492: Divide-by-12 Counter (separate Divide-by-2 and Divide-by-6 sections)
7493: 4-bit Binary Counter (separate Divide-by-2 and Divide-by-8 sections)
7494: 4-bit Shift register, Dual Asynchronous Presets
7495: 4-bit Shift register, Parallel In, Parallel Out, Serial Input
7496: 5-bit Parallel-In/Parallel-Out Shift register, Asynchronous Preset
7497: Synchronous 6-bit Binary Rate Multiplier
7498: 4-bit Data Selector/Storage Register
7499: 4-bit Bidirectional Universal Shift register
74100: Dual 4-Bit Bistable Latch
74101: AND-OR-Gated J-K Negative-Edge-Triggered Flip-Flop with Preset
74102: AND-Gated J-K Negative-Edge-Triggered Flip-Flop with Preset and Clear
74103: Dual J-K Negative-Edge-Triggered Flip-Flop with Clear
74104: J-K Master-Slave Flip-Flop
74105: J-K Master-Slave Flip-Flop
74106: Dual J-K Negative-Edge-Triggered Flip-Flop with Preset and Clear
74107: Dual J-K Flip-Flop with Clear
74107A: Dual J-K Negative-Edge-Triggered Flip-Flop with Clear
74108: Dual J-K Negative-Edge-Triggered Flip-Flop with Preset, Common Clear, and Common Clock
74109: Dual J-Not-K Positive-Edge-Triggered Flip-Flop with Clear and Preset
74110: AND-Gated J-K Master-Slave Flip-Flop with Data Lockout
74111: Dual J-K Master-Slave Flip-Flop with Data Lockout
74112: Dual J-K Negative-Edge-Triggered Flip-Flop with Clear and Preset
74113: Dual J-K Negative-Edge-Triggered Flip-Flop with Preset
74114: Dual J-K Negative-Edge-Triggered Flip-Flop with Preset, Common Clock and Clear
74116: Dual 4-bit Latches with Clear
74118: Hex Set/Reset Latch
74119: Hex Set/Reset Latch
74120: Dual Pulse Synchronizer/Drivers
74121: Monostable Multivibrator
74122: Retriggerable Monostable Multivibrator with Clear
74123: Dual Retriggerable Monostable Multivibrator with Clear
74124: Dual Voltage-Controlled Oscillator
74125: Quad Bus Buffer with Three-State Outputs, Negative Enable
74126: Quad Bus Buffer with Three-state Outputs, Positive Enable
74128: Quad 2-input NOR Line Driver
74130: Quad 2-input AND gate Buffer with 30 V open collector outputs
74131: Quad 2-input AND gate Buffer with 15 V open collector outputs
74132: Quad 2-input NAND Schmitt trigger
74133: 13-Input NAND gate
74134: 12-Input NAND gate with Three-state Output
74135: Quad Exclusive-OR/NOR Gate
74136: Quad 2-Input XOR gate with open collector outputs
74137: 3 to 8-line Decoder/Demultiplexer with Address Latch
74138: 3 to 8-line Decoder/Demultiplexer
74139: Dual 2 to 4-line Decoder/Demultiplexer
74140: Dual 4-input NAND Line Driver
74141: BCD to Decimal Decoder/Driver for cold-cathode indicator/NIXIE Tube
74142: Decade Counter/Latch/Decoder/Driver for Nixie Tubes
74143: Decade Counter/Latch/Decoder/7-segment Driver, 15 mA Constant Current
74144: Decade Counter/Latch/Decoder/7-segment Driver, 15 V open collector outputs
74145: BCD to Decimal Decoder/Driver
74147: 10-Line to 4-Line Priority Encoder
74148: 8-Line to 3-Line Priority Encoder
74150: 16-Line to 1-Line Data Selector/Multiplexer
74151: 8-Line to 1-Line Data Selector/Multiplexer
74152: 8-Line to 1-Line Data Selector/Multiplexer
74153: Dual 4-Line to 1-Line Data Selector/Multiplexer
74154: 4-Line to 16-Line Decoder/Demultiplexer
74155: Dual 2-Line to 4-Line Decoder/Demultiplexer
74156: Dual 2-Line to 4-Line Decoder/Demultiplexer with open collector outputs
74157: Quad 2-Line to 1-Line Data Selector/Multiplexer, Noninverting
74158: Quad 2-Line to 1-Line Data Selector/Multiplexer, Inverting
74159: 4-Line to 16-Line Decoder/Demultiplexer with open collector outputs
74160: Synchronous 4-bit Decade Counter with Asynchronous Clear
74161: Synchronous 4-bit Binary Counter with Asynchronous Clear
74162: Synchronous 4-bit Decade Counter with Synchronous Clear
74163: Synchronous 4-bit Binary Counter with Synchronous Clear
74164: 8-bit Parallel-Out Serial Shift Register with Asynchronous Clear
74165: 8-bit Serial Shift Register, Parallel Load, Complementary Outputs
74166: Parallel-Load 8-Bit Shift Register
74167: Synchronous Decade Rate Multiplier
74168: Synchronous 4-Bit Up/Down Decade Counter
74169: Synchronous 4-Bit Up/Down Binary Counter
74170: 4 by 4 Register File with open collector outputs
74172: 16-Bit Multiple Port Register File with Three-state Outputs
74173: Quad D Flip-Flop with Three-state Outputs
74174: Hex D Flip-Flop with Common Clear
74175: Quad D Edge-Triggered Flip-Flop with Complementary Outputs and Asynchronous Clear
74176: Presettable Decade (Bi-Quinary) Counter/Latch
74177: Presettable Binary Counter/Latch
74178: 4-bit Parallel-Access Shift Register
74179: 4-bit Parallel-Access Shift Register with Asynchronous Clear and Complementary QD Outputs
74180: 9-bit Odd/Even Parity bit Generator and Checker
74181: 4-bit Arithmetic Logic Unit and Function Generator
74182: Lookahead Carry Generator
74183: Dual Carry-Save Full adder
74184: BCD to Binary Converter
74185: Binary to BCD Converter
74186: 512-bit (64x8) Read-only memory with open collector outputs
74187: 1024-bit (256x4) Read only memory with open collector outputs
74188: 256-bit (32x8) Programmable read-only memory with open collector outputs
74189: 64-bit (16x4) RAM with Inverting three-state Outputs
74190: Synchronous Up/Down Decade Counter
74191: Synchronous Up/Down Binary Counter
74192: Synchronous Up/Down Decade Counter with Clear
74193: Synchronous Up/Down Binary Counter with Clear
74194: 4-bit Bidirectional Universal Shift Register
74195: 4-bit Parallel-Access Shift Register
74196: Presettable Decade Counter/Latch
74197: Presettable Binary Counter/Latch
74198: 8-bit Bidirectional Universal Shift Register
74199: 8-bit Bidirectional Universal Shift Register with J-Not-K Serial Inputs
74200: 256-bit RAM with Three-state Outputs
74201: 256-bit (256x1) RAM with three-state outputs
74206: 256-bit RAM with open collector outputs
74209: 1024-bit (1024x1) RAM with three-state output
74210: Octal Buffer
74219: 64-bit (16x4) RAM with Noninverting three-state outputs
74221: Dual Monostable Multivibrator with Schmitt trigger input
74222: 16 by 4 Synchronous FIFO Memory with three-state outputs
74224: 16 by 4 Synchronous FIFO Memory with three-state outputs
74225: Asynchronous 16x5 FIFO Memory
74226: 4-bit Parallel Latched Bus Transceiver with three-state outputs
74230: Octal Buffer/Driver with three-state outputs
74232: Quad NOR Schmitt trigger
74237: 1-of-8 Decoder/Demultiplexer with Address Latch, Active High Outputs
74238: 1-of-8 Decoder/Demultiplexer, Active High Outputs
74239: Dual 2-of-4 Decoder/Demultiplexer, Active High Outputs
74240: Octal Buffer with Inverted three-state outputs
74241: Octal Buffer with Noninverted three-state outputs
74242: Quad Bus Transceiver with Inverted three-state outputs
74243: Quad Bus Transceiver with Noninverted three-state outputs
74244: Octal Buffer with Noninverted three-state outputs
74245: Octal Bus Transceiver with Noninverted three-state outputs
74246: BCD to 7-segment Decoder/Driver with 30 V open collector outputs
74247: BCD to 7-segment Decoder/Driver with 15 V open collector outputs
74248: BCD to 7-segment Decoder/Driver with Internal Pull-up Outputs
74249: BCD to 7-segment Decoder/Driver with open collector outputs
74251: 8-line to 1-line Data Selector/Multiplexer with complementary three-state outputs
74253: Dual 4-line to 1-line Data Selector/Multiplexer with three-state outputs
74255: Dual 4-bit Addressable Latch
74256: Dual 4-bit Addressable Latch
74257: Quad 2-line to 1-line Data Selector/Multiplexer with Noninverted three-state outputs
74258: Quad 2-line to 1-line Data Selector/Multiplexer with Inverted three-state outputs
74259: 8-bit Addressable Latch
74260: Dual 5-Input NOR Gate
74261: 2-bit by 4-bit Parallel Binary Multiplier
74265: Quad Complementary Output Elements
74266: Quad 2-Input XNOR gate with open collectorOutputs
74270: 2048-bit (512x4) Read Only Memory with open collector outputs
74271: 2048-bit (256x8) Read Only Memory with open collector outputs
74273: 8-bit Register with Reset
74274: 4-bit by 4-bit Binary Multiplier
74275: 7-bit Slice Wallace tree
74276: Quad J-Not-K Edge-Triggered Flip-Flops with Separate Clocks, Common Preset and Clear
74278: 4-bit Cascadeable Priority Registers with Latched Data Inputs
74279: Quad Set-Reset Latch
74280: 9-bit Odd/Even Parity bit Generator/Checker
74281: 4-bit Parallel Binary Accumulator
74283: 4-bit Binary Full adder
74284: 4-bit by 4-bit Parallel Binary Multiplier (low order 4 bits of product)
74285: 4-bit by 4-bit Parallel Binary Multiplier (high order 4 bits of product)
74287: 1024-bit (256x4) Programmable read-only memory with three-state outputs
74288: 256-bit (32x8) Programmable read-only memory with three-state outputs
74289: 64-bit (16x4) RAM with open collector outputs
74290: Decade Counter (separate divide-by-2 and divide-by-5 sections)
74291: 4-bit Universal Shift register, Binary Up/Down Counter, Synchronous
74292: Programmable Frequency Divider/Digital Timer
74293: 4-bit Binary Counter (separate divide-by-2 and divide-by-8 sections)
74294: Programmable Frequency Divider/Digital Timer
74295: 4-Bit Bidirectional Register with Three-state outputs
74297: Digital Phase-Locked-Loop Filter
74298: Quad 2-Input Multiplexer with Storage
74299: 8-Bit Bidirectional Universal Shift/Storage Register with three-state outputs
74301: 256-bit (256x1) Random access memory with open collector output
74309: 1024-bit (1024x1) Random access memory with open collector output
74310: Octal Buffer with Schmitt trigger inputs
74314: 1024-bit random access memory
74320: Crystal controlled oscillator
74322: 8-bit Shift register with Sign Extend, three-state outputs
74323: 8-bit Bidirectional Universal Shift/Storage Register with three-state outputs
74324: Voltage Controlled Oscillator (or Crystal Controlled)
74340: Octal Buffer with Schmitt trigger inputs and three-state inverted outputs
74341: Octal Buffer with Schmitt trigger inputs and three-state noninverted outputs
74344: Octal Buffer with Schmitt trigger inputs and three-state noninverted outputs
74348: 8 to 3-line Priority Encoder with three-state outputs
74350: 4-bit Shifter with three-state outputs
74351: Dual 8-line to 1-line Data Selectors/Multiplexers with three-state outputs and 4 Common Data Inputs
74352: Dual 4-line to 1-line Data Selectors/Multiplexers with Inverting Outputs
74353: Dual 4-line to 1-line Data Selectors/Multiplexers with Inverting three-state outputs
74354: 8 to 1-line Data Selector/Multiplexer with Transparent Latch, three-state outputs
74356: 8 to 1-line Data Selector/Multiplexer with Edge-Triggered Register, three-state outputs
74361: Bubble memory function timing generator
74362: Four-Phase Clock Generator/Driver (aka TIM9904)
74365: Hex Buffer with Noninverted three-state outputs
74366: Hex Buffer with Inverted three-state outputs
74367: Hex Buffer with Noninverted three-state outputs
74368: Hex Buffer with Inverted three-state outputs
74370: 2048-bit (512x4) Read-only memory with three-state outputs
74371: 2048-bit (256x8) Read-only memory with three-state outputs
74373: Octal Transparent Latch with three-state outputs
74374: Octal Register with three-state outputs
74375: Quad Bistable Latch
74376: Quad J-Not-K Flip-flop with Common Clock and Common Clear
74377: 8-bit Register with Clock Enable
74378: 6-bit Register with Clock Enable
74379: 4-bit Register with Clock Enable and Complementary Outputs
74380: 8-bit Multifunction Register
74381: 4-bit Arithmetic Logic Unit/Function Generator with Generate and Propagate Outputs
74382: 4-bit Arithmetic Logic Unit/Function Generator with Ripple Carry and Overflow Outputs
74385: Quad 4-bit Adder/Subtractor
74386: Quad 2-Input XOR gate
74387: 1024-bit (256x4) Programmable read-only memory with open collector outputs
74388: 4-bit Register with Standard and Three-state Outputs (74LS388 is equivalent to AMD Am25LS2518 , functional equivalent to Am2918 and Am25S18)
74390: Dual 4-bit Decade Counter
74393: Dual 4-bit Binary Counter
74395: 4-bit Universal Shift register with three-state outputs
74398: Quad 2-input Multiplexers with Storage and Complementary Outputs
74399: Quad 2-input Multiplexer with Storage
74408: 8-bit Parity Tree
74412: Multi-Mode Buffered 8-bit Latches with three-state outputs and Clear (74S412 is equivalent to Intel 8212, TI TIM8212)
74423: Dual Retriggerable Monostable Multivibrator
74424: Two-Phase Clock Generator/Driver (74LS424 is equivalent to Intel 8224, TI TIM8224)
74425: Quad Gates with three-state outputs and Active Low Enables
74426: Quad Gates with three-state outputs and Active High Enables
74428: System Controller for 8080A (74S428 is equivalent to Intel 8228, TI TIM8228)
74438: System Controller for 8080A (74S438 is equivalent to Intel 8238, TI TIM8238)
74440: Quad Tridirectional Bus Transceiver with Noninverted open collector outputs
74441: Quad Tridirectional Bus Transceiver with Inverted open collector outputs
74442: Quad Tridirectional Bus Transceiver with Noninverted three-state outputs
74443: Quad Tridirectional Bus Transceiver with Inverted three-state outputs
74444: Quad Tridirectional Bus Transceiver with Inverted and Noninverted three-state outputs
74448: Quad Tridirectional Bus Transceiver with Inverted and Noninverted open collector outputs
74450: 16-to-1 Multiplexer with Complementary Outputs
74451: Dual 8-to-1 Multiplexer
74452: Dual Decade Counter, Synchronous
74453: Dual Binary Counter, Synchronous (Motorola, "plain" TTL)
74453: Quad 4-to-1 Multiplexer
74454: Dual Decade Up/Down Counter, Synchronous, Preset Input
74455: Dual Binary Up/Down Counter, Synchronous, Preset Input
74456: NBCD (Natural Binary Coded Decimal) Adder
74460: Bus Transfer Switch
74461: 8-bit Presettable Binary Counter with three-state outputs
74462: Fiber-Optic Link Transmitter
74463: Fiber-Optic Link Receiver
74465: Octal Buffer with three-state outputs
74468: Dual MOS-to-TTL Level Converter
74470: 2048-bit (256x8) Programmable read-only memory with open collector outputs
74471: 2048-bit (256x8) Programmable read-only memory with three-state outputs
74472: Programmable read-only memory with open collector outputs
74473: Programmable read-only memory with three-state outputs
74474: Programmable read-only memory with open collector outputs
74475: Programmable read-only memory with three-state outputs
74481: 4-bit Slice Processor Elements
74482: 4-bit Slice Expandable Control Elements
74484: BCD-to-Binary Converter (mask programmed SN74S371 ROM)
74485: Binary-to-BCD Converter (mask programmed SN74S371 ROM)
74490: Dual Decade Counter
74491: 10-bit Binary Up/Down Counter with Limited Preset and three-state logic outputs
74498: 8-bit Bidirectional Shift Register with Parallel Inputs and three-state outputs
74508: 8-bit Multiplier/Divider
74520: 8-bit Comparator - as 74521 but with different input circuit
74521: 8-bit Comparator
74526: Fuse Programmable Identity Comparator, 16 Bit
74527: Fuse Programmable Identity Comparator, 8 Bit + 4 Bit conventional Identity Comparator
74528: Fuse Programmable Identity Comparator, 12 Bit
74531: Octal Transparent Latch with 32 mA three-state outputs
74532: Octal Register with 32 mA three-state outputs
74533: Octal Transparent Latch with Inverting Three-state logic outputs
74534: Octal Register with Inverting three-state outputs
74535: Octal Transparent Latch with Inverting three-state outputs
74536: Octal Register with Inverting 32 mA three-state outputs
74537: BCD to Decimal Decoder with three-state outputs
74538: 1 of 8 Decoder with three-state outputs
74539: Dual 1 of 4 Decoder with three-state outputs
74540: Inverting Octal Buffer with three-state outputs
74541: Non-inverting Octal Buffer with three-state outputs
74558: 8-Bit by 8-Bit Multiplier with three-state outputs
74560: 4-bit Decade Counter with three-state outputs
74561: 4-bit Binary Counter with three-state outputs
74563: 8-bit D-Type Transparent Latch with Inverting three-state outputs
74564: 8-bit D-Type Edge-Triggered Register with Inverting three-state outputs
74568: Decade Up/Down Counter with three-state outputs
74569: Binary Up/Down Counter with three-state outputs
74573: Octal D-Type Transparent Latch with three-state outputs
74574: Octal D-Type Edge-Triggered Flip-flop with three-state outputs
74575: Octal D-Type Flip-Flop with Synchronous Clear, three-state outputs
74576: Octal D-Type Flip-Flop with inverting three-state outputs
74577: Octal D-Type Flip-Flop with Synchronous Clear, inverting three-state outputs
74580: Octal Transceiver/Latch with inverting three-state outputs
74589: 8-bit Shift Register with Input Latch, three-state outputs
74590: 8-Bit Binary Counter with Output Registers and three-state outputs
74592: 8-Bit Binary Counter with Input Registers
74593: 8-Bit Binary Counter with Input Registers and three-state outputs
74594: Serial-in Shift register with Output Registers
74595: Serial-in Shift register with Output Latches
74596: Serial-in Shift register with Output Registers and open collector outputs
74597: Serial-out Shift register with Input Latches
74598: Shift register with Input latches
74600: Dynamic Memory Refresh Controller, Transparent and Burst Modes, for 4K or 16K DRAMs (74LS600 is equivalent to TI TIM99600)
74601: Dynamic Memory Refresh Controller, Transparent and Burst Modes, for 64K DRAMs (74LS601 is equivalent to TI TIM99601)
74602: Dynamic Memory Refresh Controller, Cycle Steal and Burst Modes, for 4K or 16K DRAMs (74LS602 is equivalent to TI TIM99602)
74603: Dynamic Memory Refresh Controller, Cycle Steal and Burst Modes, for 64K DRAMs (74LS603 is equivalent to TI TIM99603)
74604: Octal 2-input Multiplexer with Latch, High-Speed, with Three-state outputs (74LS604 is equivalent to TI TIM99604)
74605: Octal 2-input Multiplexer with Latch, High-Speed, with open collector outputs (74LS605 is equivalent to TI TIM99605)
74606: Octal 2-input Multiplexer with Latch, Glitch-Free, with Three-state outputs (74LS606 is equivalent to TI TIM99606)
74607: Octal 2-input Multiplexer with Latch, Glitch-Free, with open collector outputs (74LS607 is equivalent to TI TIM99607)
74608: Memory Cycle Controller (74LS608 is equivalent to TI TIM99608)
74610: Memory Mapper, Latched, Three-state Outputs (74LS610 is equivalent to TI TIM99610)
74611: Memory Mapper, Latched, open collector outputs (74LS611 is equivalent to TI TIM99611)
74612: Memory Mapper, Three-state logic Outputs (74LS612 is equivalent to TI TIM99612)
74613: Memory Mapper, open collector outputs (74LS613 is equivalent to TI TIM99613)
74620: Octal Bus Transceiver, Inverting, Three-state Outputs
74621: Octal Bus Transceiver, Noninverting, open collector outputs
74622: Octal Bus Transceiver, Inverting, open collector outputs
74623: Octal Bus Transceiver, Noninverting, Three-state outputs
74624: Voltage-Controlled Oscillator with Enable Control, Range Control, Two-Phase Outputs
74625: Dual Voltage-Controlled Oscillator with Two-Phase Outputs
74626: Dual Voltage-Controlled Oscillator with Enable Control, Two-Phase Outputs
74627: Dual Voltage-Controlled Oscillator
74628: Voltage-Controlled Oscillator with Enable Control, Range Control, External Temperature Compensation, and Two-Phase Outputs
74629: Dual Voltage-Controlled Oscillator with Enable Control, Range Control
74630: 16-bit Error Detection and Correction (EDAC) with three-state outputs
74631: 16-bit Error Detection and Correction (EDAC) with open collector outputs
74632: 32-bit Error Detection and Correction (EDAC)
74638: Octal Bus Transceiver with Inverting three-state outputs
74639: Octal Bus Transceiver with Noninverting three-state outputs
74640: Octal Bus Transceiver with Inverting three-state outputs
74641: Octal Bus Transceiver with Noninverting open collector outputs
74642: Octal Bus Transceiver with Inverting open collector outputs
74643: Octal Bus Transceiver with Mix of Inverting and Noninverting three-state outputs
74644: Octal Bus Transceiver with Mix of Inverting and Noninverting open collector outputs
74645: Octal Bus Transceiver
74646: Octal Bus Transceiver/Latch/Multiplexer with Noninverting three-state outputs
74647: Octal Bus Transceiver/Latch/Multiplexer with Noninverting open collector outputs
74648: Octal Bus Transceiver/Latch/Multiplexer with Inverting three-state outputs
74649: Octal Bus Transceiver/Latch/Multiplexer with Inverting open collector outputs
74651: Octal Bus Transceiver/Register with Inverting three-state outputs
74652: Octal Bus Transceiver/Register with Noninverting three-state outputs
74653: Octal Bus Transceiver/Register with Inverting three-state and open collector outputs
74654: Octal Bus Transceiver/Register with Noninverting three-state and open collector outputs
74658: Octal Bus Transceiver with Parity, Inverting
74659: Octal Bus Transceiver with Parity, Noninverting
74664: Octal Bus Transceiver with Parity, Inverting
74665: Octal Bus Transceiver with Parity, Noninverting
74668: Synchronous 4-bit Decade Up/Down Counter
74669: Synchronous 4-bit Binary Up/Down Counter
74670: 4 by 4 Register File with three-state outputs
74671: 4-bit Bidirectional Shift register/Latch /Multiplexer with three-state outputs
74672: 4-bit Bidirectional Shift register/Latch/Multiplexer with three-state outputs
74673: 16-bit Serial-in Serial-Out Shift register with Output Storage Registers, three-state outputs
74674: 16-bit Parallel-in Serial-out Shift register with three-state outputs
74677: 16-bit Address Comparator with Enable
74678: 16-bit Address Comparator with Latch
74679: 12-bit Address Comparator with Latch
74680: 12-bit Address Comparator with Enable
74681: 4-bit Parallel Binary Accumulator
74682: 8-bit Magnitude Comparator
74683: 8-bit Magnitude Comparator with open collector outputs
74684: 8-bit Magnitude Comparator
74685: 8-bit Magnitude Comparator with open collector outputs
74686: 8-bit Magnitude Comparator with Enable
74687: 8-bit Magnitude Comparator with Enable
74688: 8-bit Equality Comparator
74689: 8-bit Magnitude Comparator with open collector outputs
74690: 4-bit Decimal Counter/Latch/Multiplexer with Asynchronous Reset, Three-State Outputs
74691: 4-bit Binary Counter/Latch/Multiplexer with Asynchronous Reset, Three-State Outputs
74692: 4-bit Decimal Counter/Latch/Multiplexer with Synchronous Reset, Three-state Outputs
74693: 4-bit Binary Counter/Latch/Multiplexer with Synchronous Reset, Three-state Outputs
74694: 4-bit Decimal Counter/Latch/Multiplexer with Synchronous and Asynchronous Resets, three-state outputs
74695: 4-bit Binary Counter/Latch/Multiplexer with Synchronous and Asynchronous Resets, three-state outputs
74696: 4-bit Decimal Counter/Register/Multiplexer with Asynchronous Reset, three-state outputs
74697: 4-bit Binary Counter/Register/Multiplexer with Asynchronous Reset, three-state outputs
74698: 4-bit Decimal Counter/Register/Multiplexer with Synchronous Reset, three-state outputs
74699: 4-bit Binary Counter/Register/Multiplexer with Synchronous Reset, three-state outputs
74716: Programmable Decade Counter (74LS716 is equivalent to Motorola MC4016)
74718: Programmable Binary Counter (74LS718 is equivalent to Motorola MC4018)
74724: Voltage Controlled Multivibrator
74740: Octal Buffer/Line Driver, Inverting, three-state outputs
74741: Octal Buffer/Line Driver, Noninverting, three-state outputs, Mixed enable polarity
74744: Octal Buffer/Line Driver, Noninverting, three-state logic outputs
74748: 8 to 3-line priority encoder
74779: 8-bit bidirectional binary counter (3-State)
74783: Synchronous Address Multiplexer (74LS783 is equivalent to Motorola MC6883)
74790: Error Detection and Correction (EDAC)
74794: 8-Bit Register with Readback
74795: Octal Buffer with Three-state logic outputs (74LS795 is equivalent to 81LS95)
74796: Octal Buffer with Three-state logic outputs (74LS796 is equivalent to 81LS96)
74797: Octal Buffer with Three-state logic outputs (74LS797 is equivalent to 81LS97)
74798: Octal Buffer with Three-state logic outputs (74LS798 is equivalent to 81LS98)
74804: Hex 2-input NAND Drivers
74805: Hex 2-input NOR Drivers
74808: Hex 2-input AND Drivers
74832: Hex 2-input OR Drivers
74848: 8 to 3-line Priority Encoder with three-state outputs
74873: Octal Transparent Latch
74874: Octal D-Type Flip-flop
74876: Octal D-Type Flip-flop with Inverting Outputs
74878: Dual 4-bit D-Type Flip-flop with Synchronous Clear, Noninverting three-state outputs
74879: Dual 4-bit D-Type Flip-flop with Synchronous Clear, Inverting three-state outputs
74880: Octal Transparent Latch with Inverting Outputs
74882: 32-bit Lookahead Carry Generator
74888: 8-bit Slice Processor
74926: 4-digit counter/display driver
74935: 3.5-digit Digital Voltmeter (DVM) support chip for Multiplexed 7-segment displays (MM74C935 = ADD3501CCN)
74936: 3.75-digit Digital Voltmeter (DVM) support chip for Multiplexed 7-segment displays (MM74C936 = ADD3701CCN)
741005: hex inverting buffer with open-collector output
741035: hex noninverting buffers with open-collector outputs
742960: Error Detection and Correction (EDAC) (74F2960 is equivalent to AMD Am2960)
742961: EDAC Bus Buffer, Inverting
742962: EDAC Bus Buffer, Noninverting
742968: Dynamic Memory Controller
742969: Memory Timing Controller for use with EDAC
742970: Memory Timing Controller for use without EDAC
744002: Dual 4-Input NOR gate
744015: Dual 4-bit shift registers
744017: 5-Stage ÷10 Johnson Counter
744020: 14-stage binary counter
744024: 7 Stage Ripple Carry Binary Counter
744028: BCD to Decimal Decoder
744040: 12-stage binary ripple counter
744046: Phase-locked loop and voltage-controlled oscillator
744049: Hex Inverting Buffer
744050: Hex buffer/converter (non-inverting)
744051: High-Speed CMOS Logic 8-Channel Analog Multiplexer/Demultiplexer
744052: Dual 4-Channel Analog Multiplexer/Demultiplexers
744053: Triple 2-Channel Analog Multiplexer/Demultiplexers
744059: Programmable Divide-by-N Counter
744060: 14-stage binary ripple counter with oscillator
744066: Quad bilateral switches
744067: 16-Channel Analog Multiplexer/Demultiplexer
744075: Triple 3-input OR gate
744078: 8-Input OR/NOR gate
744094: 8-bit Three-state Shift Register/Latch
744316: Quad analog switch
744511: BCD to 7-Segment Decoder
744520: Dual 4-bit Synchronous Binary Counter
744538: Dual Retriggerable Precision Monostable Multivibrator
747007: hex buffer (like 7407, however push-pull outputs)
747266: Quad 2-input XNOR gate (Exclusive NOR, Equivalence test)
7429841: 10-bit bus-interface D-type latch with 3-state outputs
7440103: Presettable 8-bit Synchronous Down Counter
7440105: 4-bit by 16-word FIFO register
7400 series integrated circuits list
