Two TickTackToe questions....
Trebor29
Post by Trebor29 » Sun Nov 21, 2010 6:29 pm
Hi,
Im making a TickTackToe game in Visual Studio 2010, C# / .NET -
Has anyone got an idea as to what I can write to make the form resize based on the selected grid size... button size is 50px / space between buttons is 10px... so form needs to resize 60px for every button created .Left and .Top
The form loads at 400 x 400, and I can get it to resize but it either goes smaller :? or massive, taking over my 2 screens and can't seem to be able to tweek it just right! :? Also, Ive put the code inside the button's 'for' loop, thinking I want it to grow with the buttons..!! although thinking about it.. its running that code every time it goes through the loop :!: humm, is this right? or should it be outside the 'for' loop?
Another problem is that when I get it to resize, the groupBox doen't resize, so hiding the buttons anyway!
The other thing was: Where I am selecting a button Image when ButtonClicked, it is not showing the second image on the second clickedButton, but when using clickedButton.Text ("X" "O") it worked fine! :roll: The buttons start with no image so is the 'null' value ive used correct? previously it was clickedButton.Text == " ";
Here's the code, problem areas marked as: ?????? :-S
Thank u :D
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Media;
namespace TickTackToe
    public partial class frmTickTackToe : Form
        public frmTickTackToe()
            InitializeComponent();
        private void frmTickTackToe_Load(object sender, EventArgs e)
            cboGridWidth.SelectedIndex = 0;
        private void btnStart_Click(object sender, EventArgs e)
            int grid1 = int.Parse(cboGridWidth.Text);
            //int grid2 = int.Parse(cboGridHeight.Text);
            Button[,] tickTackButton = new Button[grid1, grid1];
            for (int i = 0; i < grid1; i++)
                for (int x = 0; x < grid1; x++)
                    tickTackButton[i, x] = new Button();
                    tickTackButton[i, x].Name = "tickTackButton" + i + ", " + x;
                    tickTackButton[i, x].Width = 50;
                    tickTackButton[i, x].Height = 50;
                    tickTackButton[i, x].Left = tickTackButton[i, x].Left + tickTackButton[i, x].Width + (i * 60);
                    tickTackButton[i, x].Top = tickTackButton[i, x].Top + tickTackButton[i, x].Top + 50 + (x * 60);
                    tickTackButton[i, x].Text = " ";
                    gbxButtons.Controls.Add(tickTackButton[i, x]);
                    tickTackButton[i, x].Click += new EventHandler(Button_Click);
                    frmTickTackToe.ActiveForm.Size = new System.Drawing.Size(400, 400);
                    frmTickTackToe.ActiveForm.Width = frmTickTackToe.ActiveForm.Width; // ????? :-S
                    frmTickTackToe.ActiveForm.Height = frmTickTackToe.ActiveForm.Height; /// ????? :-S
        private void Button_Click(object sender, EventArgs e)
            SoundPlayer[] sounds = new SoundPlayer[3]; // created soundplayer array of 3 .wav sounds.
            Random random = new Random(); // creates a new random to play sounds randomly.
            sounds[0] = new SoundPlayer(@"C:\Users\ROB\Desktop\OO Programing\TickTackToe\TickTackToe\bin\Debug\sounds\1.wav");
            sounds[1] = new SoundPlayer(@"C:\Users\ROB\Desktop\OO Programing\TickTackToe\TickTackToe\bin\Debug\sounds\2.wav");
            sounds[2] = new SoundPlayer(@"C:\Users\ROB\Desktop\OO Programing\TickTackToe\TickTackToe\bin\Debug\sounds\3.wav");
            sounds[random.Next(0, 3)].Play(); //
            Button clickedButton = (Button)sender;
            string index = clickedButton.Name.Substring("tickTackButton".Length);
            string targetTextBox = "tickTackButton" + index;
            int myIndex = gbxButtons.Controls.IndexOfKey(targetTextBox);
            Image[] playerImage = new Image[2];
            playerImage[0] = Image.FromFile(@"C:\Users\ROB\Desktop\OO Programing\TickTackToe\TickTackToe\bin\Debug\sounds\A.png");
            playerImage[1] = Image.FromFile(@"C:\Users\ROB\Desktop\OO Programing\TickTackToe\TickTackToe\bin\Debug\sounds\B.png");
            if (myIndex != -1)
                //MessageBox.Show(index);
                if (clickedButton.Image == null) // ?????? :-S
                    clickedButton.Image = playerImage[0];
                if (clickedButton.Image == playerImage[0])
                    clickedButton.Image = playerImage[1];
                if (clickedButton.Image == playerImage[1])
        private void btnNewGame_Click(object sender, EventArgs e)
            gbxButtons.Controls.Clear();
Re: Two TickTackToe questions....
Post by Neo » Sun Nov 21, 2010 10:59 pm
Enough to have,
frmTickTackToe.ActiveForm.Size = new System.Drawing.Size(x, y);
Also, it should come after the loop. No point in running this for every button.
x = number_of_buttons * width_of_a_button + constant_horizontal_margins;
y = number_of_buttons * height_of_a_button + constant_vertical_margins;
To be sure, we can set tickTackButton[i, x].Image = null; within the for loop after tickTackButton[i, x].Text = " ";.
Trebor29
Post by Trebor29 » Mon Nov 22, 2010 3:42 am
Ive sorted the form resize :D by multiplying the comboBox.SelectedIndex by button size and space between the buttons.... so.... (Button 50px & space 10px)=
            //gbxButtons.Size = gbxButtons + cboGridWidth.SelectedIndex * 60; << Not working!
            frmTickTackToe.ActiveForm.Width = frmTickTackToe.ActiveForm.Width + (cboGridWidth.SelectedIndex * 60);
            frmTickTackToe.ActiveForm.Height = frmTickTackToe.ActiveForm.Height + (cboGridWidth.SelectedIndex * 60);
Cant believe it, ive just been doing that in other applications for another assignment as well!! Cant resize the groupBox now though, lol.. getting an error "Operator '+' cannot be applied to operands of type 'System.Windows.Forms.GroupBox' and 'int'" - Love it.. lol :mrgreen:
When I Debug the program and go through the clickedButton.Image == playerImage[], it reads the first 'if null' and outputs the correct image but then fails to read through the other 'if's', skipping straight to the end of 'if (myIndex != -1)' and continues to fail to read any when going through the program again and again!
Post by Neo » Mon Nov 22, 2010 9:28 am
According to what I see, this code is wrong. This will keep on increasing the size of the form rather than adjusting it to fit the set of buttons.
For example:
say initial width=400, height=400
first run with 3x3 buttons,
height = width = 400 + 60x3 = 580
second run with 5x5 buttons,
height = width = 580 + 60x5 = 880 which should be 400 + 60x5 = 700
I think you are clear on the problem. To fix that, you need to use a fix initial size.
See my code in previous post,
So this will become as below for you (I use 100 as the constant margin),
x = (cboGridWidth.SelectedIndex * 60) + 100;
y = (cboGridWidth.SelectedIndex * 60) + 100;
This should work for you. Make sure you adjust the value 100 as required for you.
frmTickTackToe.ActiveForm.Size = new System.Drawing.Size((cboGridWidth.SelectedIndex * 60) + 100, (cboGridWidth.SelectedIndex * 60) + 100);
Similarly for Group Box,
Note that I have used 20 as the fixed margin. You need to change that to suit your layout.
gbxButtons.Size = new System.Drawing.Size((cboGridWidth.SelectedIndex * 60) + 20, (cboGridWidth.SelectedIndex * 60) + 20);
Trebor29
Post by Trebor29 » Mon Nov 22, 2010 7:11 pm
aaahhhh Neo... bursting my bubble! :lol:
Your code does work better than mine, but I still need to make the (100 margin) 400.. which seems to make it very similar. Any smaller than 400 just shrinks the form.
Not sure about (Width = Height = 400 + 60*3 = 580), doesn't this say the buttons are added on to the end of the form size 400? The form loads at 400 x 400 and the buttons 3x3 appear inside the 400 x 400. The numbers in the comboBox start at 3 (meaning 3 x 3).... through to 10 (10 x 10).
Have I missed something? :? Is there a way I can show you it running?
Post by Neo » Mon Nov 22, 2010 8:19 pm
To be sure, lets discuss base don an image.
Now we can write simple formulas for Group box width and height as below. Note that draw position of the left-top button is (a1, b1).
N - number_of_buttons_per_side
gbox_width = a1 + a2 + (p1 * N) + p2 * (N-1)
gbox_height = b1 + b2 + (q1 * N) + q2 * (N-1)
Similarly, we can write formulas for form,
form_width = w1 + w2 + gbox_width
form_height = h1 + h2 + gbox_height
Note: p1, p2, q1, q2, (a1 + a2), (b1 + b2), (w1 + w2) and (h1 + h2) are all constants.
These values will change for given N from your combo box.
Can you implement this, so the logic will become clear?
Trebor29
Post by Trebor29 » Mon Nov 22, 2010 8:55 pm
:shock: I maybe some time with this...! :)
