TWO PASS ENCODING TO H264 MP4 USING FFMPEG
now batch deletes the first encode without qt faststart
@ ECHO OFF
REM The following will convert all avi files in the current folder into mp4 files.
IF EXIST *.avi FOR %%A IN (*.avi) DO CALL :twopass "%%A"
:twopass
D:\server\encoder\ffmpeg.exe -y -i %* -b 2M -bt 4M -vcodec libx264 -pass 1 -fpre "D:\server\encoder\ffpresets\libx264-veryfast_firstpass.ffpreset" -s 640x360 -b 1000kbps -bt 800kbps -threads 4 output.mp4
D:\server\encoder\ffmpeg.exe -y -i %* -b 2M -bt 4M -vcodec libx264 -pass 2 -fpre "D:\server\encoder\ffpresets\libx264-veryfast.ffpreset" -s 640x360 -b 1000kbps -bt 800kbps -threads 4 output.mp4
RENAME output.mp4 %*.mp4
:QT Faststart
D:\server\encoder\qt-faststart.exe %*.mp4 %*.qt.mp4
:GET Thumbs
D:\server\encoder\ffmpeg.exe -v 0 -y -i %* -vframes 1 -ss 5 -vcodec mjpeg -f rawvideo -s 286x160 -aspect 16:9 %*.qt_mp4.jpg
ECHO Y | DEL %*.mp4
ECHO.
GOTO :EOF
ffmpeg Link ---- http://ffmpeg.arrozcru.org/builds/
qt faststart --- http://notboring.org/devblog/2009/07/qt ... r-windows/
remember to change the path to your ffmpeg and qt faststart exe
C:\location of \qt-faststart.exe
that's it
example info of a encoded file
General
Complete name : D:\server\xampp\htdocs\files\UFO Files - Alien Encounters.divx.qt.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 89.4 MiB
Duration : 45mn 5s
Overall bit rate : 277 Kbps
Encoded date : UTC 1970-01-01 00:00:00
Tagged date : UTC 1970-01-01 00:00:00
Writing application : Lavf52.61.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 45mn 5s
Bit rate mode : Variable
Bit rate : 200 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16/9
Frame rate mode : Variable
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.029
Stream size : 64.5 MiB (72%)
Writing library : x264 core 85 r1442 781d300
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=200 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.41 / pb_ratio=1.25 / aq=1:1.00
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 45mn 5s
Bit rate : 72.0 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 22.8 MiB (26%)
everything inside the zip is updated
File Size: 47.54 MB
http://www.mediafire.com/?yg1zznamdmm
