How to get Google PageRank using php
Post by Neo » Sat Mar 13, 2010 4:56 pm
Step 1: Download following zip file that contain required files from popstats
PageRank.zip
(3.64 KiB) Downloaded 513 times
Step 2: Now you can use call Google PageRank as below.
require_once("google_pagerank.class.php");
$rankObject = new GooglePageRank("http://www.yourdomain.com/");
$pageRank = $rankObject->pagerank;
echo $pageRank;
The class also supports result caching on the local machine, so if a second query arrives within the cache time limit the result saved in the local file is returned rather then going out and querying Google.
The ‘GooglePageRank’ class accepts cache time as a second parameter. So if you want to cache the result for 6 hours you set the second parameter for 21600 seconds (6 * 60 * 60):
$rankObject = new GooglePageRank("http://www.yourdomain.com/", 21600);
The default is set to 24 hours, which is more then adequate for most purposes.
Return to “PHP & MySQL”
