while
while(expr) {
// do stuff
} - Evaluate expr
- If expr false, skip to 5
- Run code
- Repeat at 1
- End loop
// Prints 1 through 20
$i = 1;
while($i <= 20) {
echo $i++;
// Prints the value of the 'foo' column for each row in the result
while($row = mysql_fetch_assoc($result)) {
echo $row['foo'];
// Runs forever until a break statement is executed
// (be careful with this)
while(true) {
// do stuff
do {
// do stuff
} while(expr); - Run code
- Evaluate expr
- If expr true, repeat at 1
- End loop
$i = 1;
do {
echo $i++;
} while($i < 20);
do {
// do stuff
} while(true); Code: Select all
for(expr1; expr2; expr3) {
// do stuff
} - Execute expr1
- Evaluate expr2
- If expr2 false, skip to 7
- Run code
- Execute expr3
- Repeat at 2
- End loop
The first expression (expr1) runs once before the loop starts, so it is often used to initialize variables. The second expression (expr2) is evaluated before each loop, and ends the loop if evaluated to false. The third expression (expr3) runs after each loop, and is often used to increment/decrement a variable. Below are some examples.
// Prints 1 through 99
for($i = 1; $i < 100; $i++) {
echo $i;
// Prints each item in an array
// note the $size is calculated only once to save performance
for($i = 0, $size = sizeof($array); $i < $size; $i++) {
echo $array[$i];
// Example omitting the second expression
for($i = 0; ; $i++) {
if($i > 99) {
break;
echo $i;
} Code: Select all
// Example 1
foreach($array as $value) {
// do stuff
// Example 2
foreach($array as $key => $value) {
// do stuff
// Example 3 (PHP 5)
foreach($array as &$value) {
// do stuff
} If you use the above Example 1, $value will contain a copy of the current array element's value.
Using the above Example 2, $key will contain the current element's key and $value will contain a copy of the current element's value.
Using Example 3, available as of PHP 5, $value will be a reference to the current element, and changing it within the loop will alter the original array.
// This array will be used in all examples
$array = array('foo', 'bar', 'baz');
// Prints each array element
echo $value;
// Change each element to uppercase
$array[$key] = strtoupper($value);
// Change each element to lowercase (using reference)
$value = strtolower($value);
} These two control structures do not create loops, but they are used to control the execution of loops. The break statement is used to force the loop to exit entirely. The continue statement causes the loop to stop the current iteration and skip to the next iteration. Both of these can accept a numeric argument to determine how many levels of nested loop structures to break or continue. Below are some examples.
// Stops the loop
while(true) {
break;
// Skip all empty array items
if(empty($value)) {
continue;
// do stuff
// Stops the outer loop (2nd level up)
while(1) {
while(true) {
break 2;
} This was a basic overview to loop structures in PHP. There is actually not much to them, yet they are so useful and powerful. Please comment if you have any suggestions for improvements or areas not covered.
