BUY USING A SOFTWARE.?
OR ANY OTHER ALTERNATIVE?
G-sparkZ
What are the Best virtual Memory values for Windows XP? I have a 1GB RAM In My system.Neo wrote:When it comes to modern operating systems, memory is defined as a collection of electronic chips and some pre-allocated disk space. This disk space is called Virtual memory. The OS used to store idle processes on virtual memory and when one needs to run, the kernel loads it to main memory from virtual memory.
So adding a USB pen as virtual memory will give the opportunity for the kernel to free up some memory from RAM so other programs can acquire freed up RAM and run faster. Adding enough virtual memory will make your system run faster. But it is not speed as if you add real RAM chips.
