function returnMacAddress() {
/* This code is under the GNU Public Licence
Written by michael_stankiewicz {don't spam} at yahoo {no spam} dot com
Tested only on linux, please report bugs */
// WARNING: the commands 'which' and 'arp' should be executable by the Apache us
// Get the arp executable path
$location = `which arp`;
// Execute the arp command and store the output in $arpTable
$arpTable = `$location`;
// Split the output so every line is an entry of the $arpSplitted array
$arpSplitted = split("\n",$arpTable);
// Get the remote ip address (the ip address of the client, the browser)
$remoteIp = $GLOBALS['REMOTE_ADDR'];
// Cicle the array to find the match with the remote ip address
foreach ($arpSplitted as $value) {
// Split every arp line, this is done in case the format of the arp
// command output is a bit different than expected
$valueSplitted = split(" ",$value);
foreach ($valueSplitted as $spLine) {
if (preg_match("/$remoteIp/",$spLine)) {
$ipFound = true;
// The ip address has been found, now rescan all the string
// to get the mac address
if ($ipFound) {
// Rescan all the string, in case the mac address, in the string
// returned by arp, comes before the ip address
// (you know, Murphy's laws)
reset($valueSplitted);
if (preg_match("/[0-9a-f][0-9a-f][:-]".
"[0-9a-f][0-9a-f][:-]".
"[0-9a-f][0-9a-f]/i",$spLine)) {
return $spLine;
$ipFound = false;
return false;
