Generating Keys
Generating public keys for authentication is the basic and most often used feature of ssh-keygen. ssh-keygen can generate both RSA and DSA keys. RSA keys have a minimum key length of 768 bits and the default length is 2048. When generating new RSA keys you should use at least 2048 bits of key length unless you really have a good reason for using a shorter and less secure key. The key length for DSA is always 1024 bits as specified in FIPS 186-2. Because DSA key length is limited to 1024, and RSA key length isn’t limited, so one can generate much stronger RSA keys than DSA keys, I prefer using RSA over DSA. Another reason for not using DSA is that DSA is a government standard and one may wonder if the key length was limited deliberately so it will be possible for government agencies to decrypt it.
To generate a pair of public and private keys execute the following command:
ssh-keygen -t rsa -b 2048After executing the command it may take some time to generate the keys (as the program waits for enough entropy to be gathered to generate random numbers). When the key generation is done you would be prompted to enter a filename in which the key will be saved. The public key will have the same filename but it will end with .pub. You should make sure that the key can only be read by you and not by any other user for security reasons.
Next you’ll be prompted to enter a passphrase. Each generated key can be protected by a passphrase. When a key is generated with a passphrase, the key can’t be used without the passphrase, so by using a passphrase one can prevent others from using his private keys without first guessing the passphrase. A good passphrase should be at least 10 characters long. One should stay away from English sentences as their entropy level is just too low to be used as a safe passphrase. I usually use a randomly generated passphrase, as this kind is considered the most secure. If you intend to use the key for accessing a remote machine from inside an automated script you may wish to enter an empty password, so the script won’t need user interaction. In this case just press <ENTER> twice.
If you create a passphrase-less key just make sure you only put it on trusted hosts as it may compromise the remote machine if the key falls to the wrong hands.
After entering you passphrase twice the program will print the key fingerprint, which is some kind of hashing used to distinguish different keys, followed by the default key comment (more on key comments later). After printing the key information the program will terminate. Congratulations, you’ve just created you own public key using ssh-keygen.
Comments
Adding comments to keys can allow you to organize your keys more easily. The comments are stored in end of the public key file and can be viewed in clear text. For example:
cat id_rsa2.pub
ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEAyyA8wePstPC69PeuHFtOwyTecByonsHFAjHbVnZ+h0dpomvLZxUtbknNj3+c7MPYKqKBOx9gUKV/diR/mIDqsb405MlrI1kmNR9zbFGYAAwIH/Gxt0Lv5ffwaqsz7cECHBbMojQGEz3IH3twEvDfF6cu5p00QfP0MSmEi/eB+W+h30NGdqLJCziLDlp409jAfXbQm/4Yx7apLvEmkaYSrb5f/pfvYv1FEV1tS8/J7DgdHUAWo6gyGUUSZJgsyHcuJT7v9Tf0xwiFWOWL9WsWXa9fCKqTeYnYJhHlqfinZRnT/+jkz0OZ7YmXo6j4Hyms3RCOqenIX1W6gnIn+eQIkw== This is the key's commentTo add a comment to the public key file when generating the key add to the key generation command -C "you comment". For example to generate 4048 bit RSA key with “home machine” as a comment you will do the following:
ssh-keygen -b 4048 -t rsa -C "home machine"Passphrases
Passphrases allow you to prevent unauthorized usage of your key by meaning of protecting the key itself by a password. Although your ssh directory holding the private keys should be unaccessible to other users, the root user of the system, or anyone who can achieve is privileges can access your key and copy it. In this case the passphrase will prevent him from using it.
To add a passphrase to a key just type it when prompted during the key generation process. Keep in mind that the password must be at least 5 characters long. A good passphrase, as I said before, should be at least 10 characters long, and consist of random upper and lower case letters, numbers and symbols.
While the passphrase boosts the security of the key, under some conditions you may want to leave it empty. Leaving the passphrase empty allows you to use the key from within scripts, for example to transfer a file via scp. While passphraseless keys are very useful for scripts just remember to only use them at trusted machines.
You can change the passphrase of key after it’s been created, and you should do it at least annually. To change the passphrase execute:
ssh-keygen -pEnd Notes
Feel free to share your public key, as its name suggests, it should be public. Keep in mind that your private key should be kept private. If someone gets hold of your private key, change it immediately, even if it’s passphrase protected.
