Auto IT
Auto IT
Post by Rksk » Tue Jan 26, 2010 4:58 pm
There is a very easy and useful scripting language, named AUTO IT.
It can be downloaded from www.autoitscript.com .
i will can help you to be a autoit programmer.
What we can do with Auto IT ?
Post by Rksk » Sat Mar 27, 2010 3:24 pm
There is an example to tell you "What we can do with AUTOIT?"
download this zip and extract this 2 files to a directory.
then run it with AUTOIT3 < http://www.autoitscript.com >
*you must set your screen resolution to 1024*768 or higher to run this correctly.
it will run MSpaint and draw a srilankan flag
with automated mouse movements and clicks.
But you can't modify this code because it is obfucated due to it is secret script.
There is the start of code.
you will can learn using it.
	ProcessClose("mspaint.exe")
		Opt("WinWaitDelay", 15)
		Opt("WinTitleMatchMode", 4)
		Opt("WinDetectHiddenText", 1)
		Opt("MouseCoordMode", 0)
		Opt("GUICloseOnESC", 1)
		RegDelete("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint")
		Sleep(100)
		RegWrite("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint\View", "BMPHeight", "REG_DWORD", "600")
		RegWrite("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint\View", "BMPWidth", "REG_DWORD", "800")
		RegWrite("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint\Text", "TypeFaceName", "REG_SZ", "System")
		RegWrite("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint\Text", "PointSize", "REG_DWORD", "14")
		RegWrite("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint\General-Summary", "ScreenCX", "REG_DWORD", "400")
		RegWrite("HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\Paint\General-Summary", "ScreenCY", "REG_DWORD", "300")
		Sleep(100)
		Run("mspaint.exe")
		Opt("WinTitleMatchMode", 2)
		WinWait("untitled - Paint", "Colors")
		If Not WinActive("untitled - Paint", "Colors") Then WinActivate("untitled - Paint", "Colors")
		WinSetTrans("untitled - Paint", "", 230)
		WinSetOnTop("untitled - Paint", "Colors", 1)
		WinWaitActive("untitled - Paint", "Colors")
    MouseMove(266, 403)
    MouseDown("left")
    MouseMove(1020, 737)
    MouseUp("left")
    MouseMove(38, 168)
    MouseDown("left")
    MouseUp("left")
    MouseMove(250, 115)
    MouseDown("left")
    MouseMove(827, 209)
    MouseUp("left")
    MouseMove(75, 703)
    MouseDown("left")
    MouseUp("left")
    MouseMove(300, 157)
    MouseDown("left")
    MouseUp("left")
    Send("This is only for learning purpose.")
    MouseMove(200, 392)
    MouseDown("left")
    MouseUp("left")
autoit.zip
(45.33 KiB) Downloaded 1110 times
Reason: Placed the attachement on the post using Place inline button
Re: Auto IT
Post by Neo » Sat Mar 27, 2010 8:52 pm
Interesting.... :) It is the first time that I heard of it thanks to our team mate RkskEkanayaka.
It's like an advanced batch processing script to me (kind of an advance .bat file)
Re: Auto IT
Post by Rksk » Sun Mar 28, 2010 12:43 am
But anyone hasn't downloaded the code yet.
Mr. neo pls test it yourself and tell what you think!
Re: Auto IT
Post by Neo » Sun Mar 28, 2010 12:56 am
Very sorry on that. I'm too busy these days and will do that as time permits.
Re: Auto IT
Post by Rksk » Sun Mar 28, 2010 12:58 am
Download AutoIT3 from here http://www.autoitscript.com/files/autoi ... -setup.exe
it is only 8MB !
CD tray controller
Post by Rksk » Mon Mar 29, 2010 10:32 am
There is an example code in AutoIT on CD tray controller.
After runnig this script, you will see a small bar on the Right corner of the screen. Move the moue point on to it. then you will see the window for controlling.
#include-once
#include <ButtonConstants.au3>
#include <GUIConstantsEx.au3>
#include <WindowsConstants.au3>
#include <Array.au3>
#include <GuiButton.au3>
#include <Timers.au3>
#include <StaticConstants.au3>
Opt('MustDeclareVars', 1)
Local $Button1, $Button2, $Button3, $Button4, $Button5, $btn1, $btn2, $btn3, $btn4, $btn5, $nMsg, $1, $2, $3, $4, $hi, $Form1, $romz, $1 = False, $2 = False, $3 = False, $4 = False, $5 = False
Local $Label1, $Label2, $Label3, $Label4, $Label5, $W, $Form,$Label, $a_mpos
$romz = DriveGetDrive("CDROM")
For $x = 1 To $romz[0]
	CDTray($romz[$x], "close")
Next
$W = @DesktopWidth - 200
up()
Func up()
$Form = GUICreate("Hidden", 116, 10, $W, 0, BitOR($WS_POPUP, $WS_BORDER, $DS_MODALFRAME), $WS_EX_TOPMOST)
$Label = GUICtrlCreateLabel("........", 2, 2,50, 10)
GUISetState(@SW_SHOW,$Form)
EndFunc
	While 1
	 $a_mpos = GUIGetCursorInfo($Form1)
	 If $a_mpos[4] = $Label Then
		 GUISetState(@SW_HIDE,$Form)
		 ExitLoop
		 EndIf
	WEnd
Switch $romz[0]
	Case "0"
		MsgBox(0, "Error", "No CD Drives Found")
		Exit
	Case "1"
		$1 = True
		$hi = 50
	Case "2"
		$2 = True
		$hi = 90
	Case "3"
		$3 = True
		$hi = 130
	Case "4"
		$4 = True
		$hi = 170
	Case "5"
		$5 = True
		$hi = 210
EndSwitch
_lb()
Func _lb()
	#Region ### START Koda GUI section ### Form=
	$Form1 = GUICreate("Form1", 116, $hi, $W, 0, BitOR($WS_POPUP, $WS_BORDER, $DS_MODALFRAME), $WS_EX_TOPMOST)
	Switch $romz[0]
		Case "0"
			Exit
		Case "1"
			$Button1 = GUICtrlCreateButton("Open (" & StringUpper($romz[1]) & ") ", 8, 16, 97, 25, 0)
			$Label1 = GUICtrlCreateLabel(DriveGetLabel($romz[1]), 8, 0, 100, 17, $SS_CENTER)
		Case "2"
			$Button2 = GUICtrlCreateButton("Open (" & StringUpper($romz[2]) & ") ", 8, 56, 97, 25, 0)
			$Label2 = GUICtrlCreateLabel(DriveGetLabel($romz[2]), 8, 40, 100, 17, $SS_CENTER)
		Case "3"
			$Button3 = GUICtrlCreateButton("Open (" & StringUpper($romz[3]) & ") ", 8, 96, 97, 25, 0)
			$Label3 = GUICtrlCreateLabel(DriveGetLabel($romz[3]), 8, 80, 100, 17, $SS_CENTER)
		Case "4"
			$Button4 = GUICtrlCreateButton("Open (" & StringUpper($romz[4]) & ") ", 8, 136, 97, 25, 0)
			$Label4 = GUICtrlCreateLabel(DriveGetLabel($romz[4]), 8, 120, 100, 17, $SS_CENTER)
		Case "5"
			$Button5 = GUICtrlCreateButton("Open (" & StringUpper($romz[5]) & ") ", 8, 176, 97, 25, 0)
			$Label5 = GUICtrlCreateLabel(DriveGetLabel($romz[5]), 8, 160, 100, 17, $SS_CENTER)
	EndSwitch
			DllCall("user32.dll", "int", "AnimateWindow", "hwnd", $Form1, "int", 1000, "long", 0x00040004);slide in from left
			GUISetState(@SW_SHOW, $Form1)
	#EndRegion ### END Koda GUI section ###
;~ 	_Timer_SetTimer($Form1, 1000, "_update()")
EndFunc   ;==>_lb
While 1
	$nMsg = GUIGetMsg()
	Switch $nMsg
		Case $GUI_EVENT_CLOSE
			Exit
		Case $Button1
			If $1 = True Or $2 = True Or $3 = True Or $4 = True Or $5 = True Then
				$btn1 = _GUICtrlButton_GetText($Button1)
				If $btn1 = "Close (" & $romz[1] & ") " Then
					CDTray($romz[1], "close")
					_GUICtrlButton_SetText($Button1, "Open (" & StringUpper($romz[1]) & ") ")
					$Label1 = GUICtrlCreateLabel("", 8, 0, 100, 17, $SS_CENTER)
				Else
					CDTray($romz[1], "open")
					_GUICtrlButton_SetText($Button1, "Close (" & StringUpper($romz[1]) & ") ")
				EndIf
			EndIf
		Case $Button2
			If $2 = True Or $3 = True Or $4 = True Or $5 = True Then
				$btn2 = _GUICtrlButton_GetText($Button2)
				If $btn2 = "Close (" & $romz[2] & ") " Then
					CDTray($romz[2], "close")
					_GUICtrlButton_SetText($Button2, "Open (" & StringUpper($romz[2]) & ") ")
					$Label2 = GUICtrlCreateLabel("", 8, 40, 100, 17, $SS_CENTER)
				Else
					CDTray($romz[2], "open")
					_GUICtrlButton_SetText($Button2, "Close (" & StringUpper($romz[2]) & ") ")
				EndIf
			EndIf
		Case $Button3
			If $3 = True Or $4 = True Or $5 = True Then
				$btn3 = _GUICtrlButton_GetText($Button3)
				If $btn3 = "Close (" & $romz[3] & ") " Then
					CDTray($romz[3], "close")
					_GUICtrlButton_SetText($Button2, "Open (" & StringUpper($romz[3]) & ") ")
					$Label3 = GUICtrlCreateLabel(""), 8, 80, 100, 17, $SS_CENTER)
				Else
					CDTray($romz[3], "open")
					_GUICtrlButton_SetText($Button2, "Close (" & StringUpper($romz[3]) & ") ")
				EndIf
			EndIf
		Case $Button4
			If $4 = True Or $5 = True Then
				$btn4 = _GUICtrlButton_GetText($Button4)
				If $btn4 = "Close (" & $romz[4] & ") " Then
					CDTray($romz[4], "close")
					_GUICtrlButton_SetText($Button2, "Open (" & StringUpper($romz[4]) & ") ")
					$Label4 = GUICtrlCreateLabel("", 8, 120, 100, 17, $SS_CENTER)
				Else
					CDTray($romz[4], "open")
					_GUICtrlButton_SetText($Button2, "Close (" & StringUpper($romz[4]) & ") ")
				EndIf
			EndIf
		Case $Button5
			If $5 = True Then
				$btn5 = _GUICtrlButton_GetText($Button5)
				If $btn5 = "Close (" & $romz[5] & ") " Then
					CDTray($romz[5], "close")
					_GUICtrlButton_SetText($Button2, "Open (" & StringUpper($romz[5]) & ") ")
					$Label5 = GUICtrlCreateLabel("", 8, 160, 100, 17, $SS_CENTER)
				Else
					CDTray($romz[5], "open")
					_GUICtrlButton_SetText($Button2, "Close (" & StringUpper($romz[5]) & ") ")
				EndIf
			EndIf
	EndSwitch
WEnd
Func _update()
EndFunc
A guid to learn Auto IT (01)
Post by Rksk » Mon Apr 05, 2010 5:12 pm
First we can study a simple automation script.
It Plays with the calculator.
There is the code with step by step descriptions.
if you have any question reply in this post.
; Script Function:
;   Plays with the calculator.
; Prompt the user to run the script - use a Yes/No prompt (4 - see help file)
$answer = MsgBox(4, "AutoIt Example (English Only)", "This script will run the calculator and type in 2 x 4 x 8 x 16 and then quit.  Run?")
; Check the user's answer to the prompt (see the help file for MsgBox return values)
; If "No" was clicked (7) then exit the script
If $answer = 7 Then
    MsgBox(0, "AutoIt", "OK.  Bye!")
    Exit
EndIf
; Run the calculator
Run("calc.exe")
; Wait for the calulator become active - it is titled "Calculator" on English systems
WinWaitActive("Calculator")
; Now that the calc window is active type 2 x 4 x 8 x 16
; Use AutoItSetOption to slow down the typing speed so we can see it :)
AutoItSetOption("SendKeyDelay", 400)
Send("2*4*8*16=")
Sleep(2000)
; Now quit by sending a "close" request to the calc
WinClose("Calculator")
; Now wait for calc to close before continuing
WinWaitClose("Calculator")
; Finished!
A guid to learn Auto IT (02)
Post by Rksk » Mon Apr 05, 2010 5:16 pm
My second example Plays with the notepad.
; Script Function:
;   Opens Notepad, types in some text and then quits.
$answer = MsgBox(4, "AutoIt Example (English Only)", "This script will run Notepad type in some text and then quit.  Run?")
If $answer = 7 Then
    Exit
EndIf
; Run Notepad
Run("notepad.exe")
; Wait for the Notepad become active - it is titled "Untitled - Notepad" on English systems
WinWaitActive("[CLASS:Notepad]")
; Now that the Notepad window is active type some text
Send("Hello from Notepad.{ENTER}1 2 3 4 5 6 7 8 9 10{ENTER}")
Sleep(500)
Send("+{UP 2}")
Sleep(500)
; Now quit by pressing Alt-f and then x (File menu -> Exit)
Send("!f")
Send("x")
; Now a screen will pop up and ask to save the changes, the window is called
; "Notepad" and has some text "Yes" and "No"
WinWaitActive("Notepad")
Send("n")
; Now wait for Notepad to close before continuing
WinWaitClose("[CLASS:Notepad]")
; Finished!
