How to hack a Satelite TV decoder
Post by Nipuna » Tue Jan 19, 2010 9:02 pm
help Please
Re: How to hack a Satelite TV decoder
Post by Neo » Tue Jan 19, 2010 9:07 pm
Specify the model number/brand of the decoding unit.
Post by Nipuna » Mon Feb 01, 2010 9:54 am
Neo wrote:Specify the model number/brand of the decoding unit.
how to find them?
Post by Neo » Mon Feb 01, 2010 1:53 pm
Should be on the back label of the unit. If there is no label specifying the model/brand, then it is not possible find them without opening the unit which will void warranty.
When you find them somehow, you need to Google that for any firmware update, etc... but I'm sure this is not easily possible and you won't get it for free if someone is capable of doing that :D
Post by Nipuna » Mon Feb 01, 2010 2:18 pm
I can find the Brand.
But it has a website here it is
http://www.technosat-uae.com/
Post by Neo » Mon Feb 01, 2010 2:27 pm
From the products menu, find the model you have and then do a Google search for what you require. If there is anything available, Google will find it. (As said before, I can't encourage you to do unethical things) :)
Post by Nipuna » Mon Feb 22, 2010 3:56 pm
Neo wrote:From the products menu, find the model you have and then do a Google search for what you require. If there is anything available, Google will find it. (As said before, I can't encourage you to do unethical things) :)
Is there a Common Software to Hack This?
Post by Neo » Mon Feb 22, 2010 6:02 pm
I don't think so. You may try google.
Post by Nipuna » Wed Mar 10, 2010 4:41 pm
I found this in Decoder's Menu -> CA Status
SoftCell: Ver 2.26C
Post by Neo » Wed Mar 10, 2010 5:27 pm
I was only able to find this forum on this. Not much valuable information on firmware upgrade, etc... However submit your question in that forum. They might able to help you.
