FFMPEG Command Line Arguments
Post by Neo » Wed Jan 13, 2010 1:35 pm
New Version
To get this help, enter ffmpeg -h for this version
FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  configuration: --enable-gpl --enable-postproc --enable-swscale --enable-avfilt
er --enable-avfilter-lavf --enable-pthreads --enable-avisynth --enable-libfaac -
-enable-libfaad --enable-libmp3lame --enable-libspeex --enable-libtheora --enabl
e-libvorbis --enable-libxvid --enable-libx264 --enable-memalign-hack
  libavutil     49.15. 0 / 49.15. 0
  libavcodec    52.20. 0 / 52.20. 0
  libavformat   52.31. 0 / 52.31. 0
  libavdevice   52. 1. 0 / 52. 1. 0
  libavfilter    0. 4. 0 /  0. 4. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
  built on Mar 16 2009 16:09:18, gcc: 4.2.4 [Sherpya]
usage: ffmpeg [[infile options] -i infile]... {[outfile options] outfile}...
Hyper fast Audio and Video encoder
Main options:
-L                  show license
-h                  show help
-version            show version
-formats            show available formats, codecs, protocols, ...
-f fmt              force format
-i filename         input file name
-y                  overwrite output files
-t duration         record or transcode "duration" seconds of audio/video
-fs limit_size      set the limit file size in bytes
-ss time_off        set the start time offset
-itsoffset time_off  set the input ts offset
-itsscale stream:scale  set the input ts scale
-timestamp time     set the timestamp ('now' to set the current time)
-metadata string=string  add metadata
-dframes number     set the number of data frames to record
-v number           set the logging verbosity level
-target type        specify target file type ("vcd", "svcd", "dvd", "dv", "dv50"
, "pal-vcd", "ntsc-svcd", ...)
-xerror             exit on error
Advanced options:
-map file:stream[:syncfile:syncstream]  set input stream mapping
-map_meta_data outfile:infile  set meta data information of outfile from infile
-benchmark          add timings for benchmarking
-dump               dump each input packet
-hex                when dumping packets, also dump the payload
-re                 read input at native frame rate
-loop_input         loop (current only works with images)
-loop_output        number of times to loop output in formats that support loopi
ng (0 loops forever)
-threads count      thread count
-vsync              video sync method
-async              audio sync method
-adrift_threshold threshold  audio drift threshold
-vglobal            video global header storage type
-copyts             copy timestamps
-shortest           finish encoding within shortest input
-dts_delta_threshold threshold  timestamp discontinuity delta threshold
-programid          desired program number
-copyinkf           copy initial non-keyframes
-muxdelay seconds   set the maximum demux-decode delay
-muxpreload seconds  set the initial demux-decode delay
Video options:
-b bitrate          set bitrate (in bits/s)
-vb bitrate         set bitrate (in bits/s)
-vframes number     set the number of video frames to record
-r rate             set frame rate (Hz value, fraction or abbreviation)
-s size             set frame size (WxH or abbreviation)
-aspect aspect      set aspect ratio (4:3, 16:9 or 1.3333, 1.7777)
-croptop size       set top crop band size (in pixels)
-cropbottom size    set bottom crop band size (in pixels)
-cropleft size      set left crop band size (in pixels)
-cropright size     set right crop band size (in pixels)
-padtop size        set top pad band size (in pixels)
-padbottom size     set bottom pad band size (in pixels)
-padleft size       set left pad band size (in pixels)
-padright size      set right pad band size (in pixels)
-padcolor color     set color of pad bands (Hex 000000 thru FFFFFF)
-vn                 disable video
-vcodec codec       force video codec ('copy' to copy stream)
-sameq              use same video quality as source (implies VBR)
-pass n             select the pass number (1 or 2)
-passlogfile prefix  select two pass log file name prefix
-newvideo           add a new video stream to the current output stream
Advanced Video options:
-pix_fmt format     set pixel format, 'list' as argument shows all the pixel for
mats supported
-intra              use only intra frames
-vdt n              discard threshold
-qscale q           use fixed video quantizer scale (VBR)
-rc_override override  rate control override for specific intervals
-me_threshold threshold  motion estimaton threshold
-deinterlace        deinterlace pictures
-psnr               calculate PSNR of compressed frames
-vstats             dump video coding statistics to file
-vstats_file file   dump video coding statistics to file
-intra_matrix matrix  specify intra matrix coeffs
-inter_matrix matrix  specify inter matrix coeffs
-top                top=1/bottom=0/auto=-1 field first
-dc precision       intra_dc_precision
-vtag fourcc/tag    force video tag/fourcc
-qphist             show QP histogram
-force_fps          force the selected framerate, disable the best supported fra
merate selection
-vbsf bitstream_filter
-vpre preset        set the video options to the indicated preset
Audio options:
-ab bitrate         set bitrate (in bits/s)
-aframes number     set the number of audio frames to record
-aq quality         set audio quality (codec-specific)
-ar rate            set audio sampling rate (in Hz)
-ac channels        set number of audio channels
-an                 disable audio
-acodec codec       force audio codec ('copy' to copy stream)
-vol volume         change audio volume (256=normal)
-newaudio           add a new audio stream to the current output stream
-alang code         set the ISO 639 language code (3 letters) of the current aud
io stream
Advanced Audio options:
-atag fourcc/tag    force audio tag/fourcc
-sample_fmt format  set sample format, 'list' as argument shows all the sample f
ormats supported
-absf bitstream_filter
-apre preset        set the audio options to the indicated preset
Subtitle options:
-sn                 disable subtitle
-scodec codec       force subtitle codec ('copy' to copy stream)
-newsubtitle        add a new subtitle stream to the current output stream
-slang code         set the ISO 639 language code (3 letters) of the current sub
title stream
-sbsf bitstream_filter
-spre preset        set the subtitle options to the indicated preset
Audio/Video grab options:
-vc channel         set video grab channel (DV1394 only)
-tvstd standard     set television standard (NTSC, PAL (SECAM))
-isync              sync read on input
AVCodecContext AVOptions:
-b                 <int>   E.V.. set bitrate (in bits/s)
-ab                <int>   E..A. set bitrate (in bits/s)
-bt                <int>   E.V.. set video bitrate tolerance (in bits/s)
-flags             <flags> EDVA.
   mv4                     E.V.. use four motion vector by macroblock (mpeg4)
   obmc                    E.V.. use overlapped block motion compensation (h263+
   qpel                    E.V.. use 1/4 pel motion compensation
   loop                    E.V.. use loop filter
   gmc                     E.V.. use gmc
   mv0                     E.V.. always try a mb with mv=<0,0>
   part                    E.V.. use data partitioning
   gray                    EDV.. only decode/encode grayscale
   psnr                    E.V.. error[?] variables will be set during encoding
   naq                     E.V.. normalize adaptive quantization
   ildct                   E.V.. use interlaced dct
   low_delay               EDV.. force low delay
   alt                     E.V.. enable alternate scantable (mpeg2/mpeg4)
   global_header           E.VA. place global headers in extradata instead of ev
ery keyframe
   bitexact                EDVAS use only bitexact stuff (except (i)dct)
   aic                     E.V.. h263 advanced intra coding / mpeg4 ac predictio
n
   umv                     E.V.. use unlimited motion vectors
   cbp                     E.V.. use rate distortion optimization for cbp
   qprd                    E.V.. use rate distortion optimization for qp selecti
on
   aiv                     E.V.. h263 alternative inter vlc
   slice                   E.V..
   ilme                    E.V.. interlaced motion estimation
   scan_offset             E.V.. will reserve space for svcd scan offset user da
ta
   cgop                    E.V.. closed gop
-me_method         <int>   E.V.. set motion estimation method
   zero                    E.V.. zero motion estimation (fastest)
   full                    E.V.. full motion estimation (slowest)
   epzs                    E.V.. EPZS motion estimation (default)
   esa                     E.V.. esa motion estimation (alias for full)
   tesa                    E.V.. tesa motion estimation
   dia                     E.V.. dia motion estimation (alias for epzs)
   log                     E.V.. log motion estimation
   phods                   E.V.. phods motion estimation
   x1                      E.V.. X1 motion estimation
   hex                     E.V.. hex motion estimation
   umh                     E.V.. umh motion estimation
   iter                    E.V.. iter motion estimation
-g                 <int>   E.V.. set the group of picture size
-cutoff            <int>   E..A. set cutoff bandwidth
-frame_size        <int>   E..A.
-qcomp             <float> E.V.. video quantizer scale compression (VBR)
-qblur             <float> E.V.. video quantizer scale blur (VBR)
-qmin              <int>   E.V.. min video quantizer scale (VBR)
-qmax              <int>   E.V.. max video quantizer scale (VBR)
-qdiff             <int>   E.V.. max difference between the quantizer scale (VBR
-bf                <int>   E.V.. use 'frames' B frames
-b_qfactor         <float> E.V.. qp factor between p and b frames
-rc_strategy       <int>   E.V.. ratecontrol method
-b_strategy        <int>   E.V.. strategy to choose between I/P/B-frames
-hurry_up          <int>   .DV..
-ps                <int>   E.V.. rtp payload size in bits
-bug               <flags> .DV.. workaround not auto detected encoder bugs
   autodetect              .DV..
   old_msmpeg4             .DV.. some old lavc generated msmpeg4v3 files (no aut
odetection)
   xvid_ilace              .DV.. Xvid interlacing bug (autodetected if fourcc==X
VIX)
   ump4                    .DV.. (autodetected if fourcc==UMP4)
   no_padding              .DV.. padding bug (autodetected)
   amv                     .DV..
   ac_vlc                  .DV.. illegal vlc bug (autodetected per fourcc)
   qpel_chroma             .DV..
   std_qpel                .DV.. old standard qpel (autodetected per fourcc/vers
ion)
   qpel_chroma2            .DV..
   direct_blocksize         .DV.. direct-qpel-blocksize bug (autodetected per fo
urcc/version)
   edge                    .DV.. edge padding bug (autodetected per fourcc/versi
on)
   hpel_chroma             .DV..
   dc_clip                 .DV..
   ms                      .DV.. workaround various bugs in microsofts broken de
coders
-lelim             <int>   E.V.. single coefficient elimination threshold for lu
minance (negative values also consider dc coefficient)
-celim             <int>   E.V.. single coefficient elimination threshold for ch
rominance (negative values also consider dc coefficient)
-strict            <int>   EDVA. how strictly to follow the standards
   very                    EDV.. strictly conform to a older more strict version
 of the spec or reference software
   strict                  EDV.. strictly conform to all the things in the spec
no matter what consequences
   normal                  EDV..
   inofficial              EDV.. allow inofficial extensions
   experimental            EDV.. allow non standardized experimental things
-b_qoffset         <float> E.V.. qp offset between P and B frames
-er                <int>   .DVA. set error detection aggressivity
   careful                 .DV..
   compliant               .DV..
   aggressive              .DV..
   very_aggressive         .DV..
-mpeg_quant        <int>   E.V.. use MPEG quantizers instead of H.263
-qsquish           <float> E.V.. how to keep quantizer between qmin and qmax (0
= clip, 1 = use differentiable function)
-rc_qmod_amp       <float> E.V.. experimental quantizer modulation
-rc_qmod_freq      <int>   E.V.. experimental quantizer modulation
-rc_eq             <string> E.V.. set rate control equation
-maxrate           <int>   E.V.. set max video bitrate tolerance (in bits/s)
-minrate           <int>   E.V.. set min video bitrate tolerance (in bits/s)
-bufsize           <int>   E.VA. set ratecontrol buffer size (in bits)
-rc_buf_aggressivity <float> E.V.. currently useless
-i_qfactor         <float> E.V.. qp factor between P and I frames
-i_qoffset         <float> E.V.. qp offset between P and I frames
-rc_init_cplx      <float> E.V.. initial complexity for 1-pass encoding
-dct               <int>   E.V.. DCT algorithm
   auto                    E.V.. autoselect a good one (default)
   fastint                 E.V.. fast integer
   int                     E.V.. accurate integer
   mmx                     E.V..
   mlib                    E.V..
   altivec                 E.V..
   faan                    E.V.. floating point AAN DCT
-lumi_mask         <float> E.V.. compresses bright areas stronger than medium on
es
-tcplx_mask        <float> E.V.. temporal complexity masking
-scplx_mask        <float> E.V.. spatial complexity masking
-p_mask            <float> E.V.. inter masking
-dark_mask         <float> E.V.. compresses dark areas stronger than medium ones
-idct              <int>   EDV.. select IDCT implementation
   auto                    EDV..
   int                     EDV..
   simple                  EDV..
   simplemmx               EDV..
   libmpeg2mmx             EDV..
   ps2                     EDV..
   mlib                    EDV..
   arm                     EDV..
   altivec                 EDV..
   sh4                     EDV..
   simplearm               EDV..
   simplearmv5te           EDV..
   simplearmv6             EDV..
   simpleneon              EDV..
   simplealpha             EDV..
   h264                    EDV..
   vp3                     EDV..
   ipp                     EDV..
   xvidmmx                 EDV..
   faani                   EDV.. floating point AAN IDCT
-ec                <flags> .DV.. set error concealment strategy
   guess_mvs               .DV.. iterative motion vector (MV) search (slow)
   deblock                 .DV.. use strong deblock filter for damaged MBs
-pred              <int>   E.V.. prediction method
   left                    E.V..
   plane                   E.V..
   median                  E.V..
-aspect            <rational> E.V.. sample aspect ratio
-debug             <flags> EDVAS print specific debug info
   pict                    .DV.. picture info
   rc                      E.V.. rate control
   bitstream               .DV..
   mb_type                 .DV.. macroblock (MB) type
   qp                      .DV.. per-block quantization parameter (QP)
   mv                      .DV.. motion vector
   dct_coeff               .DV..
   skip                    .DV..
   startcode               .DV..
   pts                     .DV..
   er                      .DV.. error recognition
   mmco                    .DV.. memory management control operations (H.264)
   bugs                    .DV..
   vis_qp                  .DV.. visualize quantization parameter (QP), lower QP
 are tinted greener
   vis_mb_type             .DV.. visualize block types
   buffers                 .DV.. picture buffer allocations
-vismv             <int>   .DV.. visualize motion vectors (MVs)
   pf                      .DV.. forward predicted MVs of P-frames
   bf                      .DV.. forward predicted MVs of B-frames
   bb                      .DV.. backward predicted MVs of B-frames
-mb_qmin           <int>   E.V.. obsolete, use qmin
-mb_qmax           <int>   E.V.. obsolete, use qmax
-cmp               <int>   E.V.. full pel me compare function
   sad                     E.V.. sum of absolute differences, fast (default)
   sse                     E.V.. sum of squared errors
   satd                    E.V.. sum of absolute Hadamard transformed difference
s
   dct                     E.V.. sum of absolute DCT transformed differences
   psnr                    E.V.. sum of squared quantization errors (avoid, low
quality)
   bit                     E.V.. number of bits needed for the block
   rd                      E.V.. rate distortion optimal, slow
   zero                    E.V.. 0
   vsad                    E.V.. sum of absolute vertical differences
   vsse                    E.V.. sum of squared vertical differences
   nsse                    E.V.. noise preserving sum of squared differences
   w53                     E.V.. 5/3 wavelet, only used in snow
   w97                     E.V.. 9/7 wavelet, only used in snow
   dctmax                  E.V..
   chroma                  E.V..
-subcmp            <int>   E.V.. sub pel me compare function
s
quality)
   zero                    E.V.. 0
   dctmax                  E.V..
   chroma                  E.V..
-mbcmp             <int>   E.V.. macroblock compare function
s
quality)
   zero                    E.V.. 0
   dctmax                  E.V..
   chroma                  E.V..
-ildctcmp          <int>   E.V.. interlaced dct compare function
s
quality)
   zero                    E.V.. 0
   dctmax                  E.V..
   chroma                  E.V..
-dia_size          <int>   E.V.. diamond type & size for motion estimation
-last_pred         <int>   E.V.. amount of motion predictors from the previous f
rame
-preme             <int>   E.V.. pre motion estimation
-precmp            <int>   E.V.. pre motion estimation compare function
s
quality)
   zero                    E.V.. 0
   dctmax                  E.V..
   chroma                  E.V..
-pre_dia_size      <int>   E.V.. diamond type & size for motion estimation pre-p
ass
-subq              <int>   E.V.. sub pel motion estimation quality
-me_range          <int>   E.V.. limit motion vectors range (1023 for DivX playe
r)
-ibias             <int>   E.V.. intra quant bias
-pbias             <int>   E.V.. inter quant bias
-coder             <int>   E.V..
   vlc                     E.V.. variable length coder / huffman coder
   ac                      E.V.. arithmetic coder
   raw                     E.V.. raw (no encoding)
   rle                     E.V.. run-length coder
   deflate                 E.V.. deflate-based coder
-context           <int>   E.V.. context model
-mbd               <int>   E.V.. macroblock decision algorithm (high quality mod
e)
   simple                  E.V.. use mbcmp (default)
   bits                    E.V.. use fewest bits
   rd                      E.V.. use best rate distortion
-sc_threshold      <int>   E.V.. scene change threshold
-lmin              <int>   E.V.. min lagrange factor (VBR)
-lmax              <int>   E.V.. max lagrange factor (VBR)
-nr                <int>   E.V.. noise reduction
-rc_init_occupancy <int>   E.V.. number of bits which should be loaded into the
rc buffer before decoding starts
-inter_threshold   <int>   E.V..
-flags2            <flags> EDVA.
   fast                    E.V.. allow non spec compliant speedup tricks
   sgop                    E.V.. strictly enforce gop size
   noout                   E.V.. skip bitstream encoding
   local_header            E.V.. place global headers at every keyframe instead
of in extradata
   bpyramid                E.V.. allows B-frames to be used as references for pr
edicting
   wpred                   E.V.. weighted biprediction for b-frames (H.264)
   mixed_refs              E.V.. one reference per partition, as opposed to one
reference per macroblock
   dct8x8                  E.V.. high profile 8x8 transform (H.264)
   fastpskip               E.V.. fast pskip (H.264)
   aud                     E.V.. access unit delimiters (H.264)
   skiprd                  E.V.. RD optimal MB level residual skipping
   ivlc                    E.V.. intra vlc table
   drop_frame_timecode         E.V..
   non_linear_q            E.V.. use non linear quantizer
   reservoir               E..A. use bit reservoir
-error             <int>   E.V..
-antialias         <int>   .DV.. MP3 antialias algorithm
   auto                    .DV..
   fastint                 .DV..
   int                     .DV..
   float                   .DV..
-qns               <int>   E.V.. quantizer noise shaping
-threads           <int>   EDV..
-mb_threshold      <int>   E.V.. macroblock threshold
-dc                <int>   E.V.. intra_dc_precision
-nssew             <int>   E.V.. nsse weight
-skip_top          <int>   .DV.. number of macroblock rows at the top which are
skipped
-skip_bottom       <int>   .DV.. number of macroblock rows at the bottom which a
re skipped
-profile           <int>   E.VA.
   unknown                 E.VA.
   aac_main                E..A.
   aac_low                 E..A.
   aac_ssr                 E..A.
   aac_ltp                 E..A.
-level             <int>   E.VA.
   unknown                 E.VA.
-lowres            <int>   .DV.. decode at 1= 1/2, 2=1/4, 3=1/8 resolutions
-skip_threshold    <int>   E.V.. frame skip threshold
-skip_factor       <int>   E.V.. frame skip factor
-skip_exp          <int>   E.V.. frame skip exponent
-skipcmp           <int>   E.V.. frame skip compare function
s
quality)
   zero                    E.V.. 0
   dctmax                  E.V..
   chroma                  E.V..
-border_mask       <float> E.V.. increases the quantizer for macroblocks close t
o borders
-mblmin            <int>   E.V.. min macroblock lagrange factor (VBR)
-mblmax            <int>   E.V.. max macroblock lagrange factor (VBR)
-mepc              <int>   E.V.. motion estimation bitrate penalty compensation
(1.0 = 256)
-skip_loop_filter  <int>   .DV..
   none                    .DV..
   default                 .DV..
   noref                   .DV..
   bidir                   .DV..
   nokey                   .DV..
   all                     .DV..
-skip_idct         <int>   .DV..
   none                    .DV..
   default                 .DV..
   noref                   .DV..
   bidir                   .DV..
   nokey                   .DV..
   all                     .DV..
-skip_frame        <int>   .DV..
   none                    .DV..
   default                 .DV..
   noref                   .DV..
   bidir                   .DV..
   nokey                   .DV..
   all                     .DV..
-bidir_refine      <int>   E.V.. refine the two motion vectors used in bidirecti
onal macroblocks
-brd_scale         <int>   E.V.. downscales frames for dynamic B-frame decision
-crf               <float> E.V.. enables constant quality mode, and selects the
quality (x264)
-cqp               <int>   E.V.. constant quantization parameter rate control me
thod
-keyint_min        <int>   E.V.. minimum interval between IDR-frames (x264)
-refs              <int>   E.V.. reference frames to consider for motion compens
ation (Snow)
-chromaoffset      <int>   E.V.. chroma qp offset from luma
-bframebias        <int>   E.V.. influences how often B-frames are used
-trellis           <int>   E.VA. rate-distortion optimal quantization
-directpred        <int>   E.V.. direct mv prediction mode - 0 (none), 1 (spatia
l), 2 (temporal), 3 (auto)
-complexityblur    <float> E.V.. reduce fluctuations in qp (before curve compres
sion)
-deblockalpha      <int>   E.V.. in-loop deblocking filter alphac0 parameter
-deblockbeta       <int>   E.V.. in-loop deblocking filter beta parameter
-partitions        <flags> E.V.. macroblock subpartition sizes to consider
   parti4x4                E.V..
   parti8x8                E.V..
   partp4x4                E.V..
   partp8x8                E.V..
   partb8x8                E.V..
-sc_factor         <int>   E.V.. multiplied by qscale for each frame and added t
o scene_change_score
-mv0_threshold     <int>   E.V..
-b_sensitivity     <int>   E.V.. adjusts sensitivity of b_frame_strategy 1
-compression_level <int>   E.VA.
-use_lpc           <int>   E..A. sets whether to use LPC mode (FLAC)
-lpc_coeff_precision <int>   E..A. LPC coefficient precision (FLAC)
-min_prediction_order <int>   E..A.
-max_prediction_order <int>   E..A.
-prediction_order_method <int>   E..A. search method for selecting prediction or
der
-min_partition_order <int>   E..A.
-max_partition_order <int>   E..A.
-timecode_frame_start <int>   E.V.. GOP timecode frame start number, in non drop
 frame format
-request_channels  <int>   .D.A. set desired number of audio channels
-drc_scale         <float> .D.A. percentage of dynamic range compression to appl
y
-channel_layout    <int64> ED.A.
-request_channel_layout <int64> .D.A.
-rc_max_vbv_use    <float> E.V..
-rc_min_vbv_use    <float> E.V..
-ticks_per_frame   <int>   EDVA.
AVFormatContext AVOptions:
-probesize         <int>   .D...
-muxrate           <int>   E.... set mux rate
-packetsize        <int>   E.... set packet size
-fflags            <flags> ED...
   ignidx                  .D... ignore index
   genpts                  .D... generate pts
-track             <int>   E....  set the track number
-year              <int>   E.... set the year
-analyzeduration   <int>   .D... how many microseconds are analyzed to estimate
duration
-cryptokey         <binary> .D... decryption key
-indexmem          <int>   .D... max memory used for timestamp index (per stream
-rtbufsize         <int>   .D... max memory used for buffering real-time frames
-fdebug            <flags> ED... print specific debug info
   ts                      ED...
SWScaler AVOptions:
-sws_flags         <flags> E.V.. scaler/cpu flags
   fast_bilinear           E.V.. fast bilinear
   bilinear                E.V.. bilinear
   bicubic                 E.V.. bicubic
   experimental            E.V.. experimental
   neighbor                E.V.. nearest neighbor
   area                    E.V.. averaging area
   bicublin                E.V.. luma bicubic, chroma bilinear
   gauss                   E.V.. gaussian
   sinc                    E.V.. sinc
   lanczos                 E.V.. lanczos
   spline                  E.V.. natural bicubic spline
   print_info              E.V.. print info
   accurate_rnd            E.V.. accurate rounding
   mmx                     E.V.. MMX SIMD acceleration
   mmx2                    E.V.. MMX2 SIMD acceleration
   3dnow                   E.V.. 3DNOW SIMD acceleration
   altivec                 E.V.. AltiVec SIMD acceleration
   bfin                    E.V.. Blackfin SIMD acceleration
   full_chroma_int         E.V.. full chroma interpolation
   full_chroma_inp         E.V.. full chroma input
   bitexact                E.V..
New Version Formats
File formats:
  E 3g2             3GP2 format
  E 3gp             3GP format
 D  4xm             4X Technologies format
 D  IFF             IFF format
 D  ISS             Funcom ISS format
 D  MTV             MTV format
 DE RoQ             raw id RoQ format
 D  aac             raw ADTS AAC
 DE ac3             raw AC-3
  E adts            ADTS AAC
 DE aiff            Audio IFF
 DE alaw            PCM A-law format
 DE amr             3GPP AMR file format
 D  apc             CRYO APC format
 D  ape             Monkey's Audio
 DE asf             ASF format
  E asf_stream      ASF format
 DE ass             SSA/ASS format
 DE au              SUN AU format
 DE avi             AVI format
  E avm2            Flash 9 (AVM2) format
 D  avs             AVISynth
 D  bethsoftvid     Bethesda Softworks VID format
 D  bfi             Brute Force & Ignorance
 D  c93             Interplay C93
 D  cavsvideo       raw Chinese AVS video
  E crc             CRC testing format
 DE daud            D-Cinema audio format
 DE dirac           raw Dirac
 DE dnxhd           raw DNxHD (SMPTE VC-3)
 D  dsicin          Delphine Software International CIN format
 DE dts             raw DTS
 DE dv              DV video format
  E dvd             MPEG-2 PS format (DVD VOB)
 D  dxa             DXA
 D  ea              Electronic Arts Multimedia Format
 D  ea_cdata        Electronic Arts cdata
 DE eac3            raw E-AC-3
 DE f32be           PCM 32 bit floating-point big-endian format
 DE f32le           PCM 32 bit floating-point little-endian format
 DE f64be           PCM 64 bit floating-point big-endian format
 DE f64le           PCM 64 bit floating-point little-endian format
 DE ffm             FFM (FFserver live feed) format
 D  film_cpk        Sega FILM/CPK format
 DE flac            raw FLAC
 D  flic            FLI/FLC/FLX animation format
 DE flv             FLV format
  E framecrc        framecrc testing format
  E gif             GIF Animation
 D  gsm             raw GSM
 DE gxf             GXF format
 DE h261            raw H.261
 DE h263            raw H.263
 DE h264            raw H.264 video format
 D  idcin           id Cinematic format
 DE image2          image2 sequence
 DE image2pipe      piped image2 sequence
 D  ingenient       raw Ingenient MJPEG
 D  ipmovie         Interplay MVE format
  E ipod            iPod H.264 MP4 format
 D  lmlm4           lmlm4 raw format
 DE m4v             raw MPEG-4 video format
 DE matroska        Matroska file format
 DE mjpeg           raw MJPEG video
 D  mlp             raw MLP
 D  mm              American Laser Games MM format
 DE mmf             Yamaha SMAF
  E mov             MOV format
 D  mov,mp4,m4a,3gp,3g2,mj2 QuickTime/MPEG-4/Motion JPEG 2000 format
  E mp2             MPEG audio layer 2
 DE mp3             MPEG audio layer 3
  E mp4             MP4 format
 D  mpc             Musepack
 D  mpc8            Musepack SV8
 DE mpeg            MPEG-1 System format
  E mpeg1video      raw MPEG-1 video
  E mpeg2video      raw MPEG-2 video
 DE mpegts          MPEG-2 transport stream format
 D  mpegtsraw       MPEG-2 raw transport stream format
 D  mpegvideo       raw MPEG video
  E mpjpeg          MIME multipart JPEG format
 D  msnwctcp        MSN TCP Webcam stream
 DE mulaw           PCM mu-law format
 D  mvi             Motion Pixels MVI format
 DE mxf             Material eXchange Format
  E mxf_d10         Material eXchange Format, D-10 Mapping
 D  nc              NC camera feed format
 D  nsv             Nullsoft Streaming Video
  E null            raw null video format
 DE nut             NUT format
 D  nuv             NuppelVideo format
 DE ogg             Ogg
 D  oma             Sony OpenMG audio
  E psp             PSP MP4 format
 D  psxstr          Sony Playstation STR format
 D  pva             TechnoTrend PVA file and stream format
 D  r3d             REDCODE R3D format
 DE rawvideo        raw video format
  E rcv             VC-1 test bitstream
 D  redir           Redirector format
 D  rl2             RL2 format
 DE rm              RealMedia format
 D  rpl             RPL/ARMovie format
  E rtp             RTP output format
 D  rtsp            RTSP input format
 DE s16be           PCM signed 16 bit big-endian format
 DE s16le           PCM signed 16 bit little-endian format
 DE s24be           PCM signed 24 bit big-endian format
 DE s24le           PCM signed 24 bit little-endian format
 DE s32be           PCM signed 32 bit big-endian format
 DE s32le           PCM signed 32 bit little-endian format
 DE s8              PCM signed 8 bit format
 D  sdp             SDP
 D  shn             raw Shorten
 D  siff            Beam Software SIFF
 D  smk             Smacker video
 D  sol             Sierra SOL format
  E svcd            MPEG-2 PS format (VOB)
 DE swf             Flash format
 D  thp             THP
 D  tiertexseq      Tiertex Limited SEQ format
 D  tta             True Audio
 D  txd             Renderware TeXture Dictionary
 DE u16be           PCM unsigned 16 bit big-endian format
 DE u16le           PCM unsigned 16 bit little-endian format
 DE u24be           PCM unsigned 24 bit big-endian format
 DE u24le           PCM unsigned 24 bit little-endian format
 DE u32be           PCM unsigned 32 bit big-endian format
 DE u32le           PCM unsigned 32 bit little-endian format
 DE u8              PCM unsigned 8 bit format
 D  vc1             raw VC-1
 D  vc1test         VC-1 test bitstream format
  E vcd             MPEG-1 System format (VCD)
 D  vfwcap          VFW video capture
 D  vmd             Sierra VMD format
  E vob             MPEG-2 PS format (VOB)
 DE voc             Creative Voice file format
 DE wav             WAV format
 D  wc3movie        Wing Commander III movie format
 D  wsaud           Westwood Studios audio format
 D  wsvqa           Westwood Studios VQA format
 D  wv              WavPack
 D  xa              Maxis XA File Format
 DE yuv4mpegpipe    YUV4MPEG pipe format
Codecs:
 D V    4xm             4X Movie
 D V D  8bps            QuickTime 8BPS video
 D A    8svx_exp        8SVX exponential
 D A    8svx_fib        8SVX fibonacci
 D A    aac             Advanced Audio Coding
 D V D  aasc            Autodesk RLE
 DEA    ac3             ATSC A/52A (AC-3)
 D A    adpcm_4xm       ADPCM 4X Movie
 DEA    adpcm_adx       SEGA CRI ADX ADPCM
 D A    adpcm_ct        ADPCM Creative Technology
 D A    adpcm_ea        ADPCM Electronic Arts
 D A    adpcm_ea_maxis_xa ADPCM Electronic Arts Maxis CDROM XA
 D A    adpcm_ea_r1     ADPCM Electronic Arts R1
 D A    adpcm_ea_r2     ADPCM Electronic Arts R2
 D A    adpcm_ea_r3     ADPCM Electronic Arts R3
 D A    adpcm_ea_xas    ADPCM Electronic Arts XAS
 D A    adpcm_ima_amv   ADPCM IMA AMV
 D A    adpcm_ima_dk3   ADPCM IMA Duck DK3
 D A    adpcm_ima_dk4   ADPCM IMA Duck DK4
 D A    adpcm_ima_ea_eacs ADPCM IMA Electronic Arts EACS
 D A    adpcm_ima_ea_sead ADPCM IMA Electronic Arts SEAD
 D A    adpcm_ima_iss   ADPCM IMA Funcom ISS
 DEA    adpcm_ima_qt    ADPCM IMA QuickTime
 D A    adpcm_ima_smjpeg ADPCM IMA Loki SDL MJPEG
 DEA    adpcm_ima_wav   ADPCM IMA WAV
 D A    adpcm_ima_ws    ADPCM IMA Westwood
 DEA    adpcm_ms        ADPCM Microsoft
 D A    adpcm_sbpro_2   ADPCM Sound Blaster Pro 2-bit
 D A    adpcm_sbpro_3   ADPCM Sound Blaster Pro 2.6-bit
 D A    adpcm_sbpro_4   ADPCM Sound Blaster Pro 4-bit
 DEA    adpcm_swf       ADPCM Shockwave Flash
 D A    adpcm_thp       ADPCM Nintendo Gamecube THP
 D A    adpcm_xa        ADPCM CDROM XA
 DEA    adpcm_yamaha    ADPCM Yamaha
 DEA    alac            ALAC (Apple Lossless Audio Codec)
 D V    amv             AMV Video
 D A    ape             Monkey's Audio
 DEV D  asv1            ASUS V1
 DEV D  asv2            ASUS V2
 D A    atrac3          Atrac 3 (Adaptive TRansform Acoustic Coding 3)
 D V D  avs             AVS (Audio Video Standard) video
 D V    bethsoftvid     Bethesda VID video
 D V    bfi             Brute Force & Ignorance
 DEV    bmp             BMP image
 D V D  c93             Interplay C93
 D V D  camstudio       CamStudio
 D V D  camtasia        TechSmith Screen Capture Codec
 D V D  cavs            Chinese AVS video (AVS1-P2, JiZhun profile)
 D V D  cinepak         Cinepak
 D V D  cljr            Cirrus Logic AccuPak
 D A    cook            COOK
 D V D  cyuv            Creative YUV (CYUV)
 D A    dca             DCA (DTS Coherent Acoustics)
 DEV D  dnxhd           VC3/DNxHD
 D A    dsicinaudio     Delphine Software International CIN audio
 D V D  dsicinvideo     Delphine Software International CIN video
 DES    dvbsub          DVB subtitles
 DES    dvdsub          DVD subtitles
 DEV D  dvvideo         DV (Digital Video)
 D V    dxa             Feeble Files/ScummVM DXA
 D A    eac3            ATSC A/52B (AC-3, E-AC-3)
 D V D  eacmv           Electronic Arts CMV video
 D V D  eatgq           Electronic Arts TGQ video
 D V    eatgv           Electronic Arts TGV video
 D V D  eatqi           Electronic Arts TQI Video
 D V D  escape124       Escape 124
 DEV D  ffv1            FFmpeg codec #1
 DEVSD  ffvhuff         Huffyuv FFmpeg variant
 DEA    flac            FLAC (Free Lossless Audio Codec)
 DEV D  flashsv         Flash Screen Video
 D V D  flic            Autodesk Animator Flic video
 DEVSD  flv             Flash Video (FLV)
 D V D  fraps           Fraps
 DEA    g726            G.726 ADPCM
 DEV    gif             GIF (Graphics Interchange Format)
 DEV D  h261            H.261
 DEVSDT h263            H.263 / H.263-1996
 D VSD  h263i           Intel H.263
  EV    h263p           H.263+ / H.263-1998 / H.263 version 2
 D V D  h264            H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
 DEVSD  huffyuv         Huffyuv / HuffYUV
 D V D  idcinvideo      id Quake II CIN video
 D A    imc             IMC (Intel Music Coder)
 D V D  indeo2          Intel Indeo 2
 D V    indeo3          Intel Indeo 3
 D A    interplay_dpcm  DPCM Interplay
 D V D  interplayvideo  Interplay MVE video
 DEV D  jpegls          JPEG-LS
 D V    kmvc            Karl Morton's video codec
  EA    libfaac         libfaac AAC (Advanced Audio Codec)
 D A    libfaad         libfaad AAC (Advanced Audio Codec)
  EA    libmp3lame      libmp3lame MP3 (MPEG audio layer 3)
 D A    libspeex        libspeex Speex
  EV    libtheora       libtheora Theora
  EA    libvorbis       libvorbis Vorbis
  EV    libx264         libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
  EV    libxvid         libxvidcore MPEG-4 part 2
  EV    ljpeg           Lossless JPEG
 D V D  loco            LOCO
 D A    mace3           MACE (Macintosh Audio Compression/Expansion) 3:1
 D A    mace6           MACE (Macintosh Audio Compression/Expansion) 6:1
 D V D  mdec            Sony PlayStation MDROBOT.LK (Motion DECoder)
 D V D  mimic           Mimic
 DEV D  mjpeg           MJPEG (Motion JPEG)
 D V D  mjpegb          Apple MJPEG-B
 D A    mlp             MLP (Meridian Lossless Packing)/TrueHD
 D V D  mmvideo         American Laser Games MM Video
 D V D  motionpixels    Motion Pixels video
 D A    mp1             MP1 (MPEG audio layer 1)
 DEA    mp2             MP2 (MPEG audio layer 2)
 D A    mp3             MP3 (MPEG audio layer 3)
 D A    mp3adu          ADU (Application Data Unit) MP3 (MPEG audio layer 3)
 D A    mp3on4          MP3onMP4
 D A    mpc7            Musepack SV7
 D A    mpc8            Musepack SV8
 DEVSDT mpeg1video      MPEG-1 video
 DEVSDT mpeg2video      MPEG-2 video
 DEVSDT mpeg4           MPEG-4 part 2
 D VSDT mpegvideo       MPEG-1 video
 DEVSD  msmpeg4         MPEG-4 part 2 Microsoft variant version 3
 DEVSD  msmpeg4v1       MPEG-4 part 2 Microsoft variant version 1
 DEVSD  msmpeg4v2       MPEG-4 part 2 Microsoft variant version 2
 D V D  msrle           Microsoft RLE
 D V D  msvideo1        Microsoft Video 1
 D V D  mszh            LCL (LossLess Codec Library) MSZH
 DEA    nellymoser      Nellymoser Asao
 D V D  nuv             NuppelVideo/RTJPEG
 DEV    pam             PAM (Portable AnyMap) image
 DEV    pbm             PBM (Portable BitMap) image
 DEA    pcm_alaw        PCM A-law
 D A    pcm_dvd         PCM signed 20|24-bit big-endian
 DEA    pcm_f32be       PCM 32-bit floating point big-endian
 DEA    pcm_f32le       PCM 32-bit floating point little-endian
 DEA    pcm_f64be       PCM 64-bit floating point big-endian
 DEA    pcm_f64le       PCM 64-bit floating point little-endian
 DEA    pcm_mulaw       PCM mu-law
 DEA    pcm_s16be       PCM signed 16-bit big-endian
 DEA    pcm_s16le       PCM signed 16-bit little-endian
 D A    pcm_s16le_planar PCM 16-bit little-endian planar
 DEA    pcm_s24be       PCM signed 24-bit big-endian
 DEA    pcm_s24daud     PCM D-Cinema audio signed 24-bit
 DEA    pcm_s24le       PCM signed 24-bit little-endian
 DEA    pcm_s32be       PCM signed 32-bit big-endian
 DEA    pcm_s32le       PCM signed 32-bit little-endian
 DEA    pcm_s8          PCM signed 8-bit
 DEA    pcm_u16be       PCM unsigned 16-bit big-endian
 DEA    pcm_u16le       PCM unsigned 16-bit little-endian
 DEA    pcm_u24be       PCM unsigned 24-bit big-endian
 DEA    pcm_u24le       PCM unsigned 24-bit little-endian
 DEA    pcm_u32be       PCM unsigned 32-bit big-endian
 DEA    pcm_u32le       PCM unsigned 32-bit little-endian
 DEA    pcm_u8          PCM unsigned 8-bit
 DEA    pcm_zork        PCM Zork
 D V    pcx             PC Paintbrush PCX image
 DEV    pgm             PGM (Portable GrayMap) image
 DEV    pgmyuv          PGMYUV (Portable GrayMap YUV) image
 DEV    png             PNG image
 DEV    ppm             PPM (Portable PixelMap) image
 D V    ptx             V.Flash PTX image
 D A    qcelp           QCELP / PureVoice
 D A    qdm2            QDesign Music Codec 2
 D V D  qdraw           Apple QuickDraw
 D V D  qpeg            Q-team QPEG
 DEV D  qtrle           QuickTime Animation (RLE) video
 DEV    rawvideo        raw video
 D A    real_144        RealAudio 1.0 (14.4K)
 D A    real_288        RealAudio 2.0 (28.8K)
 D V D  rl2             RL2 video
 DEA    roq_dpcm        id RoQ DPCM
 DEV D  roqvideo        id RoQ video
 D V D  rpza            QuickTime video (RPZA)
 DEV D  rv10            RealVideo 1.0
 DEV D  rv20            RealVideo 2.0
 D V D  rv30            RealVideo 3.0
 D V D  rv40            RealVideo 4.0
 DEV    sgi             SGI image
 D A    shorten         Shorten
 D A    smackaud        Smacker audio
 D V    smackvid        Smacker video
 D V D  smc             QuickTime Graphics (SMC)
 DEV    snow            Snow
 D A    sol_dpcm        DPCM Sol
 DEA    sonic           Sonic
  EA    sonicls         Sonic lossless
 D V D  sp5x            Sunplus JPEG (SP5X)
 D V    sunrast         Sun Rasterfile image
 DEV D  svq1            Sorenson Vector Quantizer 1
 D VSD  svq3            Sorenson Vector Quantizer 3
 DEV    targa           Truevision Targa image
 D V    theora          Theora
 D V D  thp             Nintendo Gamecube THP video
 D V D  tiertexseqvideo Tiertex Limited SEQ video
 DEV    tiff            TIFF image
 D V D  truemotion1     Duck TrueMotion 1.0
 D V D  truemotion2     Duck TrueMotion 2.0
 D A    truespeech      DSP Group TrueSpeech
 D A    tta             True Audio (TTA)
 D V    txd             Renderware TXD (TeXture Dictionary) image
 D V D  ultimotion      IBM UltiMotion
 D V    vb              Beam Software VB
 D V    vc1             SMPTE VC-1
 D V D  vcr1            ATI VCR1
 D A    vmdaudio        Sierra VMD audio
 D V D  vmdvideo        Sierra VMD video
 D V    vmnc            VMware Screen Codec / VMware Video
 DEA    vorbis          Vorbis
 D V    vp3             On2 VP3
 D V D  vp5             On2 VP5
 D V D  vp6             On2 VP6
 D V D  vp6a            On2 VP6 (Flash version, with alpha channel)
 D V D  vp6f            On2 VP6 (Flash version)
 D V D  vqavideo        Westwood Studios VQA (Vector Quantized Animation) video
 D A    wavpack         WavPack
 DEA    wmav1           Windows Media Audio 1
 DEA    wmav2           Windows Media Audio 2
 DEVSD  wmv1            Windows Media Video 7
 DEVSD  wmv2            Windows Media Video 8
 D V    wmv3            Windows Media Video 9
 D V D  wnv1            Winnov WNV1
 D A    ws_snd1         Westwood Audio (SND1)
 D A    xan_dpcm        DPCM Xan
 D V D  xan_wc3         Wing Commander III / Xan
 D V D  xl              Miro VideoXL
 D S    xsub            XSUB
 DEV D  zlib            LCL (LossLess Codec Library) ZLIB
 DEV    zmbv            Zip Motion Blocks Video
Bitstream filters:
 text2movsub remove_extra noise mov2textsub mp3decomp mp3comp mjpegadump imxdump
 h264_mp4toannexb dump_extra
Supported file protocols:
 file: gopher: http: pipe: rtp: tcp: udp:
Frame size, frame rate abbreviations:
 ntsc pal qntsc qpal sntsc spal film ntsc-film sqcif qcif cif 4cif
Note, the names of encoders and decoders do not always match, so there are several cases where the above table shows encoder only or decoder only entries even though both encoding and decoding are supported. For example, the h263 decoder corresponds to the h263 and h263p encoders, for file formats it is even worse.
Download this version of ffmpeg.exe.
ffmpeg.zip
(3.13 MiB) Downloaded 1102 times
Old Version
FFmpeg version SVN-r6179, Copyright (c) 2000-2004 Fabrice Bellard
  configuration:  --enable-memalign-hack
  libavutil version: 49.0.0
  libavcodec version: 51.13.0
  libavformat version: 50.5.0
  built on Sep  5 2006 22:35:53, gcc: 3.4.5 (mingw special)
Main options:
-L                  show license
-h                  show help
-f fmt              force format
-img img_fmt        force image format
-t duration         set the recording time
-title string       set the title
-author string      set the author
-copyright string   set the copyright
-comment string     set the comment
-v verbose          control amount of logging
-slang code         set the ISO 639 language code (3 letters) of the current subtitle stream
Video options:
-b bitrate          set video bitrate (in kbit/s)
-vn                 disable video
-bt tolerance       set video bitrate tolerance (in kbit/s)
-maxrate bitrate    set max video bitrate tolerance (in kbit/s)
-minrate bitrate    set min video bitrate tolerance (in kbit/s)
-bufsize size       set ratecontrol buffer size (in kByte)
-passlogfile file   select two pass log file name
-g gop_size         set the group of picture size
-qscale q           use fixed video quantiser scale (VBR)
-qmin q             min video quantiser scale (VBR)
-qmax q             max video quantiser scale (VBR)
-lmin lambda        min video lagrange factor (VBR)
-lmax lambda        max video lagrange factor (VBR)
-mblmin q           min macroblock quantiser scale (VBR)
-mblmax q           max macroblock quantiser scale (VBR)
-qdiff q            max difference between the quantiser scale (VBR)
-qblur blur         video quantiser scale blur (VBR)
-qsquish squish     how to keep quantiser between qmin and qmax (0 = clip, 1 = use differentiable function)
-qcomp compression  video quantiser scale compression (VBR)
-rc_init_cplx complexity  initial complexity for 1-pass encoding
-b_qfactor factor   qp factor between p and b frames
-i_qfactor factor   qp factor between p and i frames
-b_qoffset offset   qp offset between p and b frames
-i_qoffset offset   qp offset between p and i frames
-ibias bias         intra quant bias
-pbias bias         inter quant bias
-rc_eq equation     set rate control equation
-me method          set motion estimation method
-me_threshold       motion estimaton threshold
-mb_threshold       macroblock threshold
-bf frames          use 'frames' B frames
-preme              pre motion estimation
-bug param          workaround not auto detected encoder bugs
-strict strictness  how strictly to follow the standards
-vhook module       insert video processing module
-sc_threshold threshold  scene change threshold
-me_range range     limit motion vectors range (1023 for DivX player)
-mepc factor (1.0 = 256)  motion estimation bitrate penalty compensation
-skip_threshold threshold  frame skip threshold
-skip_factor factor  frame skip factor
-skip_exp exponent  frame skip exponent
-vbsf bitstream filter
Audio options:
-ab bitrate         set audio bitrate (in kbit/s)
-an                 disable audio
-alang code         set the ISO 639 language code (3 letters) of the current audio stream
-absf bitstream filter
Subtitle options:
-vd device          set video grab device
-ad device          set audio device
-grab format        request grabbing using
-gd device          set grab device
Advanced options:
-loop_output        number of times to loop output in formats that support looping (0 loops forever)
-dts_delta_threshold   timestamp discontinuity delta threshold
-ps size            set packet size in bits
-error rate         error rate
-muxrate rate       set mux rate
-packetsize size    set packet size
-bit_rate          <int>   E.VA.
-bit_rate_tolerance <int>   E.V..
-mv4                       E.V.. use four motion vector by macroblock (mpeg4)
-obmc                      E.V.. use overlapped block motion compensation (h263+)
-qpel                      E.V.. use 1/4 pel motion compensation
-loop                      E.V.. use loop filter
-gmc                       E.V.. use gmc
-mv0                       E.V.. always try a mb with mv=<0,0>
-part                      E.V.. use data partitioning
-gray                      EDV.. only decode/encode grayscale
-psnr                      E.V.. error[?] variables will be set during encoding
-naq                       E.V.. normalize adaptive quantization
-ildct                     E.V.. use interlaced dct
-low_delay                 .DV.. force low delay
-alt                       E.V.. enable alternate scantable (mpeg2/mpeg4)
-trell                     E.V.. use trellis quantization
-bitexact                  EDVAS use only bitexact stuff (except (i)dct)
-aic                       E.V.. h263 advanced intra coding / mpeg4 ac prediction
-umv                       E.V.. use unlimited motion vectors
-cbp                       E.V.. use rate distortion optimization for cbp
-qprd                      E.V.. use rate distortion optimization for qp selection
-aiv                       E.V.. h263 alternative inter vlc
-slice                     E.V..
-ilme                      E.V.. interlaced motion estimation
-scan_offset               E.V.. will reserve space for svcd scan offset user data
-cgop                      E.V.. closed gop
-fast                      E.V.. allow non spec compliant speedup tricks
-sgop                      E.V.. strictly enforce gop size
-noout                     E.V.. skip bitstream encoding
-local_header              E.V.. place global headers at every keyframe instead of in extradata
-gop_size          <int>   E.V..
-qcompress         <float> E.V..
-qmin              <int>   E.V..
-qmax              <int>   E.V..
-max_qdiff         <int>   E.V..
-max_b_frames      <int>   E.V..
-b_quant_factor    <float> E.V..
-bugs              <int>   .DV..
-autodetect                .DV..
-old_msmpeg4               .DV..
-xvid_ilace                .DV..
-ump4                      .DV..
-no_padding                .DV..
-amv                       .DV..
-ac_vlc                    .DV..
-qpel_chroma               .DV..
-std_qpel                  .DV..
-qpel_chroma2              .DV..
-direct_blocksize          .DV..
-edge                      .DV..
-hpel_chroma               .DV..
-dc_clip                   .DV..
-ms                        .DV..
-lelim             <int>   E.V.. single coefficient elimination threshold for luminance (negative values also consider dc coefficient)
-celim             <int>   E.V.. single coefficient elimination threshold for chrominance (negative values also consider dc coefficient)
-strict            <int>   E.V..
-very                      E.V..
-strict                    E.V..
-normal                    E.V..
-inofficial                E.V..
-experimental              E.V..
-b_quant_offset    <float> E.V..
-er                <int>   .DV..
-careful                   .DV..
-compliant                 .DV..
-aggressive                .DV..
-very_aggressive           .DV..
-rc_qsquish        <float> E.V..
-rc_max_rate       <int>   E.V..
-rc_min_rate       <int>   E.V..
-rc_buffer_size    <int>   E.V..
-i_quant_factor    <float> E.V..
-i_quant_offset    <float> E.V..
-rc_initial_cplx   <float> E.V..
-dct               <int>   E.V..
-auto                      E.V..
-fastint                   E.V..
-int                       E.V..
-mmx                       E.V..
-mlib                      E.V..
-altivec                   E.V..
-faan                      E.V..
-lumi_mask         <float> E.V.. lumimasking
-dark_mask         <float> E.V.. darkness masking
-idct              <int>   EDV..
-auto                      EDV..
-int                       EDV..
-simple                    EDV..
-simplemmx                 EDV..
-libmpeg2mmx               EDV..
-ps2                       EDV..
-mlib                      EDV..
-arm                       EDV..
-altivec                   EDV..
-sh4                       EDV..
-simplearm                 EDV..
-h264                      EDV..
-vp3                       EDV..
-ipp                       EDV..
-xvidmmx                   EDV..
-ec                <flags> .DV..
-guess_mvs                 .DV..
-deblock                   .DV..
-left                      E.V..
-plane                     E.V..
-median                    E.V..
-pict                      .DV..
-rc                        E.V..
-bitstream                 .DV..
-mb_type                   .DV..
-qp                        .DV..
-mv                        .DV..
-dct_coeff                 .DV..
-skip                      .DV..
-startcode                 .DV..
-pts                       .DV..
-er                        .DV..
-mmco                      .DV..
-bugs                      .DV..
-vis_qp                    .DV..
-vis_mb_type               .DV..
-pf                        .DV..
-bf                        .DV..
-bb                        .DV..
-preme             <int>   E.V..
-sad                       E.V..
-sse                       E.V..
-satd                      E.V..
-dct                       E.V..
-psnr                      E.V..
-bit                       E.V..
-rd                        E.V..
-zero                      E.V..
-vsad                      E.V..
-vsse                      E.V..
-nsse                      E.V..
-w53                       E.V..
-w97                       E.V..
-dctmax                    E.V..
-chroma                    E.V..
-ibias             <int>   E.V..
-pbias             <int>   E.V..
-coder             <int>   E.V..
-vlc                       E.V.. variable length coder / huffman coder
-ac                        E.V.. arithmetic coder
-mbd               <int>   E.V..
-simple                    E.V..
-bits                      E.V..
-rd                        E.V..
-auto                      .DV..
-fastint                   .DV..
-int                       .DV..
-float                     .DV..
-thread_count      <int>   EDV..
-dc                <int>   E.V..
-unknown                   E.VA.
-level             <int>   E.VA.
-unknown                   E.VA.
-lowres            <int>   .DV..
-frame_skip_threshold <int>   E.V..
-frame_skip_factor <int>   E.V..
-frame_skip_exp    <int>   E.V..
-mb_lmin           <int>   E.V..
-mb_lmax           <int>   E.V..
-me_penalty_compensation <int>   E.V..
-crf               <int>   E.V..
-cqp               <int>   E.V..
-refs              <int>   E.V..
-bpyramid                  E.V..
-wpred                     E.V..
-mixed_refs                E.V..
-8x8dct                    E.V..
-fastpskip                 E.V..
-aud                       E.V..
-brdo                      E.V..
-parti4x4                  E.V..
-parti8x8                  E.V..
-partp4x4                  E.V..
-partp8x8                  E.V..
-partb8x8                  E.V..
-ivlc                      E.V.. intra vlc table
-fflags            <flags> .D...
-ignidx                    .D... ignore index
-genpts                    .D... generate pts
Old Version Formats
File formats:
  E 3g2             3gp2 format
  E 3gp             3gp format
 D  RoQ             Id RoQ format
 D  aac             ADTS AAC
 DE ac3             raw ac3
  E adts            ADTS AAC
 DE aiff            Audio IFF
 DE alaw            pcm A law format
 DE amr             3gpp amr file format
 DE asf             asf format
  E asf_stream      asf format
 DE au              SUN AU Format
 DE avi             avi format
 D  avs             avs format
  E crc             crc testing format
 D  daud            D-Cinema audio format
 D  dts             raw dts
  E dvd             MPEG2 PS format (DVD VOB)
 DE ffm             ffm format
 DE flac            raw flac
 DE flv             flv format
 DE gif             GIF Animation
 D  gxf             GXF format
 DE h261            raw h261
 DE h263            raw h263
 DE h264            raw H264 video format
 D  idcin           Id CIN format
 DE image           image sequence
 DE imagepipe       piped image sequence
 D  ingenient       Ingenient MJPEG
 DE m4v             raw MPEG4 video format
 D  matroska        Matroska file format
 DE mjpeg           MJPEG video
 DE mmf             mmf format
  E mov             mov format
 D  mov,mp4,m4a,3gp,3g2,mj2 QuickTime/MPEG4/Motion JPEG 2000 format
  E mp4             mp4 format
 DE mpeg            MPEG1 System format
  E mpeg1video      MPEG video
  E mpeg2video      MPEG2 video
 DE mpegts          MPEG2 transport stream format
 D  mpegvideo       MPEG video
  E mpjpeg          Mime multipart JPEG format
 DE mulaw           pcm mu law format
 D  mxf             MXF format
 D  nsv             NullSoft Video format
  E null            null video format
 DE nut             nut format
 D  ogg             Ogg
  E psp             psp mp4 format
 DE rm              rm format
 DE s16be           pcm signed 16 bit big endian format
 DE s16le           pcm signed 16 bit little endian format
 DE s8              pcm signed 8 bit format
 D  shn             raw shorten
 D  smk             Smacker Video
 D  sol             Sierra SOL Format
  E svcd            MPEG2 PS format (VOB)
 DE swf             Flash format
 D  tta             true-audio
 DE u16be           pcm unsigned 16 bit big endian format
 DE u16le           pcm unsigned 16 bit little endian format
 DE u8              pcm unsigned 8 bit format
  E vcd             MPEG1 System format (VCD)
  E vob             MPEG2 PS format (VOB)
 DE voc             Creative Voice File format
 DE wav             wav format
Image formats (filename extensions, if any, follow):
 DE gif    gif
Codecs:
 D V    4xm
 D V D  8bps
 D V    VMware video
 D V D  aasc
  EA    ac3
 DEA    adpcm_4xm
 DEA    adpcm_adx
 DEA    adpcm_ct
 DEA    adpcm_ea
 DEA    adpcm_ima_dk3
 DEA    adpcm_ima_dk4
 DEA    adpcm_ima_qt
 DEA    adpcm_ima_smjpeg
 DEA    adpcm_ima_wav
 DEA    adpcm_ima_ws
 DEA    adpcm_ms
 DEA    adpcm_sbpro_2
 DEA    adpcm_sbpro_3
 DEA    adpcm_sbpro_4
 DEA    adpcm_swf
 DEA    adpcm_xa
 DEA    adpcm_yamaha
 D A    alac
 DEV D  asv1
 DEV D  asv2
 D V D  avs
 D V    bmp
 D V D  camstudio
 D V D  camtasia
 D V D  cavs
 D V D  cinepak
 D V D  cljr
 D A    cook
 D V D  cyuv
 DES    dvbsub
 DES    dvdsub
 DEV D  dvvideo
 DEV D  ffv1
 DEVSD  ffvhuff
 DEA    flac
 D V D  flashsv
 D V D  flic
 DEVSD  flv
 D V D  fraps
 DEA    g726
 DEV D  h261
 DEVSDT h263
 D VSD  h263i
  EV    h263p
 D V DT h264
 DEVSD  huffyuv
 D V D  idcinvideo
 D V D  indeo2
 D V    indeo3
 D A    interplay_dpcm
  EV    jpegls
 D V    kmvc
  EV    ljpeg
 D V D  loco
 D A    mace3
 D A    mace6
 D V D  mdec
 DEV D  mjpeg
 D V D  mjpegb
 D V D  mmvideo
 DEA    mp2
 D A    mp3
 D A    mp3adu
 D A    mp3on4
 DEVSDT mpeg1video
 DEVSDT mpeg2video
 DEVSDT mpeg4
 D VSDT mpegvideo
 DEVSD  msmpeg4
 DEVSD  msmpeg4v1
 DEVSD  msmpeg4v2
 D V D  msrle
 D V D  msvideo1
 D V D  mszh
 D V D  nuv
 DEV    pam
 DEV    pbm
 DEA    pcm_alaw
 DEA    pcm_mulaw
 DEA    pcm_s16be
 DEA    pcm_s16le
 DEA    pcm_s24be
 DEA    pcm_s24daud
 DEA    pcm_s24le
 DEA    pcm_s32be
 DEA    pcm_s32le
 DEA    pcm_s8
 DEA    pcm_u16be
 DEA    pcm_u16le
 DEA    pcm_u24be
 DEA    pcm_u24le
 DEA    pcm_u32be
 DEA    pcm_u32le
 DEA    pcm_u8
 DEV    pgm
 DEV    pgmyuv
 DEV    png
 DEV    ppm
 D A    qdm2
 D V D  qdraw
 D V D  qpeg
 D V D  qtrle
 DEV    rawvideo
 D A    real_144
 D A    real_288
 D A    roq_dpcm
 D V D  roqvideo
 D V D  rpza
 DEV D  rv10
 DEV D  rv20
 D A    shorten
 D A    smackaud
 D V    smackvid
 D V D  smc
 DEV    snow
 D A    sol_dpcm
 DEA    sonic
  EA    sonicls
 D V D  sp5x
 DEV D  svq1
 D VSD  svq3
 D V    theora
 D V D  truemotion1
 D V D  truemotion2
 D A    truespeech
 D A    tta
 D V D  ultimotion
 D V    vc1
 D V D  vcr1
 D A    vmdaudio
 D V D  vmdvideo
 D A    vorbis
 D V    vp3
 D V D  vqavideo
 D A    wmav1
 D A    wmav2
 DEVSD  wmv1
 DEVSD  wmv2
 D V    wmv3
 D V D  wnv1
 D A    ws_snd1
 D A    xan_dpcm
 D V D  xan_wc3
 D V D  xl
 DEV D  zlib
 D V    zmbv
 file: pipe:
Motion estimation methods:
 zero(fastest) full(slowest) log phods epzs(default) x1 hex umh iter
Note, the names of encoders and decoders dont always match, so there are several cases where the above table shows encoder only or decoder only entries even though both encoding and decoding are supported for example, the h263 decoder corresponds to the h263 and h263p encoders, for file formats its even worse
ffmpeg_o.zip
(1.44 MiB) Downloaded 1102 times
Mysoogal
Re: FFMPEG Command Line Arguments
Post by Mysoogal » Sat Apr 02, 2011 11:49 am
to expand this on windows and Linux please check this post,
http://ubuntuforums.org/showthread.php? ... 5&page=157
there is actually a very advanced profile list complied for ffmpeg it should work on windows and Linux , its taken from winff video encoder,
