mysql error
Web programming topics
Mysoogal
mysql error
Post by Mysoogal » Sun Dec 20, 2009 6:35 am
having problems with mysql and this code, i've messed up something in mysql but not really sure, when i visit list.php it says no video table im really lost
  // encoding may take a few minutes.
  set_time_limit(1800);
  // disable output buffering so we can send the encoding progress to the browser.
  ob_implicit_flush(true);
  include("db.php");
  function StringToTime($Duration)
      $TimeArray = NULL;
      if(strlen($Duration) > 0)
          $TimeArray = explode(":", $Duration);                 if(count($TimeArray) > 2)
              return ((int)$TimeArray[0]) * 3600 + ((int)$TimeArray[1]) * 60 + ((int)$TimeArray[2]);
    function GetCurPath()
      $curpath = $_SERVER["DOCUMENT_ROOT"].$_SERVER["PHP_SELF"];
      $index = strrpos($curpath, "/");
      if($index != 0)
          $curpath = substr($curpath, 0, $index);
      return $curpath;
  }       function flv_convert_get_thumb($FileName, $FileName_JPG, $FileName_FLV)
flv_convert_get_thumb('$FileName', '$FileName_JPG', '$FileName_FLV,$in, $in_sub, $in_idx, $out_thumb, $out_vid');
// code provided and updated by steve of phpsnaps ! thanks
// accepts:
// 1: the input video file
// 2: path to thumb jpg
// 3: path to transcoded mpeg?
function flv_convert_get_thumb($in, $out_thumb, $out_vid)
  // get thumbnail
$cmd = ffmpeg -v 0 -y -i '.$FileName.' -vframes 1 -ss 250 -vcodec mjpeg -f rawvideo -s 286x160 -aspect 16:9 '.$$FileName_JPG;
  $res = shell_exec($cmd);
  // $res is the output of the command
 // transcode video
  $cmd = mencoder '.$FileName_FLV.' -o '.$FileName_FLV.' -sub '.$in_sub.' -subfont-text-scale 3.0 -subpos 99 -idx '.$in_idx.' -af volume=10 -aspect 16:9 -of avi -noodml -ovc x264 -x264encopts bitrate=500:level_idc=41:bframes=3:frameref=2: nopsnr: nossim: pass=1: threads=auto -oac mp3lame';
  $Author = $_REQUEST["author"];
  $Title = $_REQUEST["title"];
  $FileName = $_REQUEST["filename"];
  $Dimension = $_REQUEST["dimension"];
  // here removed blackmailing code and added yours
  $ExecResult = flv_convert_get_thumb($FileName, $FileName.'.jpg', $FileName.'.flv');
  // end of change
    // remove the uploaded file.
  unlink(GetCurPath() . "/files/".$FileName);
    if($ExecResult == 0)
      $Conn = NULL;
      $Sql = NULL;
            $Conn = OpenDB();
      $time = date('Y-m-d H:i:s', time());
          $Duration = 0;
            $Sql = "INSERT INTO VIDEOS (AUTHOR, TITLE, DIMENSION, DURATION, ORIGINALFILE, FLVFILE, IMAGEFILE, UPLOADTIME, VIEWS) " .
       "VALUES ('".$Author."', '".$Title."', ".$Dimension.", ".$Duration.", '".$FileName."', '".$FileName.".flv', '".$FileName.".jpg', '".$time."', 1);";
        mysql_query($Sql);                     $err = mysql_error();
      mysql_close();
      if($err)
          echo "Error: " . $err . "<br>";
<li><a href="list.php">Upload Finished ! Please Press Here</a></li>
this is error given to me
Error: Table 'fvec.VIDEOS' doesn't exist
Warning: mysql_fetch_row(): supplied argument is not a valid MySQL result resource in /var/www/list.php on line 23
There are 0 videos in total
Upload my video now >>
what i'm i doing wrong here, is there missing video table in mysql ? i'm i passing the right info ? im confused as you can see i changed many things so im lost :cry:
Mysoogal
Re: mysql error
Post by Mysoogal » Sun Dec 20, 2009 6:41 am
this is dump of mysql
-- Server version: 5.0.51
-- PHP Version: 5.2.4-2ubuntu5.9
SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
-- Database: `fvec`
-- Table structure for table `videos`
CREATE TABLE IF NOT EXISTS `videos` (
  `ID` int(10) unsigned NOT NULL auto_increment,
  `AUTHOR` varchar(255) default NULL,
  `TITLE` varchar(255) default NULL,
  `DIMENSION` int(11) default '0',
  `DURATION` int(11) default '0',
  `ORIGINALFILE` varchar(255) NOT NULL,
  `FLVFILE` varchar(255) NOT NULL,
  `IMAGEFILE` varchar(255) NOT NULL,
  `UPLOADTIME` date default NULL,
  `VIEWS` int(11) default '0',
  PRIMARY KEY  (`ID`)
) ENGINE=MyISAM  DEFAULT CHARSET=latin1 AUTO_INCREMENT=5 ;
-- Dumping data for table `videos`
INSERT INTO `videos` (`ID`, `AUTHOR`, `TITLE`, `DIMENSION`, `DURATION`, `ORIGINALFILE`, `FLVFILE`, `IMAGEFILE`, `UPLOADTIME`, `VIEWS`) VALUES
(1, 'test', 'test', 1, 0, '{10DA4085-762F-90F2-35BA-C63BF1229B10}.mpeg', '{10DA4085-762F-90F2-35BA-C63BF1229B10}.mpeg.flv', '{10DA4085-762F-90F2-35BA-C63BF1229B10}.mpeg.jpg', '2009-06-17', 3),
(2, 'test', 'test', 1, 0, '{E7F7D8D1-3B97-FE8A-B440-1393A431BF76}.mpeg', '{E7F7D8D1-3B97-FE8A-B440-1393A431BF76}.mpeg.flv', '{E7F7D8D1-3B97-FE8A-B440-1393A431BF76}.mpeg.jpg', '2009-06-17', 3),
(3, 'sdf', 'sdfd', 1, 0, '{641BD967-5F5F-0B7D-B210-625D1EB70784}.mpeg', '{641BD967-5F5F-0B7D-B210-625D1EB70784}.mpeg.flv', '{641BD967-5F5F-0B7D-B210-625D1EB70784}.mpeg.jpg', '2009-06-17', 2),
(4, 'sdf', 'sdfd', 1, 0, '{641BD967-5F5F-0B7D-B210-625D1EB70784}.mpeg', '{641BD967-5F5F-0B7D-B210-625D1EB70784}.mpeg.flv', '{641BD967-5F5F-0B7D-B210-625D1EB70784}.mpeg.jpg', '2009-06-17', 3);
i dont think nothing is missing :shock:
Re: mysql error
Post by Neo » Mon Dec 21, 2009 11:49 am
There are some syntax errors. I'll point out the lines. (There can be more so you need to carefully check).
Line 27, 28:
1. Function call is out of the GetCurPath function
2. Doesn't end up with a semicolon
3. I think this function call is not required here?
4. The open bracket at Line 28 need to be removed I think
Line 30:
1. Since $FileName, etc... are vaiabled, they must be passed without quotes.
2. I think this line also need to be commented?
Line 39:
1. Missing quotes before ffmpeg.
2. At the end on line, there are two $ chars instead of one.
$cmd = ffmpeg -v 0 -y -i '.$FileName.' -vframes 1 -ss 250 -vcodec mjpeg -f rawvideo -s 286x160 -aspect 16:9 .$$FileName_JPG;
Line 45:
1. Missing quotes before mencoder.
2. Invalid parameters. I don't see in_sub, in_idx are passed.
$cmd = mencoder '.$FileName_FLV.' -o '.$FileName_FLV.' -sub '.$in_sub.' -subfont-text-scale 3.0 -subpos 99 -idx '.$in_idx.' -af volume=10 -aspect 16:9 -of avi -noodml -ovc x264 -x264encopts bitrate=500:level_idc=41:bframes=3:frameref=2: nopsnr: nossim: pass=1: threads=auto -oac mp3lame;
Line 59:
1. Is $FileName having just the name of the file? (ex: exampe)
In case it comes with the extension (Ex: example.avi), $FileName.'.jpg' will be example.avi.jpg
Finally, I can't see that you used mysql_connect function to connect to your database.
See this link.
I think you do not use a php editor with syntax highlighting. If you use 99% of these syntax error can be seen at the time of writing. Try Programmer's Notepad.
Mysoogal
Re: mysql error
Post by Mysoogal » Mon Dec 21, 2009 12:14 pm
thank you for point all those things out, i will try my best to fix it :D
Return to “Web programming”
