New Knight rider Flasher
Other Engineering Diciplines
RAT16F88
Re: New Knight rider Flasher
Post by RAT16F88 » Tue Aug 30, 2011 6:21 pm
:roll: :roll: :roll: :roll: :roll: :roll: :roll:
Smthing has gone wrong :mrgreen: :mrgreen: :mrgreen: :roll: :roll: :| :| :| :|
anyway gd wrk Rksk :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin:
Post by Rksk » Tue Aug 30, 2011 6:42 pm
RAT16F88 wrote::roll: :roll: :roll: :roll: :roll: :roll: :roll:
Thank you.Thank you.
Have you the code for your posted video?
Post by Neo » Tue Aug 30, 2011 6:51 pm
Where is the wrong? does RaT lie?
Yours seems a bit slow to me. If you have used a 4MHz oscillator as in RAT's diagram, only thing I can guess is that your Oscillator setting in code. Try these.
  1. Normally in delay.h, you have #define PIC_CLK 4000000 //4Mhz so that the delay routines work correctly.
    You can use attached Delay routines and see whether that fix the problem.
    essentials.rar
    (3.86 KiB) Downloaded 1293 times
    Edit: Changed the PIC_CLK to 4MHz
  2. If (1) doesn't seem to fix your problem, Insert this line on top of main() (if you are using HITECH C compiler).
    __CONFIG( XT & WDTDIS & PWRTDIS & BORDIS & LVPDIS & WRTEN & DEBUGDIS & UNPROTECT );
    Edit: Use HS for 8MHz and 16MHz (XT for 455KHz, 2MHz and 4MHz)
  3. If both (1) and (2) are not working, adjust the delay routines until you are satisfied. Just reduce the values (at present it is set to 300)
Reason: Adjusted the delay.h to be 4MHz
Post by Rksk » Tue Aug 30, 2011 8:21 pm
    essentials.rar
It's correct, my my one has a speed problem & your solution corrected it.
But my problem is not that. RaT's video's LEDs runing with a tail. But my video is not that, it's style is completly difference one. Watch both of videos carefully.
Thank you.
Post by Neo » Tue Aug 30, 2011 10:15 pm
Honestly I don't see any difference other than the speed. I guess the effect you see is due to the LEDs RAT has used and dark light on the video. May be my eyes are getting old just as me :lol:
Post by Rksk » Tue Aug 30, 2011 10:51 pm
Hmm...
Ho do I explain this???
RaT' Video - All the LEDs are lighted never!
My video - All the LEDs are lighted for two time in a cyle.
Thank you.
Post by Neo » Wed Aug 31, 2011 12:02 am
You are correct. Obviously RAT was running a modified version. There should be two points where you will see all the LEDs light up according to the logic submitted in the first post.
Post by Neo » Wed Aug 31, 2011 12:38 am
According to what I see, RAT only light up 4 LEDs at a time.
I was thinking to write a simplified logic for fun ;) Write the most optimised code (in C and ASM) is like my best hobby. when you also try on that, I'm sure you'll get lots of fun out of it.
Rksk, can you try these codes and let me know? Since I haven't either compiled them or run them, there can be issues (I don't have access to a PIC at the moment).
void main() {
	int i = 1, side = 0; // side is set to left-to-right at first
	TRISB = 0; // Set PORT B as all outputs
	PORTB = 0; // Set all pins off
	while(1) {
		PORTB = (side == 0) ? ((0x00F0 << i) >> 8) : (0x0F00 >> i);
		if (i++ == 12){
			i = 1;
			side ^= 1; // XOR will switch sides
			Delay_ms(300); // Since we reached end, delay a bit more
		else{
			Delay_ms(100);
If the above logic is complicated for you, try out the following one. Then I'm sure you'll be able to go for the first one which is more compact.
void main() {
	int i;
	while(1) {
		// Left to Right motion
		for (i=1; i <= 12; i++){
			PORTB = (0x00F0 << i) >> 8;
			Delay_ms(100);
		// Right to Left motion
			PORTB = 0x0F00 >> i;
			Delay_ms(100);
Post by Rksk » Wed Aug 31, 2011 5:28 pm
Neo wrote:According to what I see, RAT only light up 4 LEDs at a time.
void main() {
	while(1) {
		if (i++ == 12){
			i = 1;
		else{
			Delay_ms(100);
void main() {
	int i;
	while(1) {
			Delay_ms(100);
			Delay_ms(100);
It's cool Neo. I just compiled and simulated on Proteus. But only 1st one worked. I can't find error with 2nd one.
( my PC & JDM are doing crazy, they worked before and not working today. :shock: )
Thank you.
john122
Corporal
Corporal
Post by john122 » Thu Feb 02, 2012 5:58 pm
I like it very much.......
Return to “Other”
