How to start C Programing with Dev C++
Re: How to start C Programing with Dev C++
Post by Nipuna » Sun Oct 31, 2010 12:01 am
Tick C++ and Make Default language both.
Then the Default Compiler would be C++.
Ask Neo About C. He will tell the deference of C and C++.
As I remember Neo said that When we Write codes without Classes it would be a C Program.
And As I remember When we Add Header files.
we add
#include<iostream>
in C++
But In C We add
#include<iostream.h>
I might be wrong because I've seen some C++ codes with #include<iostream.h>
For Clear Guide ask Neo. He Knows Better Than Me about those :). I will tell you things that I know :) I am not an
Expert of the Subject.
Post by Neo » Sun Oct 31, 2010 10:12 am
#include<iostream>
in C++
But In C We add
iostream.h is a C++ header file. We don;t have that in C. In C we use, stdio.h
No difference in using with .h and without .h in C++. In C, we always need to use .h
One other interesting point is about using <> and "" for include files.
If the path is defined to the compiler already (path is known to compiler), you can use <>. But if the path is not known, then you need to mention the exact path which should go within "".
Post by Face » Sun Oct 31, 2010 5:28 pm
Thanks NIPUNA & NEO.I read your posts.Now I am trying to make that HELLO WORLD in DEV C++.I will post my first program progress soon.
Post by Face » Fri Nov 05, 2010 10:22 am
Hi friends.
I start my first programm in C++.
This is it.But I have a problem.
//first testing programm in C++ by G-sparkz
#include<iostream>
using namespace std;
int main()
    cout<<"I am learning C++!";
    return 0;
I compiled it.Its says DONE.
How can I run my code.When I do EXECUTE>RUN
Nothing happens.Just one dialog box came & wanish.
Post by Nipuna » Fri Nov 05, 2010 1:57 pm
That's Because your Program doesn't make for that. I mean it's only work is Print the Word you add and then automatically exit.
It happened to me too. I asked Neo He gave me the solution it is.
add
cin.get();
Before
 return 0;
or you can add
system("pause");
But if you add this one you Program will print this at the end of the program
Press any key to continue
But the Best thing i say to add is
cin.get();
Post by Neo » Fri Nov 05, 2010 1:58 pm
I understand the problem. There is nothing holding the output window to stay visible.
You can do two things.
  1. Easy way is, execute (Usually Ctrl+F5) the application (Not Debug which is initiated with F5 normally). In Visual C++ we have the following icons.
    Or else you can open a command window yourself and run the exe file that was compiled.
  2. Cool way is to let the program wait for a user input. So the screen will hold until you enter something.
    You can use following code.
    #include<iostream>
    int main()
        int i;
        cin >> i; // wait until a number is entered from keyboard
        return 0;
Post by Face » Fri Nov 05, 2010 4:11 pm
Wow.Cool,It works.I am loving C more & more.It feels good.:)
Post by Face » Sat Nov 06, 2010 2:35 pm
I wrote my second program in C.
here it is.
//my second testing programm in C++
#include<iostream>
int main()
    cout<<"I am learing C++  ";
    cout<<"going to test second programm";
    cin.get();
    return 0;
1.I wanna know hot to brake a line in the program.?
2.what is the different between cin.get(); & system("pause");
3.please explain the code cin >> i;
Post by Neo » Sat Nov 06, 2010 6:31 pm
There are two ways to do this.
  1. cout << "Text on first line" << endl << "Text on second line";
  2. cout << "Text on first line \nText on second line";
In C++, end/endl command is preferred since causes cout buffer to be flushed and displayed instantly to the screen.
cin.get() waits until you enter something using keyboard and press enter so it can get the input back to program.
"pause" only wait until you press any key. Try to open the command prompt and enter pause to see what it is. system("pause"); calls the same DOS thing.
As said before, cin gets an input from keyboard. Here it get the input (which should be a number) to variable i.
If you print it using following command after cin, you will understand that.
count << "I entered " << i << " from keyboard.";
Post by Face » Tue Nov 09, 2010 9:57 pm
Thanks For the help NEO.
This is my newest code.
//my third testing programm in C++
#include<iostream>
int main()
    int a,b;
   a=10;
   b=20;
    <<endl<<"going to test third programm"
    <<endl<<"my first variable test "
    <<endl<<"my variables are a & b  "<<endl;
    cout<<"this is my variable [a] = "<<a<<endl;
    cout<<"this is my varianle [b] = "<<b<<endl;
    cout<<"I nam going to add my variables"<<endl;
    cout<<"[a] + [b] = "<<a+b<<endl;
    system("pause");
    return 0;
Return to “C/C++ Programming”
