Help to learn php
Re: Help to learn php
Post by Nipuna » Wed Aug 18, 2010 12:54 pm
Neo wrote:
  1. Go into the root xampp folder and and run xampp-control.exe
  2. Before doing anything, ensure that nothing is automatically set to run as a service, you'll need to check in two places. First, make sure the "svc" check boxes are unchecked next to each xampp component item. Second, click the Settings... button in the Control Panel, and make sure that no boxes are check in the Settings area. Click OK to return to the main Control Panel view.
  3. To turn Apache and MySQL on/off, simply click the respective start/stop buttons for each component. The buttons will change state depending on the status of the component. Figure 2 shows the Control Panel with both Apache and MySQL running.
  4. You can make a shortcut of xampp-control.exe on your desktop and start services whenever you want
The attachment Xampp.png is no longer available
Personally I do not run XAMPP, I use WAMP which is easily configurable than any other Apache/MySQL/PHP bundle on Windows.
There is no Setting button in my Xampp Control panel. Is it the setup button i tried it but it shows a command prompt with some messages
Reason: Placed image inline
Post by Neo » Wed Aug 18, 2010 1:38 pm
You are using a newer version. I'm not running XAMPP so you need to play around with it. Install WAMP which is much easier to handle.
Post by Nipuna » Wed Aug 18, 2010 1:54 pm
Neo wrote:You are using a newer version. I'm not running XAMPP so you need to play around with it. Install WAMP which is much easier to handle.
I found the way now it's working in my way?
Post by Nipuna » Wed Aug 18, 2010 4:29 pm
It shows Information about PHP
I think PHP is working how to Start Coding and checking them?
Post by Neo » Wed Aug 18, 2010 4:53 pm
There are some php tutorials in ROBOT.LK. Also try to find some good ones like w3schools, etc...
Start with the little code I have added earlier which will assure that php is working.
Make sure you place the file inside "www root" of XAMPP.
Post by Rksk » Wed Aug 18, 2010 10:08 pm
Hi nipuna,
there are many php codes that can be uses of php www.phpclasses.org
also subcribe to their daily news letter, it will give u news.
Post by Nipuna » Thu Aug 19, 2010 5:59 pm
Rksk Ekanayaka wrote:Hi nipuna,
there are many php codes that can be uses of php http://www.phpclasses.org
Thanks Friends
Post by Rksk » Fri Aug 20, 2010 9:37 pm
what is the use of joomla?
Post by Nipuna » Sat Aug 21, 2010 1:44 pm
Rksk Ekanayaka wrote:what is the use of joomla?
It's a Content management System.According to my Knowledge, We can Build Quality web Sites with that
Return to “???????? ?????”
