If you are experiencing a Virtualmin or Webmin login issue with a CloudFlare CDN enabled domain, even after changing the port to an allowed port by CloudFlare, you probably need to disable Rocket Loader for the login page with a page rule.
Just go to page rules in CloudFlare, add you login url, select Rocket Loader and make it off.
If this helps someone, please don't forget to leave a comment.
- It is currently Fri Nov 06, 2026 12:35 am
Virtualmin Webmin login issues with CloudFlare CDN
