i want read and write this ic numbers , atmel family
AT28C64B , 93C46B , AT89C2051-24PI , AT27C040 [SMD type], AT28C64E [SMD type]
& AM29F010
match ??? programmer1 ????????? ??????? ???????? ????? ???? idea 1?? ?????.
thanx
Atmel Programmer
- Sergeant Major
Re: Atmel Programmer
Check this out AVR JTAGICE mkII. This is the best I know which can programme multiple uCs without any problem.
Note: There are clones ones for less price.
- SemiconductorCat
- Major
Hi, This thread is old , so I don't think I'm hijacking this.
can't use any JTAG interface in general in it's SPI mode?
Is Oct 02, 2011 old?
Are you referring ISP mode? Some JTAGs such as Atmel JTAGICE MKii supports both JTAG, ISP and DebugWire. In some cases of Atmel, to enable DebugWire, it is required to connect SPI pins to the JTAG module to fuse but I don't think you mention that. When you buy a JTAG, you will have to read carefully on the specification on supporting devices and interfaces.can't use any JTAG interface in general in it's SPI mode?
Please contact TRONIC.LK for IC duplication services.
