i'm having issue with php / "" '' etc
Mysoogal
Post by Mysoogal » Fri Dec 25, 2009 12:30 pm
i'm trying to code a video streaming script based on videolan plugin, and ssh to do the backend ffmpeg,mencoder etc
i'm done so far a index.php which lists thumbnails and file url
but im stuck here
<a href="#" onclick="vlc_controls.play('http://code.revolunet.com/VLCjs/rambo.mpg')">rambo trailer</a>
my issue is how to enable the onclick vlc in this section of code
echo "<div class=\"photo\"><a href=\"movies/$file.mkv\"><span></span><img src=\"data/$file\" alt=\"$file\" /></a>       </div> ";
i've tried to code it like this but doesnt work
echo "<div class=\"photo\>]<a href=\"movies/$file.mkv\" onclick=\"vlc_controls.play(movies/$file.mkv)\">$file</a><span></span><img src=\"data/$file\" alt=\"$file\" /></a>       </div> ";
but its just gives me issues, im not sure how to put the \ into the vlc onclick :cry:
please advice me on this
thank you
Mysoogal
Re: i'm having issue with php / "" '' etc
Post by Mysoogal » Fri Dec 25, 2009 12:33 pm
Mysoogal
Post by Mysoogal » Fri Dec 25, 2009 1:57 pm
i got it to work after all lol took me such long time
echo " <div class=\"photo\">
        <a href=\"#\" onclick=\"vlc_controls.play('http://89.238.172.210/movies/$file.mkv')\">
        <span>
        </span>
        <img src=\"data/$file\" alt=\"$file\" /> </a>
        </div> ";
Mysoogal
Post by Mysoogal » Fri Dec 25, 2009 2:03 pm
does anybody know why that above code is not working on firefox ? :cry:
it works on IE8 and IE7 why not firefox ?
Post by Neo » Sun Dec 27, 2009 11:14 am
Hello! thought all are out for vacation :)
There are many differences between firefox and IE in parsing CSS files.
Fix CSS Div incompatibility in Firefox is added as an example.
In addition to that make sure when you use php for a css file you need to add the following at the top of the file:
<?php header("Content-type: text/css"); ?>
Mysoogal
Post by Mysoogal » Sun Dec 27, 2009 12:38 pm
thanks,top my menu had div and would overflow in ff.
thanks for fix :D
Return to “PHP & MySQL”
