* Description: This example shows how to upload and download files from a FTP
* server. The example configures the module to use FTP funtions, uploads a file
* to the FTP server and then downloads the content of the uploaded file and shows
* it. This example only shows the AT commands (and the answers of the module)
* used to use the FTP funtion and how work the FTP functions. For more
* information about the AT commands, refer to the AT command manual.
* Copyright (C) 2013 Libelium Comunicaciones Distribuidas S.L.
* http://www.libelium.com
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* Version 0.2
* Author: Alejandro Gallego
int8_t answer;
int onModulePin = 2;
char aux_str[30];
char incoming_data[120];
char test_str[ ]= "0000000011111111222222223333333344444444555555556666666677777777000000001111111122222222333333334444";
int data_size, aux;
void setup(){
pinMode(onModulePin, OUTPUT);
Serial.begin(115200);
Serial.println("Starting...");
power_on();
delay(5000);
Serial.println("Connecting to the network...");
while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500)
|| sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );
configure_FTP();
uploadFTP();
downloadFTP();
Serial.print("Incoming data: ");
Serial.println(incoming_data);
void loop(){
void configure_FTP(){
sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"APN\",\"APN\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"USER\",\"user_name\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"PWD\",\"password\"", "OK", 2000);
while (sendATcommand("AT+SAPBR=1,1", "OK", 20000) != 1);
sendATcommand("AT+FTPCID=1", "OK", 2000);
sendATcommand("AT+FTPSERV=\"ftp.yourserver.com\"", "OK", 2000);
sendATcommand("AT+FTPPORT=21", "OK", 2000);
sendATcommand("AT+FTPUN=\"user_name\"", "OK", 2000);
sendATcommand("AT+FTPPW=\"password\"", "OK", 2000);
void uploadFTP(){
sendATcommand("AT+FTPPUTNAME=\"file_name\"", "OK", 2000);
sendATcommand("AT+FTPPUTPATH=\"/path\"", "OK", 2000);
if (sendATcommand("AT+FTPPUT=1", "+FTPPUT:1,1,", 30000) == 1)
data_size = 0;
while(Serial.available()==0);
aux = Serial.read();
do{
data_size *= 10;
data_size += (aux-0x30);
while(aux != 0x0D);
if (data_size >= 100)
if (sendATcommand("AT+FTPPUT=2,100", "+FTPPUT:2,100", 30000) == 1)
Serial.println(sendATcommand(test_str, "+FTPPUT:1,1", 30000), DEC);
Serial.println(sendATcommand("AT+FTPPUT=2,0", "+FTPPUT:1,0", 30000), DEC);
Serial.println("Upload done!!");
else
sendATcommand("AT+FTPPUT=2,0", "OK", 30000);
else
else
Serial.println("Error openning the FTP session");
void downloadFTP(){
int x = 0;
sendATcommand("AT+FTPGETNAME=\"file_name\"", "OK", 2000);
sendATcommand("AT+FTPGETPATH=\"/path\"", "OK", 2000);
if (sendATcommand("AT+FTPGET=1 ", "+FTPGET:1,1", 30000) == 1)
do{
if (sendATcommand2("AT+FTPGET=2,50", "+FTPGET:2,", "+FTPGET:1,", 30000) == 1)
data_size = 0;
do{
data_size *= 10;
}while(aux != 0x0D);
Serial.print("Data received: ");
Serial.println(data_size);
if (data_size > 0)
while(Serial.available() < data_size);
Serial.read();
for (int y = 0; y < data_size; y++)
incoming_data[x] = Serial.read();
x++;
incoming_data[x] = '\0';
else
Serial.println("Download finished");
else if (answer == 2)
Serial.println("Error from FTP");
else
Serial.println("Error getting the file");
data_size = 0;
}while (data_size > 0);
else
void power_on(){
uint8_t answer=0;
// checks if the module is started
answer = sendATcommand("AT", "OK", 2000);
if (answer == 0)
digitalWrite(onModulePin,HIGH);
delay(3000);
digitalWrite(onModulePin,LOW);
while(answer == 0){ // Send AT every two seconds and wait for the answer
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
uint8_t x=0, answer=0;
char response[100];
unsigned long previous;
memset(response, '\0', 100); // Initialize the string
delay(100);
while( Serial.available() > 0) Serial.read(); // Clean the input buffer
Serial.println(ATcommand); // Send the AT command
x = 0;
previous = millis();
// this loop waits for the answer
do{
if(Serial.available() != 0){
// if there are data in the UART input buffer, reads it and checks for the asnwer
response[x] = Serial.read();
//Serial.print(response[x]);
x++;
// check if the desired answer is in the response of the module
if (strstr(response, expected_answer) != NULL)
answer = 1;
// Waits for the asnwer with time out
while((answer == 0) && ((millis() - previous) < timeout));
return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
char* expected_answer2, unsigned int timeout){
char response[100];
delay(100);
x = 0;
do{
x++;
// check if the desired answer 1 is in the response of the module
if (strstr(response, expected_answer1) != NULL)
answer = 1;
// check if the desired answer 2 is in the response of the module
if (strstr(response, expected_answer2) != NULL)
answer = 2;
}while((answer == 0) && ((millis() - previous) < timeout));
return answer;
