S22A350H has HDMI, I think that H is for HDMI. S22A350B has DVI. On the box of S22A350H there is a label saying that it is only for sale in Singapore. But you can buy it here.
S22350H is 2ms response time too. Has lot of good value added features.
Have you enabled Clear Type (Display properties -> Appearance -> Effects -> Use following method to smooth edges of screen fonts -> clear Type)?Monitor is Great TooWeb sites Rending Very well a Normal. But with Windows Fonts And ROBOT.LK Emoticons I can see non smooth Edges
I don't think it is a good decision to reduce resolution.I tried all the Resolution settings. Now I using 1280x720 Since in1920x1080 Things are so SmallI mean Desktop and Icons and etc.....
When connected via an analogue connection, an LCD is vulnerable to the same distortions that affect CRT monitors. However, when connected via a digital connection, often labelled DVI (for Digital Visual Interface), no digital-to-analogue conversion is required, and there should be no loss or corruption of the signal. As a result, when running at its native resolution, an LCD should give you a cleaner and crisper image than you'd see on a CRT.I have Intel G31 On-board Graphic card and I use Monitor with Analog VGA Cable not HDMI.
Is the Graphic card the Problem? I can remember something like that Herath Said.
Windows 7 Thanks to youHerath wrote:By the way, if you use a non native resolution of the LCD panel, thing will not look the best. So using 1920x1080 is recommended. Are you using windows 7 or windows xp?.
