Bellow is the commands that I've invoked.
#cd /root/qemu-1.7.0/
# ./configure --target-list=arm-softmmu --enable-sdl
#make all
#make install
Install prefix /usr/local
BIOS directory /usr/local/share/qemu
binary directory /usr/local/bin
library directory /usr/local/lib
libexec directory /usr/local/libexec
include directory /usr/local/include
config directory /usr/local/etc
local state directory /usr/local/var
Manual directory /usr/local/share/man
ELF interp prefix /usr/gnemul/qemu-%M
Source path /root/qemu-1.7.0
C compiler cc
Host C compiler cc
C++ compiler c++
Objective-C compiler clang
ARFLAGS rv
CFLAGS -O2 -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=2 -g
QEMU_CFLAGS -fPIE -DPIE -m32 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -Wstrict-prototypes -Wredundant-decls -Wall -Wundef -Wwrite-strings -Wmissing-prototypes -fno-strict-aliasing -Wendif-labels -Wmissing-include-dirs -Wempty-body -Wnested-externs -Wformat-security -Wformat-y2k -Winit-self -Wignored-qualifiers -Wold-style-declaration -Wold-style-definition -Wtype-limits -fstack-protector-all -I/usr/include/p11-kit-1 -I/usr/include/libpng12 -I/usr/include/pixman-1 -I$(SRC_PATH)/dtc/libfdt
LDFLAGS -Wl,--warn-common -Wl,-z,relro -Wl,-z,now -pie -m32 -g
make make
install install
python python -B
smbd /usr/sbin/smbd
host CPU i386
host big endian no
target list arm-softmmu
tcg debug enabled no
gprof enabled no
sparse enabled no
strip binaries yes
profiler no
static build no
-Werror enabled no
pixman system
SDL support yes
GTK support no
curses support yes
curl support yes
mingw32 support no
Audio drivers oss
Block whitelist (rw)
Block whitelist (ro)
VirtFS support no
VNC support yes
VNC TLS support yes
VNC SASL support no
VNC JPEG support yes
VNC PNG support yes
VNC WS support yes
xen support no
brlapi support no
bluez support yes
Documentation yes
GUEST_BASE yes
PIE yes
vde support no
Linux AIO support no
ATTR/XATTR support yes
Install blobs yes
KVM support yes
RDMA support no
TCG interpreter no
fdt support yes
preadv support yes
fdatasync yes
madvise yes
posix_madvise yes
sigev_thread_id yes
uuid support no
libcap-ng support no
vhost-net support yes
vhost-scsi support yes
Trace backend nop
Trace output file trace-<pid>
spice support no (/)
rbd support no
xfsctl support no
nss used no
libusb no
usb net redir no
GLX support yes
libiscsi support no
build guest agent yes
QGA VSS support no
seccomp support no
coroutine backend ucontext
coroutine pool yes
GlusterFS support no
virtio-blk-data-plane no
gcov gcov
gcov enabled no
TPM support no
libssh2 support yes
TPM passthrough no
QOM debugging yes
vhdx no
wiki.osdev.org/ARM_Integrator-CP_PL110_Dirty
typedef int(*PFN)(void);
void start(void);
void __attribute__((naked)) entry()
__asm__("mov sp, #0x60 << 8");
__asm__("bl start");
#define PL110_CR_EN 0x001
#define PL110_CR_PWR 0x800
#define PL110_IOBASE 0xc0000000
#define PL110_PALBASE (PL110_IOBASE + 0x200)
typedef unsigned int uint32;
typedef unsigned char uint8;
typedef unsigned short uint16;
typedef struct _PL110MMIO
uint32 volatile tim0; //0
uint32 volatile tim1; //4
uint32 volatile tim2; //8
uint32 volatile d; //c
uint32 volatile upbase; //10
uint32 volatile f; //14
uint32 volatile g; //18
uint32 volatile control; //1c
} PL110MMIO;
void start(void)
PFN fn;
PL110MMIO *plio;
int x;
uint16 volatile *fb;
plio = (PL110MMIO*)PL110_IOBASE;
/* 640x480 pixels */
plio->tim0 = 0x3f1f3f9c;
plio->tim1 = 0x080b61df;
plio->upbase = 0x200000;
/* 16-bit color */
plio->control = 0x1829;
fb = (uint16*)0x200000;
for (x = 0; x < (640 * 480) - 10; ++x)
fb[x] = 0x1f << (5 + 6) | 0xf << 5;
/* uncomment this and the function pointer should crash QEMU if you set it for 8MB of ram or less */
for(;;);
fn = (PFN)0x800f20;
fn();
return;
# ./gcc-arm test.c -nostdlib -o test.o
# ./objcopy-arm -j .text -O binary test.o test.bin
# qemu-system-arm -m 8 -kernel test.bin
Could somebody kindly please review where had gone wrong.
I've also run with the '-M verstailepb' option too, where giving the softmmu specific board.But nothing happens either. Is that PL110 controller is emulating there or is that old cypress PCI vga card still there? Is anyway to verify that?
I've run that UASRT example with --no-graphics option and it works fine. But the problem is using the graphics LCD display.
Could somebody who have experience in real-versatilepb ? could you kindly run this code on it? Or any suggestion where it gone wrong?
