Go ahead & follow my blog <link removed> you'll find the circuit diagram to build a programmer then
download MPlab too , Better Start with a Simple PIC like PIC 16f84a thts how I started
Good luck
also follow the datasheet of 16f84a care fully I ll Update u for the 1st project
U need a bit of common sense thats all (i assume u've burnt ur fingers with a soldering Iron -i mean ur not new to tronic s)
ANY BIGINERS TO PIC's
Reason: Link removed by admin
Re: ANY BIGINERS TO PIC's
Please be kind to leave a comment thats a big enthusiasm
Only submit questions here. We don't allow anybody to do any type of marketing in technical topics
However, you can brief about your site and add a link under Member Area -> Member Advertising.
ROBOT.LK is backed with a set of qualified engineers so hope you don't waste their time on submitting non-question posts here. Hope you'll understand
We have a separate section for Microcontrollers.
See Engineering ‹ Embedded Processors & Programming ‹ Microcontrollers
See Multi PIC programmer to make a programming unit.
See my article How to start with Microcontrollers which has a complete list of steps to begin with micros.
You may also see following 16F84 experiments.
16F84 Sample LED Circuit Diagram
Musical DoorBell with PIC16F84A
PIC Traffic Lights Controller with PIC16F84A
Be with us and get the full use of it..... Good luck!!!
Oh I'm sorry I thought It would Be really Simple for any biginner to swallow & follow Thts why I put up all my work I done when I was In 10th Grade On a blog & Put it here 'sorry again I 'm new here ,Thank U for Informing ME, Sorry Again
No problem... please enjoy the forum
THANKS I WAS So DWN SEEING IT Thanks for upliftment
If you read Terms of use carefully, you wouldn't have ended up with unnecessary unpleasantness. See point (7).
- Corporal
hii
muti pic programmer is not working pls help
It works perfectly. We make them locally and as said in the previous post let me have your address then I'll let you know the payment instructions.
