>> At what time will this bit become 0(clear)?give me a small example.
If your addition or subtraction operation like ( ADDLW , SUBLW etc ...) will product a result don't produce a carry.
ex:
Where we load the register with 1 and , add with another 1.
To understand carry, you have to go back to and find out how a ripple adder works.
http://en.wikipedia.org/wiki/Adder_(electronics)
So when your arithmetic operation does not produce a carry out from the register , that bit will be cleared out.
Every arithmetic instruction will update those flags , Z , C and DC.  So if you need to use these bits
you have to do it right just after that arithmetic instruction.
The status of those bits ,just after you turn on microcontroller is defined in the manual clearly.
It may be 1, 0, undefined or high Z status. (where high Z referred to high impedance state).
Bellow figure describes the different values of bits in registers , just after power on, reset and
wake from sleep.
Now you could learn to read the manual.
