mata oni gmail ekakin eana mails block karanna. komada eaka karanne???
______
Sthuthi..
How to block email address (Gmail)
Re: How to block email address (Gmail)
???? gmail ????? ?? email ???? block ????? ???. ?? ???.
??? use ???????? gmail ???, ??? ????? ?????? ??????? ?????.
- Follow the Create a filter link (Options -> Mail Settings -> Filters).
- Type the desired email address in From: box.
- You can block an entire domain by entering just that. (To block all mail from both [email protected] and [email protected], type "@spamdomain.com").
- To block more than one address, separate them with "|" (the vertical bar; typically above the backslash on the keyboard; not including the quotation marks). You can block both [email protected] and [email protected] by typing "[email protected]|[email protected]", for example.
- Click Next Step
- Make sure Delete it is checked under Choose action.
- Check Also apply filter to xx conversations below to delete previously received messages.
- Click Create Filter.
