Uninstall ?????? ?? "Could not Open Install.Log File" ??????
Post by Neo » Sat Aug 20, 2011 12:20 am
  1. Open the directory where the program is installed. (Eg. For System Mechanic 5, By default, it is C:\Program Files\iolo\System Mechanic 5, if you have installed XP on C:\)
  2. You will see a file named “Install.log” in there
  3. Move (cut and paste somewhere else) the “install.log” to say an empty new folder in desktop (first create a new folder and then paste the install.log into it)
  4. Now, double click the un-installer (uninstall.exe or unwise.exe)
  5. It will ask you to open the installation log. Locate to the “install.log” file on your desktop
  6. Now, uninstall will work fine and you can un-install the program
Alternate Procedure
You can simply drag the install.log to unwise.exe or uninstall.exe and it should work
Return to “???????? ?????”
