host ms sql database
kauru hari sql database eakak host karana widiya dannawada???
Re: host ms sql database
?? ???? ???? ?????. ??? ????? ????? ??????????? ??? ?????? ?? ????? topic ???? setup ???. ??? ?????: MySQL database ???? cPanel ????? setup ?????? ???????
Sorry Neo mata one Microsoft sql database eakak host karana widiya danna ganna.......
Nadeeka,
I guess you are referring Microsoft SQL Server. Microsoft SQL Server is a commercial server and only be hosted with Windows Hosting. When it comes to Web Hosting, the commonly known best combinations is Linux/PHP/MySQL.
See my note...
Godaddy Windows Hosting with MS SQL 2008 R2
1 Database x 200 MB*: $5.99
2 Databases x 200 MB*: $7.99
Unlimited Databases x 200 MB*: $14.99
*Each database can't exceed 200MB with them
SQL Server Mart - $6.99/month
2 Databases x 4GB (Supports SQL Server 2008 R2 or SQL Server 2005 or SQL Server 2000)
SQL Server Management Studio Access
SQL Server over SSL
But my advise is to move to MySQL if you have plans to work on web development in future.
See my note...
However if you still want Windows Hosting that supports SQL Server (Which is expensive due to commercial licensing requirements and not used widely), let me suggest you some sites. I doubt you will find a free service due to Microsoft commercial License requirements.Web ??? ??? ????? ??????? ?????? MySQL ???? ???? ?? ?? explain ???
SQL Server over SSL
Thanks Neo.....
namuth mata web application develop kereema pilibada danuma bohoma adui..
_________
_________
_________
_________
????? ??? ??????? ??? local SQL Server setup ???? ???????? ???????
?? ?????? ????????? SQL Server ?? ??? ???. ?? ???? ???? ??? ????? ?? ?????? ??? DBMS ????.
???? ????? ???????? SQL Server ????? ???? Windows Server OS ?? ???? ?? ???, ??? ?? link ?? ?????.
http://msdn.microsoft.com/en-us/library/ms143506.aspx
???? ??????, ???? ?? versions ????? ???????.
SQL Server 2008 R2 Standard (64-bit) x64
SQL Server 2008 R2 Standard (32-bit)
SQL Server 2008 R2 Developer (64-bit) x64
SQL Server 2008 R2 Workgroup (64-bit) x64
SQL Server Developer (32-bit)
SQL Server Workgroup (32-bit)
SQL Server Express (32-bit), Express with Tools, and Express with Advanced Services (32-bit)
????? MSDE ?????? ??????? Microsoft SQL Server 2000 Desktop Engine ????? ?????? light weight version ???? ???????. Try ???? ?????.
http://www.microsoft.com/download/en/de ... x?id=22661
Naha.. mata sql server thiyana. but mama try karanne sql host karala branch eakaka idan connect karanna puluwannda balanna...... (mama database eaka host karala / asp.net application eakakin ea host karapu db eakata connect wena eaka thama aramuna.)
______
______
??? network setup ????? ???????? ??? real environment ???? ??? ????? ??????? ????
??? ??? ??? Static IP ???? ???? internet through ???????.
???? DynDNS use ???? dynamic IP ???? website ???? host ????? ??????? ???????? ???????. ?? ?????? ???? ?? ????? ?????? ???? setup ?????? ?? ???? ????. ?? ????????? ???? Kandy ?? ????? office ??? ??????? ??? link ???? use ???? ??? ????? access ????? ???????.
?? article ?? ???? setup ??????.
How to access website hosted in localhost from internet
SQL Server ports ???? ?? ?????? forward ?????? ???.
?? ???????? ???? ??????? SQL Server ?? access ?????? ???????.
Good luck!
Good luck!
