You can use WeekdayName for this.
strDOW = WeekdayName(6) will put "Friday" to strDOW.
Note: You can use MonthName function to return month as a string as well.
Try out these to get a good idea:
Print "Now:"; Tab(30); Now
Print "Using DateValue:"; Tab(30); DateValue(Now)
Print "Using TimeValue:"; Tab(30); TimeValue(Now)
Print "Using Weekday:"; Tab(30); Weekday(Now)
Print "Using WeekdayName:"; Tab(30); WeekdayName(Weekday(Now))
Print "Using WeekdayName (abbrev.):"; Tab(30); WeekdayName(Weekday(Now), True)
Print "Using Month:"; Tab(30); Month(Now)
Print "Using MonthName:"; Tab(30); MonthName(Month(Now))
Print "Using MonthName (abbrev.):"; Tab(30); MonthName(Month(Now), True)
Print "Using Day:"; Tab(30); Day(Now)
Print "Using Year:"; Tab(30); Year(Now)
Print "Using Hour:"; Tab(30); Hour(Now)
Print "Using Minute:"; Tab(30); Minute(Now)
Print "Using Second:"; Tab(30); Second(Now)
If you are looking to get a part of date, have a look at following example:
Print "Current date/time is: "; Format$(Now, "Long Date"); Spc(1); Format$(Now, "Long Time")
Print "*** DatePart Function Examples ***"
Print "Using 'yyyy':"; Tab(20); DatePart("yyyy", Now)
Print "Using 'q':"; Tab(20); DatePart("q", Now)
Print "Using 'm':"; Tab(20); DatePart("m", Now)
Print "Using 'y':"; Tab(20); DatePart("y", Now)
Print "Using 'd':"; Tab(20); DatePart("d", Now)
Print "Using 'w':"; Tab(20); DatePart("w", Now)
Print "Using 'ww':"; Tab(20); DatePart("ww", Now)
Print "Using 'h':"; Tab(20); DatePart("h", Now)
Print "Using 'n':"; Tab(20); DatePart("n", Now)
Print "Using 's':"; Tab(20); DatePart("s", Now)
I think that's all about VB date/time
