I did it using below mwthod, but I think it isn't a good solution.
1. Select data from mysql and print data using php as below,
$user = '1';
$q=mysql_query("SELECT id,time,user_id,text FROM posts WHERE user_id = '$user' ORDER BY id");
while ($post = mysql_fetch_array($q))
echo $post['id'].",".$post['time'].",".$post['user_id'].",".$post['text']."||";
Dim mydb As Database
Dim myrs As Recordset
Dim s, s2 As String
Dim sItems() As String
Dim sItems2() As String
Set mydb = OpenDatabase("data.mdb")
Set myrs = mydb.OpenRecordset("posts", dbOpenTable)
s = InternetGetFile("http://mydomain.com/myscript.php")
sItems() = Split(s, "||")
Dim X As Integer
For X = 0 To UBound(sItems)
sItems2() = Split(sItems(X), ",")
myrs.AddNew
myrs.Fields("id") = sItems2(0)
myrs.Fields("time) = sItems2(1)
myrs.Fields("user_id") = sItems2(2)
myrs.Fields("text") = sItems2(3)
myrs.Update
Next X
I hope you will have another idea to do this.
Please help me.
Thankz,
Rksk.
