Declarations:
Const MAX_PATH = 255
Private Declare Function GetTempPath Lib "kernel32" _
Alias "GetTempPathA" (ByVal nBufferLength As Long, _
ByVal lpBuConst MAX_PATH = 255Code: Select all
Public Function GetTempDir() As String
    Dim sRet As String, lngLen As Long
    'create buffer
    sRet = String(MAX_PATH, 0)
    lngLen = GetTempPath(MAX_PATH, sRet)
    If lngLen = 0 Then err.Raise err.LastDllError
    GetTempDir = Left$(sRet, lngLen)
End FunctionUser's profile path
Declarations:
Private Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
Private Declare Function GetWindowsDirectory Lib "kernel32" Alias "GetWindowsDirectoryA" (ByVal lpBuffer As String, ByVal nSize As Long) As LongCode: Select all
' Return the user's profile path.
Private Function ProfilePath() As String
Dim win_dir As String
Dim user_name As String
Dim ret_len As Long
    ' Get the windows directory.
    win_dir = Space$(256)
    ret_len = GetWindowsDirectory(win_dir, Len(win_dir))
    win_dir = Left$(win_dir, ret_len)
    ' Get the user's name.
    user_name = Space$(256)
    GetUserName user_name, ret_len
    user_name = Left$(user_name, ret_len)
    ProfilePath = win_dir & "\" & user_name
End FunctionDeclarations:
Private Declare Function GetSystemDirectory Lib "kernel32" Alias "GetSystemDirectoryA" (ByVal lpBuffer As String, ByVal nSize As Long) As LongCode: Select all
Private Sub Form_Load()
Dim buf As String * 256
Dim return_len As Long
Dim wid1 As Single
Dim wid2 As Single
    return_len = GetSystemDirectory(buf, Len(buf))
    lblSystemDirectory.Caption = Left$(buf, return_len)
    return_len = GetWindowsDirectory(buf, Len(buf))
    lblWindowsDirectory.Caption = Left$(buf, return_len)
    wid1 = lblWindowsDirectory.Left + _
        lblWindowsDirectory.Width + Label1(0).Left
    wid2 = lblSystemDirectory.Left + _
        lblSystemDirectory.Width + Label1(0).Left
    If wid1 > wid2 Then
        Width = Width - ScaleWidth + wid1
    Else
        Width = Width - ScaleWidth + wid2
    End If
End Sub
