Solder Mat Heat Resistant Repair Station 28x20x0.5cm
CH341A 24 25 Series EEPROM Flash BIOS USB Programmer
FDP047N08 N-Channel PowerTrench MOSFET 75V 164A
MPU9255 9-DOF 3-Axis Acceleration Gyroscope Magnetometer
DS18B20 Temperature Sensor Module KY-001
Car Charger USB Dual Output 3.6A with Cable C308 (Good Quality)
24V 5A SMPS Power Supply Metal Casins
5V 10A SMPS Power Supply Metal Casing
Solder Wire Lead Roll 60/40 1.0mm 50g High Quality
Robot Wheel with Coupling
Fan Blades for Quadcopter Drone D:150mm EP-6035
TA8248K Low Frequency Power Amplifier
2N60 600V 2A N-Channel MOSFET
Z0607 800mA Triac
USB Socket Female Type B SMD
Aluminum Heat Sink 21x15x10mm TO220
Toroid Ferrite Core 16x8x5mm for Inductor Coil
470uF 400V Capacitor
Digital Audio Optical Cable 1.5m
TV Remote Control Universal LED/LCD RM-L930
2SC5885 Silicon NPN Triple Diffusion Power Transistor
2SC4138 Silicon NPN Triple Diffused Planar Transistor
IRFP4227 HEXFET Power MOSFET
IRFP260N HEXFET Power MOSFET
2N7000 Small Signal MOSFET 60V 200mA
USB Socket Male Type A PCB Mount
39 Ohm 1/4W Resistor 5%
47 Ohm 1/2W Resistor 5%
LB1405 Level Meter
M51132L 2-Channel Electronic Volume Balance
TL071 Low Noise JFET Input General Purpose Operational Amplifier
LM2917N Frequency to Voltage Converter
Nextion 5 inch Enhanced HMI Intelligent Serial LCD Module Display
Nextion 4.3 inch Enhanced HMI Intelligent Serial LCD Module Display
USB WIFI Dongle 600Mbps
5VDC 8 Way 8 Channel Relay Module with IR Infrared Remote Control
Nextion 2.8 inch Enhanced HMI Intelligent Serial LCD Module Display
Nextion 2.4 inch Enhanced HMI Intelligent Serial LCD Module Display
BeagleBone Black Rev C 1GHz ARM Cortex-A8 512MB DDR3 4GB 8bit eMMC Board Mini PC
Official Raspberry Pi Camera V2.1 Sony IMX219 Sensor 8 Megapixel
SIM7000E 4G NB-IoT / 4G eMTC / EDGE / GPRS / GNSS LTE HAT Module for Raspberry Pi
SIM5320E 3G GSM GPRS GPS Module
5VDC 16 Way 16 Channel Relay Module With Coupling Protection
IO Expansion Board for Nextion Enhanced HMI LCD Display
M590E GSM GPRS DIY Module 900-1800MHz
12VDC 2 Way 2 Channel Relay Module with DB9 Serial Port RS232 Interface
12VDC 4 Way 4 Channel Relay Module with DB9 Serial Port RS232 Interface
UPC1237H?A Stereo Amplifier Protection IC
DSO138 Digital Oscilloscope 1Msps with 2.4" TFT Display and Probe
NodeMCU ESP-32S Wifi Bluetooth Module with 0.96" OLED Display CP2102
Battery Shield V3 for 18650
BMI160 6-axis 6DOF Gyro Accelerometer Gravity Module IIC SPI
2.7inch EInk Epaper Display Module Three Color for Raspberry Pi SPI interface
Motor Shaft Coupler Flexible Couplings Aluminium 5x8mm for 3D Printer
TB6560 3A CNC Router Single 1 Axis Controller Stepper Motor Driver Module
Nextion 3.2 inch Enhanced HMI Intelligent Serial LCD Module Display
2 DOF Pan and Tilt Servo Mount Kit MG995 MG996
NodeMCU D1 ESP-12E ESP8266 Wifi Module with 0.96 inch OLED Display and 18650 Battery Holder
Double BTS7960B DC 43A Stepper Motor Driver H-Bridge PWM
UPC1188H Stereo Amplifier Protection IC
XL6009 3-32V to 5-35V 4A DC to DC Adjustable Step-Up Boost Power Supply Module
24C16 Serial 16K EEPROM
CC2541 HM-10 Bluetooth 4.0 BLE UART Transceiver Module with Adapter
24C04 Serial 4K EEPROM SMD
STM32F030F4P6 ARM Cortex-M4 32bit MCU Core Development Board
Acrylic Case Enclosure for DSO138 Oscilloscope
M27C160-50F1 EPROM UV 16MBIT M27C160
ADS1015 ADC DAC 12bit Precision Module BRPI
Bluetooth Serial Adapter Board for HC05 HC06 HC07 BC04 V1.2PRO
NodeMCU ESP-32 WiFi Bluetooth with 0.96 inch OLED Display Yellow & Blue CP2102 18650 Battery Holder
NodeMCU ESP-12E ESP8266 Wifi Module with 0.96" OLED Display CP2102
TB6600HG Stepper Motor Driver TOSHIBA JAPAN
PCF8574T 8-bit IO Extension Module IIC I2C with Dip Swithes
5VDC 8 Way 8 Channel Relay Module with Bluetooth HC-06
GY-271 HMC5883L 3-Axis Compass Magnetometer Module
A2212/13T 1000KV Brushless Outrunner Motor for RC Airplane Aircraft Quadcopter
HSCDTD008A 3 Axis Compass Magnetometer Module
Flame Detector Alarm Relay Module Board 5VDC
TEC1-12706 DC12V 60W Peltier Thermoelectric Cooler
Complete TEA5767 FM Stereo Radio Module 76-108MHZ with Antenna
Aluminum Heat Sink 19x15x10mm TO220 Black
High Voltage Tester AC Digital LED Volt Pen 90-1000V with Torch
Voltage Tester with LCD Display AC DC
USB to SATA 22 Pin Adapter Cable For 2.5 inch External Hard Disk Drive
USB to SATA/PATA/IDE Adapter For 2.5/3.5 inch Hard Disk Drive (Without Power Adapter)
USB Bluetooth Dongle V4.0 20M 3Mbps Dual Mode
TB6600 1 Axis 4A Stepper Motor Driver Controller 9-40V Micro-Step
P6100 Oscilloscope Probe 6-100MHz
1.5V AG4 LR626H 377A Alkaline Battery
TV Antenna Jack Right Angle Female Coaxial Connector
SPST Toggle Switch 3-Pin 125VAC 6A
Miniature 2 Way 3 Pin Slide Switch
Digital Voltmeter 4.5-30V 2 Wire LED Display
Digital Voltmeter Ammeter 100V 10A Blue & Red Dual LED Display
USB Charger Detector Voltmeter Ammeter
Analog Voltmeter Panel Mount 0-300VDC 91C4
Analog Voltmeter Panel Mount 0-50VDC 85C1
Analog Ammeter Panel Mount 0-10VDC 85C1
SIM800A GSM GPRS Module with STM32 Power Supply
Mini SIM800C GSM GPRS Bluetooth Module
- It is currently Wed May 22, 2024 1:47 am
TRONIC.LK Item List 1901-2000
Post by TRONICLK » Mon Mar 11, 2019 4:21 am
