Recessed Panel Light 18W Cool
Par Light 15W Cool
Flood Light 10W Cool
Flood Light 30W Warm
TV Remote Control Universal LCD TV TV-139F
US EU Universal Travel Adapter Multi Socket
315Mhz Wireless RF Transmitter Receiver Module Kit for Arduino
4-Channel 433MHz Wireless RF Remote Controller (without receiver)
Travel Charger 5V 2A Triple USB Ports for Samsung
HDMI to VGA Converter 1080p
Auto Cable 9/0.30mm 600V 30m Yellow Full Roll
Auto Cable 9/0.30mm 600V 30m Brown Full Roll
Auto Cable 9/0.30mm 600V 30m XXX Full Roll
Auto Cable 9/0.30mm 600V 30m YYY Full Roll
Auto Cable 9/0.30mm 600V Yellow per Meter
Auto Cable 9/0.30mm 600V Brown per Meter
Auto Cable 9/0.30mm 600V XXX per Meter
Auto Cable 9/0.30mm 600V YYY per Meter
2SA708 PNP Transistor
C2570 NPN Transistor
UM66 Simple Melody Generator Music
LM324N General Purpose Amplifier
7N60 600V N-Channel MOSFET
1N60 N-Channel MOSFET 600V 1A
FDV303N N-Channel MOSFET
Zenor Diode 5.1V
330uF 50V Capacitor
3.81mm Pitch 4-Pin 4-way Screw Terminal Block PCB Mount Pluggable Type
680uF 50V Capacitor
2.2uF 50V Capacitor
SIM908 Quad-Band GSM GPRS GPS Development Board with GPS and GSM Antenna
CAT5 Network Cable RJ45 100m Full Role
CAT5 Network Cable RJ45 per Meter
CAT6 Network Cable RJ45 Full Role
CAT6 Network Cable RJ45 per Meter
Heat Shrink Tube 30cm (D2mm)
Heat Shrink Tube 30cm (D3mm)
Heat Shrink Tube 30cm (D4mm)
Heat Shrink Tube 30cm (D5mm)
Heat Shrink Tube 30cm (D8mm)
Heat Shrink Tube 30cm (D10mm)
Heat Shrink Tube 30cm (D15mm)
Heat Shrink Tube 30cm (D35mm)
Universal Mobile Phone Holder
BQZ Earphone Hands-free for Samsung Phones
TV Double Aerial Indoor
135J 1.3uF 400VAC Metallized Polypropylene Film Capacitor
47uF 100V Capacitor
LED Strip Plastic White 1 Bulb Small
LED Flame Bulb E27 Decoration
LED Flood Light 50W (Simple)
Connector Bar Terminal Strips 5A
Connector Bar Terminal Strips 10A
Connector Bar Terminal Strips 16A
Connector Bar Terminal Strips 30A
Electrical Tester Screwdriver Flat Normal
Electrical Tester Screwdriver Flat and Cross
Electrical Tester Screwdriver Flat (Good Quality)
Male to Female Stereo Adapter Mic Converter (6.5mm to 3.5mm)
230V 40W E14 Bulb for Refrigerators
BLUE LED Flood Light 20W
BLUE LED Flood Light 30W
BLUE LED Flood Light 50W
BLUE LED Flood Light 100W
PET LED Candle Light 3W Yellow E14
Multi Socket with 5A Fuse (Round Pin)
Multi Socket with 13A Fuse (Square Pin)
KEVILTON Multi Socket 5A Round Pin
KEVILTON Multi Socket 13A Square Pin
USB Kit MP3 FM Normal
USB Kit MP3 FM Bluetooth
Gear Motor (No Wheel)
Arduino Starter Kit with UNO Board
BLUE LED Candle Light 12W Cool E27
BLUE LED Candle Light 4W Warm E14
BLUE LED Candle Light 6W Cool E14
micro:bit Development Board (BBC Microbit)
LED 5mm Blue Clear
LED 5mm Blue Defused
PHILIPS Contact Cleaner
Goot Soldering Iron 100W
VCD DVD DVB Universal Power Module Repair Board
SD9205A Digital Multimeter
DT700 Digital Multimeter
2SC5296 NPN Power Transistor
18 K 1/4W Resistor 5%
5.6 K 1/4W Resistor 5%
330 Ohm 1/4W Resistor 5%
224J 0.22uF 220nF 100V Mylar Capacitor
102J 1nF 100V Mylar Capacitor
10pF Ceramic Capacitor
Zenor Diode 3V 1/2W
Zenor Diode 3.3V 1/2W
Zenor Diode 3.6V 1/2W
Zenor Diode 4.7V 1/2W
Zenor Diode 6.2V 1/2W
Zenor Diode 8.2V 1/2W
Zenor Diode 10V 1/2W
Zenor Diode 12V 1/2W
Zenor Diode 3.3V 1W
- It is currently Sat Apr 27, 2024 10:19 pm
TRONIC.LK Item List 1301-1400
Post by TRONICLK » Mon Mar 11, 2019 4:15 am
