JRC4558D Dual Op-Amp Operational Amplifier
LM35 Temperature Sensor
Atmel ATTINY13A-SU Microcontroller
Atmel ATTINY13A-PU Microcontroller
Atmel ATTINY2313A-SU Microcontroller
Atmel ATTINY24-SSU Microcontroller
Atmel ATTINY84A-SSU Microcontroller
Atmel ATMEGA8A-PU Microcontroller
Atmel ATMEGA8A-AU Microcontroller
Atmel ATMEGA16A-PU Microcontroller
Atmel ATMega328P-AU Microcontroller
Atmel ATMEGA328P-PU Microcontroller
Atmel ATMEGA328P-PU Microcontroller with Uno Boot loader
Atmel ATMEGA32A-AU Microcontroller
Atmel ATMEGA64A-AU Microcontroller
Atmel ATMEGA128A-AU Microcontroller
24C04 Serial 4K EEPROM
Atmel ATTINY85-20SU Microcontroller
Microchip PIC12F675 I/P
Microchip PIC16F88
Microchip PIC16F876A
Microchip PIC16F877A
Microchip PIC16F84A
Microchip dsPIC30F4011
Microchip PIC18F2550
Microchip PIC18F452
1N4001 Diode
1N4004 Diode
1N4007 Diode
1N4148 Diode
1N5822 Diode
1N5408 Diode
1N4735A Diode
2N7002LT1G N-Channel Small Signal MOSFET (Code 7002)
MMBT2222A NPN General Purpose Amplifier Transistor (Code 1P)
M7 Rectifier Diode
1N4148W T4 Switching Diode
1.5KE 400V TVS Diode
Zenor Diode 6.8V 1/2W
BZV55 5.1V Zenor Diode
BZV55 3.6V Zenor Diode
1N5344B 5W 8.2V Zener Diode
D400 NPN Transistor
D313 NPN Transistor
BC338 NPN Transistor
BC557 NPN Transistor
BC547 NPN Transistor
C828 Transistors
C536 NPN Transistor
C8050 NPN Transistor
C945 NPN Bipolar Transistor
MMBT3904 NPN Transistors (Code 1AM)
MMBT3906 PNP Transistor (Code 2A)
2N2222A NPN Transistor
2N3904 NPN General Purpose Transistor
BC548 NPN Transistor
TL431 Programmable Precision References Transistor
S9012 PNP Transistor
S9018 NPN transistor
S9015 PNP Transistor​
A1013 PNP Transistor
A733 PNP Transistor
A1015 PNP Epitaxial Silicon Transistor
BC337 NPN Transistor
SMF05C 5-Line Transient Voltage Suppressor
LL4148 1N4148 Signal Fast Switching Diode
DB107S Bridge Rectifier
GBPC3510W Bridge Rectifier Power Diode
SS24 Schottky Diode
SS32 Schottky Diode
FDS6675 P-channel Power MOSFET
FDN340P P-channel Power MOSFET (Code 340)
BSN20 N-channel Power MOSFET (Code WK3)
IRLR110 N-channel Power MOSFET
FDD8878 N-channel Power MOSFET
LR7843 HEXFET Power MOSFET
IRF530N Power MOSFET
IRF540NS HEXFET Power MOSFET
IRF540N Power MOSFET
IRF640NS Power MOSFET
IRF640N Power MOSFET
IRF9530N Power MOSFET
BT138 Triac
BT137 Triac
BT136 Triac
BTA16 Triac
D1555 H-Out Horizontal Out Transistor
2N5401 PNP Transistor
L7805AB2T Voltage Regulator
L7805CV 5V Voltage Regulator
L7806CV 6V Voltage Regulator
L7809C2T 9V Voltage Regulator
L7809CV 9V Voltage Regulator
L7812CV 12V Voltage Regulator
L7812C 12V Voltage Regulator
L7905CV 5V Voltage Regulator
L7909CV 9V Voltage Regulator
L7912CV 12V Voltage Regulator
L7915CV 15V Voltage Regulator
L7818CV 18V Voltage Regulator
- It is currently Sat Apr 27, 2024 9:57 am
TRONIC.LK Item List 401-500
Post by TRONICLK » Mon Mar 11, 2019 3:50 am
