Soil Humidity Hydrometer Moisture Detection Sensor Module for Arduino
MQ-2 LPG CH4 CO H2 Alcohol Smoke Butane Methane Propane Gas Detection Module
MQ-3 Alcohol Ethanol Gas Detection Module for Arduino
MQ-8 Hydrogen Gas Sensor Module
MQ-8 Hydrogen Gas Sensor (Only Sensor)
Electric Solenoid Valve 0.5-inch 12VDC NC Plastic Water Air
Electric Solenoid Valve 0.5-inch 12VDC NC Metal Water Air
ISD1820 Sound Voice Board Recording and Playback Module
SD Card Module for Arduino
MicroSD Card Module for Arduino Mini
MP3 Player SD Card Voice Module for Arduino
GPD2846A TF Card MP3 Decoder Board Module
TF U-Disk MP3 Decoder Board Module
PAM8403 3W Stereo Audio Amplifier Board without Volume CtrlPAM8403 3Wx2 Stereo Audio Amplifier Board without Volume Ctrl
PAM8403 3W Stereo Audio Amplifier Board with Volume Controller 5VDC
TDA7297 15W Stereo Audio Amplifier Module 12V
LM386 Mini Audio Amplifier Module DC 5V-12V
TEA5767 Programmable Low-power FM Stereo Radio Module for Arduino
DS3231 Precision RTC Real time Clock Memory Module AT24C32 IIC I2C ZS-042
DS1302 RTC Real Time Clock Module for Arduino
DS1307 RTC Real Time Clock AT24C32 I2C Module for Arduino
DS1302 Rotating LED 5V Electronic Digital Clock 51 SCM Learning Board Kit
2-Channel Bidirectional I2C Level Shifter Module 3V-5V for Arduino
4-Channel 3.3V 5V Bi-Directional Logic Level Shifter Module
Buzzer Module (Large) for Arduino
IRF520 MOSFET Module for Arduino
TEC1-12706 DC12V 45W Peltier Thermoelectric Cooler
TLP281 4-Channel Optoisolator Optocoupler Module for Arduino
MCP2515 CAN Shield for Arduino
MCP2515 CAN Module
SIM800L Quad-Band GSM GPRS module with Antenna V2.2 5V for Arduino
SIM800 Quad-Band GSM GPRS Module with Antenna (SIM800C Upgrade)
SIM808 Quad-Band GSM GPRS GPS BT Development Board with GPS Antenna
SIM808 Quad-Band GSM GPRS GPS BT Development Board Shield for Arduino
SIM900 Quad-Band GSM GPRS Shield with Antenna for Arduino
Mini A6 GSM GPRS Quad-band Module with Antenna
A7 GPS GSM GPRS Development Module
Ublox NEO-6M GPS Module Aircraft Flight Controller for Arduino
RoyalTek REB-5216 GPS Shield for Arduino
GPS Antenna 1575.42MHz 3V 5V
GSM GPRS 3G Antenna 800 to 2170MHz 3dBi SMA plug
RF 315MHz Antenna 2-3 dBi
RF 433MHz Antenna 2-3 dBi
IPEX to SMA Cable WIFI GSM 3G 4G Female Wire
Angled GSM Antenna 900-1800-1900 with SMA-M Plug
37 in 1 Sensor Module Kit for Arduino (With plastic case)
MAX7219 LED 8x8 Matrix Module for Arduino
TM1638 8-Digit 8-Bit 8-Key Digital LED Tube Display Module
8-Digit LED Tube 74HC595 Display Module for Arduino
8-Bit Line Hunting Sensor Follower Module for Arduino
GY-801 L3G4200D ADXL345 HMC5883L BMP180 10-DOF 9-Axis Attitude Indicator Module
3 Wheel Smart Car Chassis kit
4 Wheel Smart Car Chassis kit
Gear Motor with Robot Wheel
DC Motor for Vesak Decoration
Caster Wheel Omni Steering
Caster Wheel Steel Ball 25.4mm
1602 16x2 Blue Backlight LCD Display
1602 16x2 Yellow Backlight LCD Display
1604 16x4 Yellow Backlight LCD Display
2004 20x4 Blue Backlight LCD Display
2004 20x4 Yellow Backlight LCD Display
128x64 Dots Graphic Blue Backlight LCD Display
0.96 inch 128X64 OLED Display Module SPI Serial Blue Yellow
5x7 LED Matrix Red Common Cathode 1.5 inch
1-Digit 7-Segment Red Colour 0.56 inch Common Cathode
1-Digit 7-Segment Red Colour 0.56 inch Common Anode
2-Digit 7-Segment Red Colour 0.8 inch Common Cathode
2-Digit 7-Segment Red Colour 0.8 inch Common Anode
4-Digit 7-Segment Red Colour 0.56 inch Common Cathode
3VDC Miniature Relay 10A 250VAC / 10A 30VDC
12VDC Miniature Relay 20A 14VDC / 5A 250VDC Small
5VDC HF32F-G-005-HS Miniature Relay 230V 1A
5VDC Miniature Relay 10A 250VAC / 10A 30VDC
9VDC Miniature Relay 250VAC 10A / 28VDC 10A
12VDC Miniature Relay 250VAC 10A / 30VDC 10A
220VAC Miniature 8Pin Relay 240VAC 5A / 28VDC 5A
Omron G3MB-202P SSR
BLUE LED Bulb 3W E27 Grade-A
BLUE LED Bulb 5W E27 Grade-A
GOLD LED Bulb 5W B22 Grade-A
BLUE LED Bulb 7W E27 Grade-A
GOLD LED Bulb 7W B22 Grade-A
BLUE LED Bulb 9W E27 Grade-A
GOLD LED Bulb 9W B22 Grade-A
BLUE LED Bulb 12W E27 Grade-A
GOLD LED Bulb 12W B22 Grade-A
BLUE LED Bulb 15W B22 Grade-A
BLUE LED Bulb 18W B22 Grade-A
BLUE LED Bulb 24W B22 Grade-A
BLUE LED Bulb 28W B22 Grade-A
BLUE LED Bulb 40W B22 Grade-A
BLUE LED T8 Tube Light 2feet 9W 220VAC Full Set
BLUE LED T8 Tube Light 1feet 5W 12VDC Full Set
BLUE LED Candle Light 12W Warm E14
PET LED Bulb 3W B22 Grade-B
PET LED Bulb 5W B22 Grade-B
PET LED Bulb 7W B22 Grade-B
PET LED Bulb 9W B22 Grade-B
- It is currently Thu May 02, 2024 9:40 pm
TRONIC.LK Item List 101-200
Post by TRONICLK » Mon Mar 11, 2019 3:48 am
