How to convert binary to BCD ?
Re: How to convert binary to BCD ?
Post by Saman » Sat Jan 26, 2013 3:19 am
Why 26 bit ? Cant represent more than 26 bit numbers ?
Is Reason for limit ,for 32 bit output? :idea:
The maximum number which can show in 26-bits is (226 - 1) = 67108863
There are 8 digits which needs 8 nibbles of 4 bytes.
Now consider (227 - 1)... it is 134217728 and it has 9 digits.
It needs 9 nibbles. That is 4-bytes and another nibble which can't be accommodated in a 32-bit integer type.
So for your question, answer is yes.
If you select the return type to be a 64-bit type such as long long or __int64, then you can represent 16-digits with those.
Nandika
Post by Nandika » Sat Jan 26, 2013 8:51 am
Thank Saman
Completely clear all.. :)
Thank All friends...
:yahoo:
penlock
Post by penlock » Fri Sep 27, 2013 3:07 pm
Hi everyone.. kak kak :clap: :clap:
Drew2
Post by Drew2 » Wed Mar 12, 2014 3:35 pm
Thanks for the post!
Return to “C/C++ Programming”
