Dear all,
I'm using clock() command at the moment to findthe time spent on a time critical function.
But I'm not satisfied with the output. Do you know a better way to find it with more accuracy?
Regards,
Shane
What's the best way to time a function in VC++?
Re: What's the best way to time a function in VC++?
Hi Shane,
Yes, there are few methods for this. clock() function is not accurate at all.
Refer the following table.
Average Error(ms) Resolution (Error x 2) (ms)
clock () 27 55
_ftime () 27 55
GetTickCount () 10 20
Multimedia Timer 1 2
So GetTickCount and Multimedia Timer are the most accurate ways to do this.
Have a look at the following examples.
GetTickcount
Multimedia Timer (winmm.lib)
When you see the output, you will agree that Multimedia Timer method is the most acurate one.
Hope this helps.
Regards,
clock () 27 55
_ftime () 27 55
GetTickcount
#include <windows.h>
#include <stdio.h>
void main (void){
DWORD i, st, en, diff;
for (i = 100; i < 130; i++){
st = GetTickCount ();
while (GetTickCount () < (st + i));
en = GetTickCount ();
diff = en - st;
printf ("Expected:%d Actual:%ld\n", i, diff);
#include <stdio.h>
#include <mmsystem.h>
void main (void){
TIMECAPS res;
if (timeGetDevCaps (&res, sizeof (TIMECAPS)) == TIMERR_NOERROR){
printf ("Supported min resolution = %d\n", res.wPeriodMin);
printf ("Supported max resolution = %d\n", res.wPeriodMax);
if (res.wPeriodMin <= 1){
if (timeBeginPeriod (1) == TIMERR_NOERROR){
st = timeGetTime ();
while (timeGetTime () < (st + i));
en = timeGetTime ();
diff = en - st;
timeEndPeriod (1);
Hope this helps.
Regards,
Multimedia Timer has sorted out my problem.
Thanks a lot.
Shane
Thanks a lot.
Shane
