C++/C 'extern' keyword explained
SemiconductorCat
Post by SemiconductorCat » Thu Sep 15, 2011 3:12 pm
When we built a program with multiple compilation units[ multiple source files and object files built a one single executable file] we have met situation that we need to share variables and made calls between multiple compilation units.
for a example consider the following two source files.
#include <stdio.h>
extern void f1();
int main(int argc,char ** argv)
    f1();
    return 0;
file1.c
#include <stdio.h>
void f1()
    printf ("f1() from file2\n");
    return ;
file2.c
compile
#gcc -c file1.c file2.c
link
#gcc -o file file1.o file2.o
run
#./file
In "C" programming language the line 2 in file1.c is actually not necessary.because "C" allow us to use implicit declaration. But if you pass the '-Wall' compiler switch to the compiler you'll get a
warning message like.
file1.c: In function 'main':
file1.c:5: warning: implicit declaration of function 'f1'
However in C++ , line 2 , at lest without 'extern'
void f1();
is necessary, because C++ doesn't allow implicit declarations , because it's a strict language.
However you still can omit 'extern' prefix keyword.
so for calling functions which are on other compilation units [which are declared in other source files and will be separately compiled and will built a '.o' file], it's not necessary to use 'extern' keyword.
So How 'extern' keyword is useful? why it exists?
As you already seen , to call external function you don't need to use 'extern' prefix. But when you referencing to a variable that exists outside your file scope without redefine it,you need to use 'extern' keyword.Such as like this.
extern int error;
which means 'error' is definied somewhere else in the code, but if you type
int error;
it means error in declared and defined in the current file scope.
So let's take a example. Review following two source files.
#include <stdio.h>
extern int error;
int main(int argc,char **argv)
    printf("error code is :%i\n",error);
    return 0;
main.c
int error =3;
error.c
... There are other uses of 'extern' keyword such as 'extern "C"' to call older C library functions within C++. And to call routines that are written in assembly language.
Good Clear Coding Style.
Although you don't need to explicitly use 'extern' as a prefix when you want to call a external function, ignoring it is not a good coding practice. believe me no industry expert is ignoring that, because you're writing code to human to read , lastly for the compiler. So I recommend you to explicitly put that prefix 'extern' where appropriate.
--Happy Coding--
--sandun--
Re: C++/C 'extern' keyword explained
Post by Saman » Thu Sep 15, 2011 5:59 pm
Very nice explanation.
I would like to add two points.
  • It is good to use CPP as the extension for C++ files
  • It would be better to use C++ in OOP style (that's why C++ is made for) where it removes the need of 'extern' completely.
Return to “C/C++ Programming”
