How to send an Email using C++
Enigma
Post by Enigma » Wed Jan 19, 2011 2:07 pm
Hi
Recently I tried to send an email using C++. Here is the solution that I found. Code will work without any issues in windows environment. I have tested this on visual studio 2005. But if you want to run this on linux/unix then use berkeley socket interface instead of winsock. I have used gamil server as the mail server. But I think any SMTP mail server with telnet enabled can use for this. Hope this will help you. :)
#include <stdlib.h>
#include <winsock2.h>
#include <stdio.h>
#pragma comment(lib,"ws2_32.lib") // use to link the winsock library
#define MailServer "gmail-smtp-in.l.google.com"
#define Mailto "[email protected]"
#define Mailfrom "[email protected]"
#define bufsize 10000
int main()
	char* subject = "This is a Test Email";
	char* Message = "Hi\n This is a test email from my computer";
	SOCKET mail_socket;
	sockaddr_in service;
	WORD wVersionRequested;
	WSADATA wsaData;
	struct hostent *host;
	int wsaerr;
	int recvBytes=0;
	char *Temp_Buf = (char*) malloc(bufsize+1);
	wVersionRequested = MAKEWORD(2, 2);
	wsaerr = WSAStartup(wVersionRequested, &wsaData);
	if (wsaerr != 0)
		return 0;
	mail_socket = socket(AF_INET,SOCK_STREAM,0);
	if(mail_socket == INVALID_SOCKET)
		WSACleanup();
		return 0;
	host = gethostbyname(MailServer);
	memset(&service,0,sizeof(service));
    memcpy(&(service.sin_addr),host->h_addr,host->h_length);
	service.sin_family= host->h_addrtype;
    service.sin_port= htons(25);
	 if (connect(mail_socket, (struct sockaddr *)&service,sizeof(service)) == -1)
		 perror("connect");
		 closesocket(mail_socket);
		 WSACleanup();
		 return 0;
	 memset(Temp_Buf,'\0',bufsize);
	 recvBytes = recv(mail_socket,Temp_Buf,bufsize,0);
	 strcpy(Temp_Buf,"helo me.hi.com\n");
	 send(mail_socket,Temp_Buf,strlen(Temp_Buf),0);
	 sprintf(Temp_Buf,"MAIL FROM:<%s>\n",Mailfrom);
	 sprintf(Temp_Buf,"RCPT TO:<%s>\n",Mailto);
	 strcpy(Temp_Buf,"DATA\n");
	 sprintf(Temp_Buf,"To:%s\nFrom:\%s\nSubject:%s\n%s\r\n.\r\n",Mailto,Mailfrom,subject,Message);
	 strcpy(Temp_Buf,"quit\n");
	 WSACleanup();
return 0;
Re: How to send an Email using C++
Post by Saman » Wed Jan 19, 2011 2:48 pm
Dude, you are an asset to us.
BTW: Under Linux, you can directly include <sys/socket.h> and use sockets without need of any additional library.
I have added a sample with server and client code.
See Sample code to use sockets in Linux/C++.
Enigma
Post by Enigma » Wed Jan 19, 2011 4:03 pm
wow I didn't know that. That's grate. :)
Pansophic
Sergeant
Sergeant
Post by Pansophic » Tue Mar 01, 2011 2:42 pm
OMG, didn't knew we could make that in c++ will try this for sure.
Return to “C/C++ Programming”
