How to make a Program to Ping in C++
Post by Nipuna » Thu Dec 02, 2010 5:47 pm
I got Ping Idea From Saman. And I learned about it from Neo too. Both teached me well. :)
Today I thought to make a Simple Program for Fun. I haven't started learning C++ yet but I learned a little and i will learn the rest in later Day.
Then I tried to make a Program Like this
When user Input an URL program Pings it and then Show ping Results.
I made a Program but it doesn't work well it always says "Enter URL". I entered an URL but it still says "Enter URL"
And I think MY code is Wrong. Can you Give Me the Correct code?
Here is the Code
#include<iostream>
#include<string>
using namespace std;
int main ()
    string url;
    float ping;
    cout<<"Enter URL";
    cin>>url;
    ping=system("ping"),url;
    cout <<ping;
    cin.get();
    return 0;
Re: How to make a Program to Ping in C++
Post by Neo » Thu Dec 02, 2010 9:43 pm
#include <iostream>
#include <string>
int main ()
	string url;
	string cmd;
	cout << "Enter URL" << endl;
	cin>>url;
	cmd = "ping " + url;
	system(cmd.c_str());
	cin.get();
	return 0;
Post by Nipuna » Fri Dec 03, 2010 10:22 am
I know this is a function
Isn't it?
And What is this
and what is it doing?
I tried adding this
cmd="pause";
without
. but it only prints pause on the screen i think this one
does the ping+url work.
Thanks for your time for helping me.
Post by Neo » Fri Dec 03, 2010 11:21 am
Isn't it?
In C++, it is possible to concatenate strings (add strings) in this way.
So what happens here is that we construct a string like "ping 192.168.0.1" and store it to the string var cmd.
And What is this
system() is used to execute external EXEs, DOS commands, etc...
If you add system("dir"); this will list down the directories in the current directory (same as you type dir in the command prompt).
Since cmd is a C++ string, it is required to use cmd.c_str() to get the pointer of the string.
So what we do with system(cmd.c_str()); is that we execute "ping ...." command on the command prompt. That's all.
Post by Nipuna » Fri Dec 03, 2010 2:21 pm
Thanks Buddy
Pointer Means the Memory Address of the cmd string? Isn't It?
I didn't Learn till Strings. :)
Post by Neo » Fri Dec 03, 2010 2:34 pm
string is a class in C++ specially created to hold a string and provide more flexibility on string operations. The memory pointer that contains text is returned by that command.
Since you have not yet stepped in to Object Oriented Programming concepts (OOP) you don't need to learn concepts like class, object, etc... right now. Just use it and later when you come to classes you'll learn them.
Post by Nipuna » Fri Dec 03, 2010 5:51 pm
Sorry Neo I made a Mistake not Strings. I wanted to tell it was Pointers. :) Sorry For that
Return to “C/C++ Programming”
