#pragma once
#include <vector>
#include <cmath>
#include "Vector2.hpp"
namespace IntersectionFunctions
	struct IntersectionObject
		std::vector<Vector2> points;
		void InsertSolution(float x, float y)
			points.push_back(Vector2(x, y));
		void InsertSolution(Vector2 v)
			points.push_back(v);
		int NumberOfSolutions()
			return points.size();
	// Circle to Circle
	IntersectionObject CircleToCircleIntersection(Vector2 circlePosition1, float radius1,
						      Vector2 circlePosition2, float radius2)
		IntersectionObject result;
		float a, distSq, dist, h;
		Vector2 d, r, v2;
		// d is the vertical and horizontal distances between the circle centers
		d = circlePosition1 - circlePosition2;
		//distance squared between the circles
		distSq = d.LengthSq();
		// Check for equality and infinite intersections exist
		if (distSq == 0 && radius1 == radius2)
			return result;
		//Check for solvability
		if (distSq > (radius1 + radius2) * (radius1 + radius2))
			// no solution. circles do not intersect
			return result;
		if (distSq < abs(radius1 - radius2) * abs(radius1 - radius2))
			// no solution. one circle is contained in the other
			return result;
		if (distSq == (radius1 + radius2) * (radius1 + radius2))
			//one solution
			result.InsertSolution((circlePosition1 - circlePosition2) / (radius1 + radius2) * radius1 + circlePosition1);
			return result;
		dist = sqrt(distSq);
		// 'point 2' is the point where the line through the circle
		// intersection points crosses the line between the circle
		// centers.
		// Determine the distance from point 0 to point 2
		a = ((radius1 * radius1) - (radius2 * radius2) + distSq) / (2.0f * dist);
		// Determine the coordinates of point 2
		v2 = circlePosition1 + d * (a / dist);
		// Determine the distance from point 2 to either of the intersection points
		h = sqrt((radius1 * radius1) - (a * a));
		// Now determine the offsets of the intersection points from point 2
		r = d * (h / dist);
		r = r.Normal();
		// Determine the absolute intersection points
		result.InsertSolution(v2 + r);
		result.InsertSolution(v2 - r);
		return result;
	// Used only within this namespace
	int PrivateLineToCircleIntersection(Vector2 vertex1, Vector2 vertex2,
					    Vector2 circlePosition, float radius,
					    Vector2 & solution1, Vector2 & solution2)
		// Vector from point 1 to point 2
		Vector2 vertex1to2 = vertex2 - vertex1;
		// Vector from point 1 to the circle's center
		Vector2 circleToVertex1 = circlePosition - vertex1;
		float dot = vertex1to2.Dot(circleToVertex1);
		Vector2 proj1 = vertex1to2 * (dot / vertex1to2.LengthSq());
		Vector2 midpt = vertex1 + proj1;
		Vector2 circleToMidpt = midpt - circlePosition;
		float distSqToCenter = circleToMidpt.LengthSq();
		if (distSqToCenter > radius * radius) return 0;
		if (distSqToCenter == radius * radius)
			solution1 = midpt;
			return 1;
		float distToIntersection;
		if (distSqToCenter == 0)
			distToIntersection = radius;
		else
			distToIntersection = sqrt(radius * radius - distSqToCenter);
		vertex1to2 = vertex1to2.Normalize();
		vertex1to2 *= distToIntersection;
		solution1 = midpt + vertex1to2;
		solution2 = midpt - vertex1to2;
		return 2;
	//Line to Circle
	IntersectionObject LineToCircleIntersection(Vector2 vertex1, Vector2 vertex2,
						    Vector2 circlePosition, float radius)
		Vector2 solution1, solution2;
		switch(PrivateLineToCircleIntersection(vertex1, vertex2, circlePosition, radius, solution1, solution2))
		case 2:
			result.InsertSolution(solution2);
		case 1:
			result.InsertSolution(solution1);
			break;
		return result;
	// Circle to Line
	IntersectionObject CircleToLineIntersection(Vector2 circlePosition, float radius,
						    Vector2 vertex1, Vector2 vertex2)
		return LineToCircleIntersection(vertex1, vertex2, circlePosition, radius);
	// LineSegment to Circle
	IntersectionObject LineSegmentToCircleIntersection(Vector2 vertex1, Vector2 vertex2,
		Vector2 vertex1ToSolution1, vertex2ToSolution1, vertex1ToSolution2, vertex2ToSolution2;
		case 2:
			vertex1ToSolution2 = solution2 - vertex1;
			vertex2ToSolution2 = solution2 - vertex2;
			if (vertex1ToSolution2.Dot(vertex1to2) > 0 &&
				vertex2ToSolution2.Dot(vertex1to2) < 0)
		case 1:
			vertex1ToSolution1 = solution1 - vertex1;
			vertex2ToSolution1 = solution1 - vertex2;
			if (vertex1ToSolution1.Dot(vertex1to2) > 0 &&
				vertex2ToSolution1.Dot(vertex1to2) < 0)
			break;
		return result;
	// Circle to LineSegment
	IntersectionObject CircleToLineSegmentIntersection(Vector2 circlePosition, float radius,
		return LineSegmentToCircleIntersection(vertex1, vertex2, circlePosition, radius);
	// Ray to Circle
	IntersectionObject RayToCircleIntersection(Vector2 vertex1, Vector2 vertex2,
		Vector2 vertex1ToSolution1, vertex1ToSolution2;
		case 2:
			if (vertex1ToSolution2.Dot(vertex1to2) > 0)
		case 1:
			if (vertex1ToSolution1.Dot(vertex1to2) > 0)
			break;
		return result;
	// Circle to Ray
	IntersectionObject CircleToRayIntersection(Vector2 circlePosition, float radius,
		return RayToCircleIntersection(vertex1, vertex2, circlePosition, radius);
	bool PrivateLineToLineIntersection(Vector2 vertex1, Vector2 vertex2,
					   Vector2 vertex3, Vector2 vertex4, float & r, float & s)
		float d;
		//Make sure the lines aren't parallel
		Vector2 vertex3to4 = vertex4 - vertex3;
		//if (vertex1to2.x * -vertex3to4.y + vertex1to2.y * vertex3to4.x != 0)
		if(vertex1to2.y / vertex1to2.x != vertex3to4.y / vertex3to4.x)
			d = vertex1to2.x * vertex3to4.y - vertex1to2.y * vertex3to4.x;
			if (d != 0)
				Vector2 vertex3to1 = vertex1 - vertex3;
				r = (vertex3to1.y * vertex3to4.x - vertex3to1.x * vertex3to4.y) / d;
				s = (vertex3to1.y * vertex1to2.x - vertex3to1.x * vertex1to2.y) / d;
				return true;
		return false;
	// Line to Line
	IntersectionObject LineToLineIntersection(Vector2 vertex1, Vector2 vertex2,
						  Vector2 vertex3, Vector2 vertex4)
		float r, s;
		if(PrivateLineToLineIntersection(vertex1, vertex2, vertex3, vertex4, r, s))
			result.InsertSolution(vertex1 + (vertex2 - vertex1) * r);
		return result;
	// LineSegment to LineSegment
	IntersectionObject LineSegmentToLineSegmentIntersection(Vector2 vertex1, Vector2 vertex2,
		float r, s;
			if (r >= 0 && r <= 1)
				if (s >= 0 && s <= 1)
		return result;
	IntersectionObject LineSegmentToLineIntersection(Vector2 vertex1, Vector2 vertex2,
		float r, s;
		return result;
	// Line to LineSement
	IntersectionObject LineToLineSegmentIntersection(Vector2 vertex1, Vector2 vertex2,
		return LineSegmentToLineIntersection(vertex3, vertex4, vertex1, vertex2);
	// Ray to LineSegment
	IntersectionObject RayToLineSegmentIntersection(Vector2 vertex1, Vector2 vertex2,
		float r, s;
			if (r >= 0)
		return result;
	// LineSegment to Ray
	IntersectionObject LineSegmentToRayIntersection(Vector2 vertex1, Vector2 vertex2,
		return RayToLineSegmentIntersection(vertex3, vertex4, vertex1, vertex2);
	// Ray to Line
	IntersectionObject RayToLineIntersection(Vector2 vertex1, Vector2 vertex2,
		float r, s;
			if (r >= 0)
		return result;
	// Line to Ray
	IntersectionObject LineToRayIntersection(Vector2 vertex1, Vector2 vertex2,
		return RayToLineIntersection(vertex3, vertex4, vertex1, vertex2);
	// Ray to Ray
	IntersectionObject RayToRayIntersection(Vector2 vertex1, Vector2 vertex2,
		float r, s;
			if (r >= 0)
				if (s >= 0)
		return result;
