Hi,
I need to open a sequence of files named as bitmapXX.bmp (where XX= 0... 99) inside a 'for' loop, access them and then close at the end of iteration.
something like below.
for (i=0; i<100; i++)
//open file
//access
//close
I tried to use strcat and itoa but I have a problem when I have generate a number with proceeding 0...for example for 1, it generates bitmap1.bmp instead of bitmap01.bmp.
Can you please help?
Kevin
Opening a sequence of files inside a loop
Re: Opening a sequence of files inside a loop
you can use sprintf instead as below.
char filename[50]; // to hold the filename
FILE *fp;
for (............
sprintf ( filename, "C:/path/bitmap%.2d.bmp", i); // %.2d will add zeros to the left and make the width exactly 2
fp = fopen (filename, "rb"); //for binary reading (ANSI C)
fread(buf, ..., ..., fp);
fclose(fp);
Hope this helps.
FILE *fp;
for (............
fclose(fp);
Hope this helps.
