Library for high performance parallel computing
Post by Neo » Wed Nov 07, 2018 6:40 am
The ArrayFire accelerated computing library is a free, general-purpose, open-source library that simplifies the process of developing software that targets parallel and massively-parallel architectures including CPUs, GPUs, and other hardware acceleration devices. ArrayFire is used on devices from low-powered mobile phones to high-powered GPU-enabled supercomputers including CPUs from all major vendors (Intel, AMD, Arm), GPUs from the dominant manufacturers (NVIDIA, AMD, and Qualcomm), as well as a variety of other accelerator devices on Windows, Mac, and Linux.
Free download library from https://arrayfire.com/.
Function list could be found at http://arrayfire.org/docs/group__arrayfire__func.htm
Hello world c++ example.
array A = randu(5, 3, f32); // Create 5x3 matrix of random floats on the GPU
array B = sin(A) + 1.5;     // Element-wise arithmetic
array C = fft(B);           // Fourier transform the result
float d[] = { 1, 2, 3, 4, 5, 6 };
array D(2, 3, d, afHost);   // Create 2x3 matrix from host data
D.col(0) = D.col(end);      // Copy last column onto first
array vals, inds;
sort(vals, inds, A);        // Sort A and print sorted array and corresponding indices
af_print(vals);
af_print(inds);
Himash
Sergeant
Sergeant
Re: Library for high performance parallel computing
Post by Himash » Thu Nov 08, 2018 8:36 pm
Good one ....
Return to “C/C++ Programming”
