Google was ingenious when they came up with Adsense. Not only do they get an opportunity to make additional money from their search engines, but they also allow Internet marketers a chance to make money in an easier manner. Why is this so? Well, with traditional affiliate marketing, you must make a sale before you receive commission. But with Adsense, all you have to do is create content that will produce ads that readers will click on. And in return for just a click, you will receive a few cents or in many cases, SEVERAL dollars.
This is where high paying Adsense keywords come in. So how can you find these high paying words? There are two approaches. The easiest one involves looking up pre-made lists. The other one involves you doing the research through Google's Adwords tool. Simply enter in the term you're interested in, and the tool will tell you how much each click is worth.
In terms of actual value, there are high paying keywords that are worth more than $20. There are even a few that are in the range of $40 to $69. In both cases, these keywords tend to revolve around lawyers, debt, credit cards, schooling and illness. And, contrary to what some may think, often times the most expensive Adsense keywords revolve around long-tail terms over more generalized phrases.
Either way, if you decide to promote these keywords, you could become independently wealthy relatively quickly. However, you do need to be aware of some things before going after these ultra-profitable of keywords.
First off, you must remember that Google will take its cut from
each keyword. And you will not know how much they will take until the stats start coming in. So, don't assume that 1,000 clicks from a $45 keyword will equal $45,000. Your cut will end up being much less than that. But it will still be much more generous than if you promoted a keyword that was only worth .05.
In addition, be aware that the higher paying keywords tend to not drive much traffic because there is so much competition surrounding them. So, unless you can beat the competition with a Fortune 500 business, you'll have to be more creative with how you promote these keywords.
For example, consider the keyword "expert core programmers" which is currently worth $52.25. There are a ton of websites ranked for this keyword, so you can forget about search engine traffic for this term. What you will have to do is drive traffic through other terms with Internet articles. And, you will have to think outside of the box to do this.
For instance, instead of promoting "expert core programmers" you could promote expert core message boards, books or research centers. You could talk about expert core developers and how to become an expert. Ultimately, if you put your heart and mind into it, there's no limit to what you will come up with.
In conclusion, high paying keywords could be your ticket towards financial independence. Yet, remember, even the gurus don't earn money overnight. You will still need to put in a lot of work through proper SEO and keyword optimization. Once you do that, the profits will surely start to come in.
- It is currently Mon May 13, 2024 12:57 am
Making Money With High Paying Adsense Keywords
