Here is the article
This is a common question which comes into our mind when we are about to start development of any website which requires CMS.A few things which you should keep in mind before you go for any specific CMS :
1. Do you know your requirements ? You should know what exactly do you require ? For e.g if you want a pure e-commerce website then you should go for e-commerce specialist CMSs like OSCommerce, ZenCart etc. If you want blogs along with e-commerce then you can go for wordpress. Hence it depends, what kind of requirements do you have ?
2. Are you familiar with the CMS, which you are going to use ? This means that you should be familiar with the CMS which you are going to use.
3. Availability of Support : The CMS which you are going to use must have a developer community and also it must have a place for discussion for development related issues and concerns . If it has then in case of difficulties, your problem will be resolved quickly.
4. SEO friendly : The CMS must be SEO friendly. Though, you’ll have to put extra efforts to make your website on top pages of popular search engines. But it helps alot if you have SEO friendly CMS. SEO friendly CMS gives you SEO friendly URLS etc. Some of the CMSs have SEO plugins which helps alot to improve your rankings in top most search engines.
5. Appealing GUI : The final website must have an appealing GUI. Until and unless your GUI is user-friendly and have appealing colors and functions, you won’t get much crowd !
6. BUG free : The CMS which you are going to use must be secure. It should not be vulnerable to hackers etc. This is the most important concern if you are dealing in financial transactions.
Conclusion : Before finalizing the CMS, first of all compare its features with other CMSs and then decide which CMS would be the best for you !
