Which is better Web Hosting; Linux or Windows?
Post by Neo » Mon Sep 14, 2009 7:49 pm
On the Internet there is a tremendous amount of argument over which operating system is the best for web hosting. There are anti-windows haters, there are FreeBSD fanatics and more. But which is the best? The truth is it depends on what you are doing.
The servers which run the web sites and the server software all run on a computer program known as the operating system. If you are running a personal computer chances are that you are running Windows ME, XP, NT or some other similar computer program. That is the operating system of your computer. With web hosting servers they also need a operating system and there are essentially three different competing versions.
Windows Option
The first version is Windows. Microsoft makes an operating system especially for servers. This operating systems allows true integration with Microsoft's products and also allows web sites to run Active Server Pages (basically computer scripts for dynamic web site content). Microsoft's server also allows integration with its SQL database, one of the more powerful databases. The downside of Microsoft's server software is that it costs several thousands of dollars for each server. Available options include Windows 2000 Server, Advanced Server and 2003 Server amoung others. Windows is best for new administrators because of its simple user interface. Additional software will cost extra such as: firewall, remote admin programs, ASP Encrypt, ASPMail, and many more required applications to make your server production ready.
Windows Hosting Benefits
  • ASP Support
  • ASP.NET Support
  • Powerful SQL Server Database
  • Access Database Support
  • PHP and MySQL Compatible
  • IIS Web Server
Linux Option
The second version is Linux. Linux is actually a common name for a variety of operating systems. Linux was, and is, developed by a community of individuals which come together to commonly write the main part of Linux. After this main part is developed, and continually refined, additional parts are added to the program to customize it for whatever purposes the end user wants. A variety of companies market Linux and you might have heard of a few: Red Hat, Debian, Slackware, etc. Linux is good in that it is compatible with the popular programming language PHP. It is also favored by some web hosters in that in general it has a good security record and tends on average to be a stable operating system. Linux software is free - note this is no longer true for Red Hat Enterprise versions. Linux is still free in other distributions such as Fredora, Debian and Ubuntu.
Linux additional software is generally free or low cost; APF Firewall, Apache, Sendmail, BIND and much more. We recommend you use a virus scanner such as Clam or F-Prot and MailScanner. Linux servers are very hard to administer compared to Windows. Everything is done through remote shell access like DOS. There are no pretty interfaces or buttons to click on - just a huge amount of commands. Although with all this console power you have much more control of your actual server compared to Windows.
Linux Hosting Benefits
  • PHP and MySQL Support
  • Apache Web Server
  • Mod Rewrite Support
  • Chmod file permissions
The third version is Unix-based operating systems. The last version mentioned here is very close in comparison to the Linux versions. In fact there are probably more similarities than differences. The main difference is the history of how the two versions came into being. Linux is an offshoot of the Unix operating system, where the Unix-based operating systems are refinements of Unix itself. Linux basically is a cousin to Unix-based operating systems. The main Unix-based operating systems are FreeBSD and OpenBSD. The selling point of these operating system is that they tend to be very stable once installed. The downpoint is that they are very technical to install. OpenBSD also has the reputation of very secure in that in the last six years it had only one security hole in the software itself. But OpenBSD does not allow everything; that it you have to sacrifice some flexibility for security. These operating systems are free as well.
So which is the best? Well it depends on what you need. If you want the tightest security then OpenBSD or Linux is probably for you. But it is very technical to install and you will not have a lot of frills. How about compatibility with all of Microsoft's products? Well then Windows is the best for you, but be prepared in that it will cost a lot--the other operating systems here are free. How about compatibity with PHP? Well then look at Linux or FreeBSD. You see it is not so much as which operating system is the best, but rather which operating system is best for what you need to do.
Lets put it simply, if you need to develop your site in ASP then use a Windows based hosting company. If you're developing in PHP then definately use a Linux/*nix hosting company.
WindowsLinux
FTP Accessyesyes
Telnet/SSH Accesslimitedyes
HTML & JavaScriptyesyes
FrontPage Extensionsyesyes
CGI/Perllimitedyes
ASPyeslimited
PHPlimitedyes
ColdFusionyesyes
Access Databaseyesno
mySQL Databaseyesyes
Return to “Web Related”
