How to uninstall MailPress (MailPress Uninstall problems)
Post by Neo » Tue Jul 12, 2011 3:24 pm
When you try to delete MailPress 5.1 plug-in from WordPress, If you are getting an error which says MP_uninstall not found, here is a quick solution for you.
Open uninstall.php which is under /wp-content/plugins/mailpress/ and replace the entire content with the following code. Note that this class can be found inside a folder in the MailPress installation. If you are using a higher version than 5.1, make sure to replace the code from that.
class MP_uninstall
    function __construct()
        global $wpdb;
// taxonomies
        $taxonomies = array('MailPress_mailing_list', 'MailPress_autoresponder');
        foreach($taxonomies as $taxonomy)
            $queries[] = "DELETE FROM $wpdb->terms              WHERE term_id IN (SELECT term_id FROM $wpdb->term_taxonomy WHERE taxonomy = '$taxonomy');";
            $queries[] = "DELETE FROM $wpdb->term_relationships WHERE term_id IN (SELECT term_id FROM $wpdb->term_taxonomy WHERE taxonomy = '$taxonomy');";
            $queries[] = "DELETE FROM $wpdb->term_taxonomy WHERE taxonomy = '$taxonomy';";
// postmeta
        $queries[] = "DELETE FROM $wpdb->postmeta WHERE meta_key like '%_MailPress%';";
        $queries[] = "DELETE FROM $wpdb->postmeta WHERE meta_key like '%_mailpress%';";
// usermeta
        $queries[] = "DELETE FROM $wpdb->usermeta WHERE meta_key like '%_MailPress%';";
        $queries[] = "DELETE FROM $wpdb->usermeta WHERE meta_key like '%_mailpress%';";
// options
        $queries[] = "DELETE FROM $wpdb->options WHERE option_name like '%MailPress%';";
        $queries[] = "DELETE FROM $wpdb->options WHERE option_name like '%mailpress%';";
// mailpress tables
        $queries[] = "DROP TABLE $wpdb->mp_stats;";
        $queries[] = "DROP TABLE $wpdb->mp_mails;";
        $queries[] = "DROP TABLE $wpdb->mp_mailmeta;";
        $queries[] = "DROP TABLE $wpdb->mp_users;";
        $queries[] = "DROP TABLE $wpdb->mp_usermeta;";
        $queries[] = "DROP TABLE $wpdb->mp_tracks;";
        $queries[] = "DROP TABLE $wpdb->mp_forms;";
        $queries[] = "DROP TABLE $wpdb->mp_fields;";
        foreach($queries as $query) $wpdb->query($query);
new MP_uninstall();
Return to “Web Related”
