- Go to your domain panel and click manage domains
- Find the domain that you want to create the private name servers for
- Click add on the Host Summary section on the bottom left hand side
- Enter ns1 for the host name, and enter your primary IP for the IP address and click ok
- Click on add again and enter ns2, and enter the same IP except 1 number higher. Ex: if your primary IP was 192.168.0.1, the second IP you would use would be 192.168.0.2
- Click OK
- Now go to Nameservers and add NS1.YOURDOMAIN.COM and NS2.YOURDOMAIN.COM
- It will take up to 72 hours to update these information (This is common for all registrars)
How to setup GoDaddy domain nameservers for different host
To set up Nameservers in GoDaddy when the hosting is with a different company (private nameservers),
