- The first thing you should always do when handling a program that uses Windows is to include the windows.h header.
#include <windows.h> - Header structure 1
bfTypeCode: Select all
typedef struct tagBITMAPFILEHEADER { WORD bfType; DWORD bfSize; WORD bfReserved1; WORD bfReserved2; DWORD bfOffBits; } BITMAPFILEHEADER, *PBITMAPFILEHEADER;
Specifies the file type. It must be set to the signature word BM (0x4D42) to indicate bitmap.
bfSize
Specifies the size, in bytes, of the bitmap file.
For a 24-bit file, sizeof(BITMAPFILEHEADER) + sizeof(BITMAPINFOHEADER) + 3 * Width * Height
bfReserved1
Reserved; set to zero
bfReserved2
bfOffBits
Specifies the offset, in bytes, from the BITMAPFILEHEADER structure to the bitmap bits.
i.e.: sizeof(BITMAPFILEHEADER)+sizeof(BITMAPINFOHEADER) - Header structure 2
biSizeCode: Select all
typedef struct tagBITMAPINFOHEADER { DWORD biSize; // size of structure, in bytes DWORD biWidth; // bitmap width, in pixels DWORD biHeight; // bitmap height, in pixels WORD biPlanes; // see below WORD biBitCount; // see below DWORD biCompression; // see below DWORD biSizeImage; // see below DWORD biXPelsPerMeter; // see below DWORD biYPelsPerMeter; // see below DWORD biClrUsed; // see below DWORD biClrImportant; // see below } BITMAPINFOHEADER;
Specifies the size of the structure, in bytes.
biWidth
Specifies the width of the bitmap, in pixels.
biHeight
Specifies the height of the bitmap, in pixels.
biPlanes
Specifies the number of planes for the target device.
This value must be set to 1.
biBitCount
Specifies the number of bits per pixel.
biCompression
Specifies the type of compression for a compressed bottom-up bitmap. Use BI_RGB for an uncompressed format.
biSizeImage
Specifies the size, in bytes, of the image. This may be set to zero for BI_RGB bitmaps.
biXPelsPerMeter
Specifies the horizontal resolution, in pixels per meter, of the target device for the bitmap. Set this to 2400.
biYPelsPerMeter
Specifies the vertical resolution, in pixels per meter, of the target device for the bitmap. Set this to 2400.
biClrUsed
Specifies the number of color indexes in the color table that are actually used by the bitmap. Set this to 0.
biClrImportant
Specifies the number of color indexes required for displaying the bitmap. If this value is zero, all colors are required. - Image itself is an array of RGBTRIPLES. Sometimes padding is required, but we shouldn't encounter that problem with bitmaps that have a width as a multiple of 4.
For a 128 * 128 pixel image, this would be declared as:Code: Select all
RGBTRIPLE image[128*128]; - Simple example
#include <windows.h> #include <iostream.h> HANDLE hfile; DWORD written; BITMAPFILEHEADER bfh; BITMAPINFOHEADER bih; RGBTRIPLE *image; void() { // Open the file hfile = CreateFile("source.bmp",GENERIC_READ,FILE_SHARE_READ,NULL,OPEN_EXISTING,NULL,NULL); // Read the header ReadFile(hfile,&bfh,sizeof(bfh),&written,NULL); ReadFile(hfile,&bih,sizeof(bih),&written,NULL); // Read image imagesize = bih.biWidth*bih.biHeight; // Helps you allocate memory for the image image = new RGBTRIPLE[imagesize]; // Create a new image (I'm creating an array during runtime) ReadFile(hfile,image,imagesize*sizeof(RGBTRIPLE),&written,NULL); // Reads it off the disk // Close source file CloseHandle(hfile); // Now for some information cout<<"The image width is "<<bih.biWidth<<"\n"; // Will output the width of the bitmap cout<<"The image height is "<<bih.biHeight<<"\n"; // Will output the height of the bitmap } - Since the BMP image is kept upside down in the file, we need to use following codes to read/write pixels.
RGBTRIPLE get_pixel(int x,int y) { // Image define from earlier return image[(bih.biHeight-1-y)*bih.biWidth+x]; } RGBTRIPLE set_pixel(int x,int y,RGBTRIPLE color) { // Image define from earlier image[(bih.biHeight-1-y)*bih.biWidth+x] = color; }
BMP Reader in C++
BMP Reader in C++
Re: BMP Reader in C++
How do I get a zip file to be supported in a bmp (bitmap) file ? Trying to get some jazzy fonts, but when I attempt to open a zipfile (ttf.) it tells me the file isn't supported by a bitmap file. Is there a program I have to download for this ?
Read point 12 of ROBOT.LK - Terms of use. Please start a new topic with a descriptive subject to get an answer.
- SemiconductorCat
- Major
Nice piece of code.
anyway I have reviewed the code.One thing that I have noticed here.
This is another very difference between C and C++.
for a example.
Is oky in C++ but not in C. In C you always have to ,
But still it's not a good practice.
The coding styles suggest you to use this style.
I know neo and others are already know this,but I have mentioned this for completeness.
for a example.
struct A{
int a;
int b;
A a;
typedef struct tag_A{
int a;
int b;
} A;
A a;
struct A
int a;
int b;
typedef struct A A ;
It doesn't make sense as both structures are defined in Wingdi.h as BITMAPFILEHEADER structure and BITMAPINFOHEADER structure which includes when you use Windows.h.
Following is the common practice (just as by Microsoft).
Instead of 'tagA', some programmers use 'A_'.
One thing that most people doesn't know is, in C++, class is an extension of the C language structure. Because the only difference between a structure and a class is that structure members have public access by default and class members have private access by default, you can use the keywords class or struct to define equivalent classes. See Classes Vs. structures (C++ only).
typedef struct tagA {
WORD bfType;
DWORD bfSize;
WORD bfReserved1;
WORD bfReserved2;
DWORD bfOffBits;
} A, *PA;One thing that most people doesn't know is, in C++, class is an extension of the C language structure. Because the only difference between a structure and a class is that structure members have public access by default and class members have private access by default, you can use the keywords class or struct to define equivalent classes. See Classes Vs. structures (C++ only).
- SemiconductorCat
- Major
ya when you don't need to keep a reference or pointer to structure itself, there's not
use of the writng tag_A or tagA or A_ thing.But as a good practice microsoft API writers
have done it. I think it's a good practice.
it will be a issue when defining a structure like this, for a example:
where in a case like that you can't write
because some compilers are not smart enough to see lookahead , and they do just left to right
parsing , in these cases when it generating the parser tree inside the structure definition and it's
elements it never heard anything about 'linked_section_entry'. I think professional compilers like
Microsoft VC++ , GNU G++ have fixed this issue. But the good practice is write it in the defensive
way.
May be in the next version of C++/C , C++0x these things may be fixed and solved.
// part from my real project//
/* declares some internally used data-structures */
struct tab_linked_config_entry;
struct tab_linked_config_entry{
config_parser_entry e;
struct tab_linked_config_entry * next;
typedef struct tab_linked_config_entry linked_config_entry;
struct tag_linked_section_entry{
linked_config_entry * ptr_entry_table;
struct tag_linked_section_entry *next;
typedef struct tag_linked_section_entry linked_section_entry;
typedef struct
struct linked_section_entry * next;
} linked_section_entry;
way.
